Below you will find more information about the led status, if the system led is Amber, it is receiving power but probably has any hardware problem, including the power supply. If you have a Cisco contract, a ticket with the Cisco TAC should be opened to create a RMA.
Reference: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/hardware/installation/guide/2960_hg/higover.html
LEDs
You can use the switch LEDs to monitor switch activity and its performance. Figure 1-23 shows the switch LEDs and the Mode button that you use to select one of the port modes.
All LEDs are visible through the GUI management applications—Network Assistant for multiple switches and the device manager for a single switch. The switch software configuration guide describes how to use the CLI to configure and to monitor individual switches and switch clusters.
Only the Catalyst 2960 PoE switches have a PoE LED.
The four Catalyst 2960 8-port switches and these models do not have an RPS connector or an RPS LED: Catalyst 2960-24-S, Catalyst 2960-Plus 24TC-S, 2960-24TC-S, 2960-48TT-S, 2960-Plus 48TC-S, 2960-48TC-S.
Figure 1-23 Catalyst 2960 Switch LEDs
SYST LED
Speed LED
RPS LED
PoE LED
Status LED
Mode button
Duplex LED
Port LEDs
System LED
The System LED shows whether the system is receiving power and is functioning properly. Table 1-2 lists the LED colors and their meanings.
Table 1-2 System LED
Off
System is not powered on.
Green
System is operating normally.
Amber
System is receiving power but is not functioning properly.
RPS LED
The RPS LED shows the RPS status. Table 1-3 lists the LED colors and their meanings.
Note
The Catalyst 2960 8-port switches, and the Catalyst 2960-24-S, 2960-Plus 24TC-S, 2960-24TC-S, 2960-Plus 48TC-S, 2960-48TC-S, and 2960-48TT-S switches do not have an RPS LED.
Table 1-3 RPS LED
Off
RPS is off or not properly connected.
Green
RPS is connected and ready to provide back-up power, if required.
Blinking green
RPS is connected but is unavailable because it is providing power to another device (redundancy has been allocated to a neighboring device).
Amber
The RPS is in standby mode or in a fault condition. Press the Standby/Active button on the RPS, and the LED should turn green. If it does not, the RPS fan could have failed. Contact Cisco Systems.
Blinking amber
The internal power supply in a switch has failed, and the RPS is providing power to the switch (redundancy has been allocated to this device).
For more information about the Cisco RPS 2300 or the Cisco RPS 675, see the related hardware installation guide for that power system.
Port LEDs and Modes
The port LEDs, as a group or individually, display information about the switch and about the individual ports ( Table 1-4 ):
Table 1-4 Modes for Port LEDs
STAT
Port status
The port status. This is the default mode.
DUPLX
Port duplex mode
The port duplex mode: full duplex or half duplex.
SPEED
Port speed
The port operating speed: 10, 100, or 1000 Mb/s.
PoE
PoE port power
The PoE status.
Even if the PoE mode is not selected, the PoE LED shows PoE problems when they are detected ( Table 1-5 ). The PoE LED applies only to Catalyst 2960 switches that support PoE.
Table 1-5 PoE Mode LED
Off
PoE mode is not selected. None of the 10/100 PoE ports have been denied power or are in a fault condition.
Green
PoE mode is selected, and the PoE status is shown on the port LEDs.
Blinking amber
PoE mode is not selected. At least one of the 10/100 PoE ports has been denied power, or at least one of the ports has a PoE fault.
To select or change a mode, press the Mode button until the desired mode is highlighted. When you change port modes, the meanings of the port LED colors also change. Table 1-6 explains how to interpret the port LED colors in different port modes.
Table 1-6 Meaning of Port LED Colors in Different Modes on the Switch
STAT (port status)
Off
No link, or port was administratively shut down.
Green
Link present.
Blinking green
Activity. Port is sending or receiving data.
Alternating green-amber
Link fault. Error frames can affect connectivity, and errors such as excessive collisions, cyclic redundancy check (CRC) errors, and alignment and jabber errors are monitored for a link-fault indication.
Amber
Port is blocked by Spanning Tree Protocol (STP) and is not forwarding data.
Note After a port is reconfigured, the port LED can remain amber for up to 30 seconds as STP checks the network topology for possible loops.
Blinking amber
Port is blocked by STP and is not sending or receiving packets.
DUPLX (duplex)
Off
Port is operating in half duplex.
Green
Port is operating in full duplex.
SPEED
10/100 and 10/100/1000 ports
Off
Port is operating at 10 Mb/s.
Green
Port is operating at 100 Mb/s.
Blinking green
Port is operating at 1000 Mb/s.
Off
Green
Blinking green
Note When installed in Catalyst 2960 switches, 1000BASE-T SFP modules can operate at 10, 100, or 1000 Mb/s in full-duplex mode or at 10 or 100 Mb/s in half-duplex mode.
PoE
Off
PoE is off. If the powered device is receiving power from an AC power source, the PoE port LED is off even if the powered device is connected to the switch port.
Green
PoE is on. The port LED is green only when the switch port is providing power.
Alternating green and amber
PoE is denied because providing power to the powered device will exceed the switch power capacity. The Catalyst 2960-Plus 24PC-L, 2960-24PC-L, 2960-Plus 48PST-L, 2960-48PST-L, 2960-Plus 48PST-S, 2960-48PST-S, 2960-Plus 24PC-S, and 2960-24PC-S switches provide up to 370 W of power. The Catalyst 2960-24LT-L, 2960-Plus 24LC-L, 2960-Plus 24LC-S, and 2960-24LC-S switches provide up to 124 W of power.
Blinking amber
PoE is off due to a fault.
Caution PoE faults are caused when noncompliant cabling or powered devices are connected to a PoE port. Only standard-compliant cabling can be used to connect Cisco prestandard IP Phones or wireless access points or IEEE 802.3af-compliant devices to PoE ports. You must remove from the network the cable or device that causes a PoE fault.
Amber
PoE for the port has been disabled. By default, PoE is enabled.
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
