cisco 2960 switch console port is not working
junaid haroon
I have switch its console is not working where as same console cable is working with all other swtiches
please help me out
anirudh.wna
is it a new switch.
check if,
1.if you have the settings right in hyperterminal/putty/minicom etc..
2.if a different console cable is workig in this switch.
3 you are connecting to the correct console port !!
4.if you have any ip address configure in the switch, try to telnet/ssh to it.
HI,
my switch is old one
i have checked all senarios but still facing same issue
isn,t there any config inside. what is the model of your switch. did'nt you create any int vlan with any ip?? can you recall.. by any chance does  your switch support usb console cable??
Dear,
I have already mentioned a model of switch
