OSPFv3 on Switch
hosborne7531
Visitor
So trying to run OSPFv3 on a IOSL2 and a NX-OS switch, I receive a error stating "Protocol not in this image". So does CML not going to allow me to use this protocol or is there a "fix" I can do (Not using a router)?
Snippet output from config:
DLS2(config)#ip routing
DLS2(config)#ipv6 unicast-routing
DLS2(config)#router ospfv3 1
As I know, IOSvL2 is not supported
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Georg Pauwen
are you using the VIRL (or IOSv) images ? Post the output of 'sh ver' of both devices...
Not able to access the NX-OS right now, but here is the IOSvL2
***IOSvL2***
DLS2(config)#do sho ver
Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2(CML_NIGHTLY_20190423)FLO_DSGS7, EARLY DEPLOYMENT DEVELOPMENT BUILD, synced to V152_6_0_81_E
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 23-Apr-19 04:48 by mmen
ROM: Bootstrap program is IOSv
D2 uptime is 51 minutes
System returned to ROM by reload
System image file is "flash0:/vios_l2-adventerprisek9-m"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IOSv () processor (revision 1.0) with 722281K/62464K bytes of memory.
Processor board ID 9MKG1WP49VI
2 Virtual Ethernet interfaces
4 Gigabit Ethernet interfaces
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
2097152K bytes of ATA System CompactFlash 0 (Read/Write)
0K bytes of ATA CompactFlash 1 (Read/Write)
11217K bytes of ATA CompactFlash 2 (Read/Write)
0K bytes of ATA CompactFlash 3 (Read/Write)
Configuration register is 0x101
Deepak Kumar,
Hmm, seems strange that the designers would program a option of using OSPFv3 but not actually provide the service for it. Just wasn’t sure if I was missing something special for the virtual lab equipment. So my fix action was to just replace the switch with a router and modify the requirements of the lab for the students. Thanks.
