cisco 2960-x
rehbejoh36
im trying to load .tar file on cisco 2960-x with command
boot flash:/c2960x-universalk9-tar.152-7.E5.tar
I get
error loading
anyone know what im doing wrong
13 Replies 13
balaji.bandi
If you looking to boot from file, then you need to get extention .bin (file)  not .tar file
You  can use below document for tar file installation : ( example)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_58_se/configuration/guide/2960scg/swiosfs.html
BB
I had a .bin file but the web would not work.I was told to go to cisco web site and get the .tar
what is the current version
show version
if you like to upgrade and get GUI below command should work for you.
# archive download-sw /leave-old-sw flash:c2960x-universalk9-tar.152-7.E5.tar
if you looking more option :
#archive download-sw ?
/allow-feature-upgrade Allow installation of image with different feature sets
/directory Specify a directory for images
/force-reload Unconditionally reload system after successful sw upgrade
/force-ucode-reload Upgrade UCODE after successful sw upgrade and before an unconditional reload
/imageonly Load only the IOS image(s)
/leave-old-sw Leave old sw installed after successful sw upgrade
/no-set-boot Don't set BOOT -- leave existing boot config alone
/no-version-check skip version check that prevents incompatible image install
/overwrite OK to overwrite an existing image
/reload Reload system (if no unsaved config changes) after successful sw upgrade
/safe Always load before deleting old version
/upgrade-ucode Upgrade UCODE after successful sw upgrade (no reload)
BB
verison 15.2(7)E5
Try as suggested above post :
# archive download-sw flash:c2960x-universalk9-tar.152-7.E5.tar
BB
is this test switch or offline you upgrading ?
if this is not live :
1. just reboot the switch
2. dir flash: make sure you have  (c2960x-universalk9-tar.152-7.E5.tar)
3. Do you have enough space in flash
Note : Do not post screenshots, post capture the logs in notepad and attach
BB
ok thanks and its offline
95057920 bytes free
dir flash shows bin file not tar file
so do I need to load tar again using this command
copy xmodem:c2960x-universalk9-mz.152-7-E5.tar flash:c2960x-universalk9-mz.152-7-E5.tar
then use the archive command?
as per the message the file not in flash: (either copy to flash and install )
X model should have USB, copy the TAR file to USB or insdtall from USB.
BB
Leo Laohoo
Yes if you want the GUI to work you can not use a bin file and need the tar file. As others have explained the boot command uses the bin file, but that is not what you really want. To use the tar file you need to use the archive command.
Rick
this is what I get when I do the archive command.
WTF.  That boot variable string is so wrong in so many places.
Do not "re-invent the wheel" and keep it simple.  Use the following command:
This script will do the following:
  • Unpack the BIN file into the correct location.
  • Perform a quick hash check to guarantee the BIN file is not corrupt.
  • Correctly set the boot-variable string without any human intervention.
Can "copying" the BIN file do all of these three with one command?  No, it does not.
