Cisco 2960x Downgrade problem
Fred06
Could you inform me if it is possible to downgrade from version 15.2(4)E6 to 15.2(2)E7 ?
Is it necessary to do a special manipulation ?
I tried to do it with the following commands but the Switch doesn't seem to start correctly.
  • archive download-sw /overwrite /reload tftp://tftp_server_ip/file_name".
Thanks for your feedback.
13 Replies 13
Leo Laohoo
Yes, it can be done.
Maybe the switch is doing a ROMMON downgrade?
can you share show version output. also check below link for IOS change process.
https://www.grandmetric.com/knowledge-base/design_and_configure/ios-image-upgrade-procedure-best-practice/
rate this and mark as answer if this solved your concern
Good luck
KB
marce1000
        >..archive download-sw /overwrite /reload tftp://tftp_server_ip/file_name
                     - Did  the particular command complete successfully ?
 M.
Fred06
I tested again this week and here are the results;
I executed the following commands to transfer my firmware to the Switch:
+ Switch# archive tar /xtract TFTP://192.168.150.2/cme-full-7.1.0.0.tar flash: (Copie et décompresse l'image dans le flash)
+ Switch# verify /md5 flash:/new_copied_image_name.bin (Vérification de la nouvelle image)
+ Switch# sh run | i boot
+ Switch(config)# boot system flash:/folder/new_copied_image_name.bin (Change l'image de démarrage)
+ Switch# reload (Redémarre le Switch avec la nouvelle image)
Then the Switch does looping reboots. Here is some information about the boot:
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 833536
mifs[5]: Bytes available : 972800
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1004032
mifs[6]: Bytes available : 2866688
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 964 files, 22 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 121823744
mifs[9]: Bytes available : 361984
mifs[9]: mifs fsck took 82 seconds.
...done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin"...Verifying image flash:c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin.....................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 12-Jul-17 13:06 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 833536
mifs[7]: Bytes available : 972800
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1004032
mifs[8]: Bytes available : 2866688
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 1 seconds.
mifs[10]: Initialization complete.
mifs[11]: 964 files, 22 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 121823744
mifs[11]: Bytes available : 361984
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
Failed to get Board Configuration
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
07:02:39 UTC Mon Nov 15 2021: Unexpected exception to CPUvector 1200, PC = 90640018
-Traceback= 0x90640018z 0x2B8BA70z 0x2B8BBA4z 0x2B8C0FCz 0x295CA38z 0x21A79D4z 0x21A7BB0z 0x21A7D28z 0x5688D8z 0x568B48z 0x2E3A760z 0x2E36460z
=== Flushing messages (07:02:40 UTC Mon Nov 15 2021) ===
Buffered messages:
Queued messages:
Nov 15 07:02:40.233: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:01:09.628: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.087: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Nov 15 07:02:39.687: in Switch 0. Cannot read pid from Flexstack module
Nov 15 07:02:40.117: %Insufficient flash filespace for extended crashinfo.
Instruction TLB Miss Exception (0x1200)!
SRR0 = 0x90640018 SRR1 = 0x00029200 SRR2 = 0x021C7D9C SRR3 = 0x00029200
ESR = 0x00000000 DEAR = 0xC7F3998A TSR = 0x84000000 DBSR = 0x00000000
CPU Register Context:
Vector = 0x00001200 PC = 0x90640018 MSR = 0x00029200 CR = 0x59000099
LR = 0x0296C4DC CTR = 0x90640018 XER = 0xA000004C
R0 = 0x00000000 R1 = 0x0579BEF8 R2 = 0x00000000 R3 = 0x00000000
R4 = 0x0000000E R5 = 0x00000000 R6 = 0x0579BF4C R7 = 0x00000049
R8 = 0x00000209 R9 = 0x90640018 R10 = 0x00000209 R11 = 0x035B0038
R12 = 0x39000093 R13 = 0x1F183944 R14 = 0x0054B088 R15 = 0x03CB7050
R16 = 0x03D67DB0 R17 = 0x03DED4D4 R18 = 0x04D83A1C R19 = 0x03DED4C4
R20 = 0x03D67E08 R21 = 0x04D83A10 R22 = 0x066D747C R23 = 0x00000002
R24 = 0x00000036 R25 = 0x00000001 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x0000000E R29 = 0x00000000 R30 = 0x00000001 R31 = 0x00000004
Stack trace:
PC = 0x90640018, SP = 0x0579BEF8
Frame 00: SP = 0x0579BF18 PC = 0x00000000
Frame 01: SP = 0x0579BF38 PC = 0x02B8BA70
Frame 02: SP = 0x0579BF60 PC = 0x02B8BBA4
Frame 03: SP = 0x0579C010 PC = 0x02B8C0FC
Frame 04: SP = 0x0579C070 PC = 0x0295CA38
Frame 05: SP = 0x0579C080 PC = 0x021A79D4
Frame 06: SP = 0x0579C0A0 PC = 0x021A7BB0
Frame 07: SP = 0x0579C0B8 PC = 0x021A7D28
Frame 08: SP = 0x0579C0E8 PC = 0x005688D8
Frame 09: SP = 0x0579C1E8 PC = 0x00568B48
Frame 10: SP = 0x0579C1F0 PC = 0x02E3A760
Frame 11: SP = 0x00000000 PC = 0x02E36460
Switch uptime is 1 minute, 26 seconds
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision M0) with 524288K bytes of memory.
Processor board ID FCW2146B3DW
CPU rev: B
Board rev: 18
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Xmodem file system is available.
Base ethernet MAC Address: 2c:0b:e9:0f:37:80
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
executing...
cisco Systems, Inc.
07:08:11 UTC Mon Nov 15 2021: Unexpected exception to CPUvector 1200, PC = 90640018
=== Flushing messages (07:08:12 UTC Mon Nov 15 2021) ===
Buffered messages:
Queued messages:
Nov 15 07:08:12.233: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:01:09.580: Read env variable - LICENSE_BOOT_LEVEL =
Nov 15 07:08:11.687: in Switch 0. Cannot read pid from Flexstack module
Nov 15 07:08:12.117: %Insufficient flash filespace for extended crashinfo.
SRR0 = 0x90640018 SRR1 = 0x00029200 SRR2 = 0x02527E54 SRR3 = 0x00029200
R0 = 0x00000000 R1 = 0x05E1BA30 R2 = 0x00000000 R3 = 0x00000000
R4 = 0x0000000E R5 = 0x00000000 R6 = 0x05E1BA84 R7 = 0x00000048
R20 = 0x03D67E08 R21 = 0x04D83A10 R22 = 0x06D570AC R23 = 0x00000002
Stack trace:
PC = 0x90640018, SP = 0x05E1BA30
Frame 00: SP = 0x05E1BA50 PC = 0x00000000
Frame 01: SP = 0x05E1BA70 PC = 0x02B8BA70
Frame 02: SP = 0x05E1BA98 PC = 0x02B8BBA4
Frame 03: SP = 0x05E1BB48 PC = 0x02B8C0FC
Frame 04: SP = 0x05E1BBA8 PC = 0x0295CA38
Frame 05: SP = 0x05E1BBB8 PC = 0x021A79D4
Frame 06: SP = 0x05E1BBD8 PC = 0x021A7BB0
Frame 07: SP = 0x05E1BBF0 PC = 0x021A7D28
Frame 08: SP = 0x05E1BC20 PC = 0x005688D8
Frame 09: SP = 0x05E1BD20 PC = 0x00568B48
Frame 10: SP = 0x05E1BD28 PC = 0x02E3A760
CPU rev: B
Board rev: 18
Testing DataBus...
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Thank's in advance !
It's possible that this switch (cisco WS-C2960X-48FPD-L) doesn't support this old version ? (c2960x-universalk9-mz.152-2.E7.bin)
I transferred a newer image again and then downgraded but I still get the looping starts..
Thank's !
If the switch boots into ROMMON, post the complete output to the command "dir flash:".
Does the switch have a stacking module installed, if it does, remove it.
Thank's for your reply,
I'm on site tomorrow, I will take the information. But I know that I have two firmware like this : flash:/x2960x-universalk9-xxxx/x2960x-universalk9-xxxx.bin
One is working but I have to use the second (most older) for the stack.
The Switch doesn't have a stacking module at this moment.
Thanks !
Here is the information contained in the flash:
switch: dir flash:
Directory of flash:/
    2  drwx  512       <date>               c2960x-universalk9-mz.152-2.E7
  668  -rwx  109       <date>               info
  669  drwx  512       <date>               dc_profile_dir
  671  drwx  512       <date>               c2960x-universalk9-mz.152-4.E6
  673  -rwx  2475      <date>               config.text
  674  drwx  23040     <date>               crashinfo_ext
  985  -rwx  10264     <date>               multiple-fs
  986  -rwx  5         <date>               private-config.text
374K bytes available (118948K bytes used)
switch:
Thank's in advance.
Please post the output to the following command:  dir flash:c2960x-universalk9-mz.152-4.E6
Here is the result :
switch: dir flash:c2960x-universalk9-mz.152-4.E6
Directory of flash:c2960x-universalk9-mz.152-4.E6/
  672  -rwx  24667136  <date>               c2960x-universalk9-mz.152-4.E6.bin
switch:
Thanks !
Ok, try this:  boot flash:c2960x-universalk9-mz.152-4.E6/c2960x-universalk9-mz.152-4.E6.bin
With this image, the switch is functional.
However, I absolutely have to downgrade with the other image.
Is there a solution from there?
Switch>show ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 02:53 by prod_rel_team
Thank's
Oh, f*ck.
Look at this Reddit thread:  Possible Counterfeit Cisco Equipment w/Photos
Look at the photos carefully.
Lift the motherboard and see if there is a "mini".
