Bookmark
Subscribe
743
cisco 2950 switch
almamun
Does catalyst 2950 switch support inline power?
5 Replies 5
mohammedmahmoud
Level 11
Level 11
No, i believe that the first Catalyst switch family that provides PoE is the 3500 series, please check the below document:
http://www.cisco.com/en/US/prod/switches/ps5718/ps708/networking_solutions_products_genericcontent0900aecd805f0955.pdf
You can check the Inline power patch panel, but i'll recommend getting a switch with PoE capabilities:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a00800a9ea3.html
BR,
Mohammed Mahmoud.
Hi Mohammed,
Thanks for reply. Now it is clear for me.
The document that you mentioned is really helpfull.
Bye
Martin Parry
Level 3
Level 3
The 2950 series switches do not support inline power
Martin
Hi Abdullah,
Cisco 2950 switch will not support your requirement but cisco 2960 switch can.
please check this link out:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
CE500 switch can do as well.To be honest,I usually use cisco 3560 switch to do POE functions.
Hopes this helps
Thot
Hi Thot,
Bye
Mamun
