Bookmark
Subscribe
50494
Cisco Part Number Legend
michael.pierson
Anyone know where you can get the Cisco part number legend from?
Example:     "WS-C2960-24TT-L"     what do the letters mean after the -24 [TT-L]
15 Replies 15
Leo Laohoo
The "TT" stands for the type of uplink.  In this case, it's TWO (2) 10/100/1000BaseTX.
"L" is what kind of image.  In this case it's LAN Base.
http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html
Thanks leolaohoo for your response.  Is there a legend or documentation anywhere that spells all this out?  How did you come across this information?
Experience.
vaib7av.shirkul
WS-C2960-24TT-L
WSWire Speed
CCatalyst
2960/2960GSeries of switches 2960-10/100 and 2960G-10/100/1000 for host.
24Interfaces for host
TTFirst T refers type of host interface, means UTP and second T (both are UTP ports) refers type of uplink interface
if 2960-24TC-L then C   means Combo - SFP and UTP - you can use only one type of interface.
if 2960-24PC-L then P   means PoE port for hosts.
LL for image of switch   L- for LAN BASE  and S - for Lan Lite image.
So there is no any particular documenet where we can find the actual meaning/defination/login behind each word for particular Cisco part number???
I also in search of that document.
Can any one please help out??
Nope.
Ok, But than how can i get the details for router, wireless, etc.. devices.
For example, can u help me to understand below part numbers?
C1921-3G-G-SEC/K9
AIR-CAP1602i-N-K9
AIR-CAP1602i-N-K9
CAP = Controller-based IOS loaded to the AP
1602 = Wireless Access Point 1600 with dual antennas (hence the "XXX2")
-N = Wireless LAN regulatory domain
K9 = Security.
C1921-3G-G-SEC/K9
CISCO1921 Bundle with HWIC-3G-HSPA-G, Universal Base, 256FL/512DR, Adv Security
hi
from where you get this table Please
Any Cisco authorized document for this naming convention?
Nimesh Patel
Is anybody knows  what legends stands for below parts numbers:
WS-C2960S-24PD-L
WS-C2960S-48FPD-L
Both same switches with diff in ports count then why F is missing in WS-C2960S-24PD-L?
Thank you
"F" means FULL Poe Power.  This "F" can only be found in some selected 48-port switches.  You will not be able to find "F" in 24 ports.
When you see "F", it means that you can push up to 48-ports of 15.4w PoE.
It is really difficult to understand full functionality of device just to see part number however Cisco must provide proper document explaining what LETTER they would be using in part number for what purpose but I could not fine.
I have attached that give good idea about that.
