Cisco 2960s Stack High availability issue
Hi All,
Recently we have deployed 2 2960s series switches with flexstack module, and configured as:
1) company-sw1#sh switch neighbors
  Switch #    Port 1       Port 2
      1            2              2
      2            1              1
2)company-sw1#  sh switch
Switch/Stack Mac Address : 2401.c7ef.1300
Mac persistency wait time: Indefinite
                                           H/W   Current
Switch#  Role   Mac Address      Priority Version  State
*1       Master  2401.c7ef.1300      14         1         Ready
2       Member 2401.c7e5.7a00     2          1         Ready
3       Member 0000.0000.0000     0          1         Provisioned
3) company-sw1# sh run
stack-mac persistent timer 0
interface Port-channel1
switchport mode access
interface Port-channel2
interface GigabitEthernet1/0/1
spanning-tree portfast
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/0/2
channel-group 2 mode active
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
AT the server side , we have configured teeming (bond) of eth0 and eth1 with 802.3ad protocol support for both the servers, teaming is working fine.
And started the ping from one server to other ,
1. And if i poweroff  the Master switch , there is no issue (no dropages in the icmp request/reply or Tcp ).
2. Even though  the Master switch comes back, the  member becomes Master , and stays as it is until the new master restarts.
3. But if i powerof the the new Master which is using the persistent mac of old master switch, i lose the atleast 3 icmp packet.
Pls reply....
Ashraf
Reza Sharifi
Hi Ashraf,
With Portchannel, you loose what is already in the wire when you tun off the master or member.  If for example the server is using interface 2/0/2, you are not going to see any packet drops, because the packet is traversing the member switch. Now if the server using port 1/0/1, when you shut down the master, you will see a 1, 2 or 3 packet drops and that is what is in the wire.
If you want to know what port the switch is using to forward packet at any time use this command:
test etherchannel load-balance interface port-channel xx mac .......
Many Thanks Reza,
i hve few quick questions.
1. Can we improve this process of portchannel with some configuration , so that i will not loose those 1,2 or 3 packet drops, is it possible....
2. Will there be any difference if i connect the Stack in Cisco 2960s , as port1 of switch1 to port 1 of switch2 and  port2 of switch1 to port2 of switch2  OR  port1 of switch1 to port2 of switch2 and port2 of switch1 to port1 of switch2.
Ashraf
