Cisco 2960 X series
Hi,i have a cisco 2960 x series which i was trying to update the GUI which was not successful tried to run recovery image but still not successful. This is now the state when i boot the switch. Any help will highly be appreciated.
7 Replies 7
Mark Elsen
 - Rather empty information I feel,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Is there a way i can run a recovery image to get out of that loop since the solution i tried seem not to work based on the image i have attached.
 - I don't see any boot loop , in fact I only see an empty screen, please verify your image and or post again.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks for your response...i have highlighted on the attached image av sent again.
 - Whatever's in there is totally unreadable, if possible  provide output from a direct serail-console which can keep output in a logging file , too - ease then to post.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
chesterr
Are you sure that you have properly settings console?
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
Have you tried change boot of OS from "rommon"?
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
Yes those are my current console settings...i am unable to get to ''rommon'' despite trying several times
