06-05-2013 09:06 PM - edited 03-07-2019 01:44 PM
Hi Experts,
I would like to know if there is STP recalculation caused vlans to bounce on the switch.
Eg:
SwitchA-----Port-channel-------SwitchB-----SwitchC
I have couple of vlans on all th switches. Portchannel is layer 2 between A and B.
but when I shut down the portchannel between the switches I see the vlans which are active on the Switch B going down and come back online
Even the vlans which are active and up between switch B and C are too going down when i shut down the port channel.
Example:
Vlan 30
ip address 30.0.0.3 255.255.255.0
sh vlan id 30
ports Po1, Gig 3/1 ( gig 3/1--connecting to Switch C)
Error:
Port channel down-->
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan30, changed state to down
%LINK-3-UPDOWN: Interface Vlan30, changed state to up
: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan30, changed state to up
Question:
Why is this Vlan going down and coming up online?
Is this due to STP recalculation?
I could see some rootchange happening when i shut down the port-channel. Hence want to know does this vlan bounces bcz of STP recalculation?
Fari
06-06-2013 05:25 PM
Any update on this please?
06-06-2013 08:57 PM
Which switch is the actual gateway for the vlans having the issue?
Which switch is the spanning tree root?
Can you post the config of the EtherChannel?
