I have 2 - WS-C2960-24TT-L switches. Both are experiencing the same issue.
Upon booting them up, all lights flash on the mode indicator panel, then it goes directly to a solid green "SYST" light. Nothing registers across the console cable. I have tried different baud rates, cables and computers. None of the ports come up regardless of how long either switch is powered on. Holding the Mode button during boot up produces the same result, nothing.
Sounds like they are dead, however, I thought this would be the place to go for ideas. Can I revive these switches?
Solved! Go to Solution.
Nope. Time for you to contact Cisco TAC and get the appliances RMA-ed.
I figured this was the case. Thanks for taking the time to reply.
did you try your console cable and converter. syst led is showing that device is operating. i have 3560 and its syst led also running.you can also look this
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/hardware/installation/guide/higover.html
How did you fix the problem. I am having the same issue.
Have you managed to solve this issue? I am also facing same issue.
Switch was working fine, and power cycle made it to this state.
Any input will be very much appreciated.
Thanks Calcan.
Mine is also out of warranty, if there is no other option, will try to heat the RAMs with hot air gun.
