Basic Network with Firewall
cyberWolf
Hi Good Day,
Hoping that someone can advise me why I cannot ping the router from inside the firewall. I have this basic network with end devices inside the firewall that is connected to a switch, I was able to ping all the devices inside the firewall with one another but if I am trying to ping the router which is outside the firewall I received a no reply. (is it normal if I am using firewall?)
Then, I tried to ping the router from the firewall connected to another switch, that connects the firewall and the router from outside I received a successful reply, but from router to inside end devices inside the firewall and vice versa end device to firewall the ping fails.
Georg Pauwen
the router has no routing, and the firewall needs to allow ICMP. Add the lines marked in bold:
ciscoasa#sh run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 172.16.1.100 255.255.255.0
--> access-list ICMP extended permit icmp any any
--> access-group ICMP in interface outside
telnet timeout 5
ssh timeout 5
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
ciscoasa#
Router#sh run
Building configuration...
Current configuration : 651 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524Q9Z1-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
--> ip route 0.0.0.0 0.0.0.0 172.16.1.100
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Georg Pauwen
ciscoasa#sh run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
telnet timeout 5
ssh timeout 5
dhcpd enable inside
ciscoasa#
Router#sh run
version 15.1
hostname Router
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Hi @Georg Pauwen
Thank you for the help, I will then proceed for basic configuration of each device and be able to complete the activity.
Thank you
