Cisco 2960X - power inline auto max 15400
mwhite1983
I have a new stack of five 2960X's and recently started to configure the stack, and found the "power inline auto max 15400" on my 3rd switch in the stack.  I did a "show power inline" and confirmed it set the max to 15.4 instead of the default 30.0 found on the other switches in the stack.  I (nor anyone else) has entered this command on any interfaces on this stack.
What would trigger this to appear if it was not manually entered?  I noticed this on a single switch in another stack I was working on previously as well.
Matt
5 Replies 5
ubhnetworking
I have seen this on our 2960x stacks too.
If you do a show run all you will see the configuration on the port is :
 power inline static max 15400
If you change it to
power inline auto max 30000
the
will go away.
Not sure why some switches default on 15400 and others on 30000.
+5
We just deployed a dozen of these for a customer - all the exact same hardware and software revision (WS-C2960XR-48LPD-I running 15.2(3)E2 ).
I but a basic identical template config on every one - changing only the hostname and management IP address per switch.
11 of the 12 were fine. #12 only had the errant command show up on all of its interfaces. I made the change dwilliams suggested and voila they were all identical.
Weird.
ciscokid6969
me too!
My first time with these switches and i am setting them up. noticed that the second switch in the stack created a line under all the interfaces for just that one switch. Don't think it hurts anything. But I would also like to know where it came from and why it is there.
I run "no power inline auto max 15400" and the line was removed.
When I did a show power inline Gix/x/x
#show power inline Gix/x/x
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/7   auto   on         6.3     xxxxxxxxxx       2     30.0
Interface  AdminPowerMax   AdminConsumption
             (Watts)           (Watts)
Gix/x/x               30.0                 30.0
