Cisco 2960 Policy based routing feature availability ?
vinayak-nayak
Hi All,
I am unable to determine if policy based routing feature is available on a Cisco 2960 switch. This is the exact model
Switch Model : WS-C2960X-24PD-L
SW Version :   15.0(2)EX5
SW Image :     C2960X-UNIVERSAL-M
SDM prefer shows as this on the switch "The current template is "lanbase-default" template".  The Cisco guide tells "NOT TO ENABLE ROUTING TEMPLATE WHEN LANBASE DEFAULT IS SETUP" not sure why ?
When i try to type in the ip policy or route-map command the cli says "unrecognized" command.
Muhammad Awais Khan
PBR is supported on 2960XR with IP-Lite image as mentioned in the below datasheet. You can refer to the tables mentioned there where PBR is only listed in 2960XR tables.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html
Further, i did compare the two platforms in feature navigator and find similar results, check the attached
