Cisco 2960X web interface works but contents are not clickable
denial
I have two Cisco 2960-X one 24 port and one 48 port.
Web interface works on both but in 48 port switch i cannot click the contents (For example i click in contents the Monitor i get the drop down menu with options i click port status and nothing happens).
They have same configuration , the only difference is the software.
The 2960-X 24 port has 15.2(2) and the 2960-X 48 port has 15.0(2)
I tried all the browsers chrome/IE/edge/safari/Mozilla but in the 2960-X 48 port  web interface i click the contents and nothing happens.
Thank you!
Deepak Kumar
Update a JAVA program and switch IP in trusted sites and try in IE.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar,
It worked with IE only but i am ok with it .
Thank you !!
Mark Malone
the CNA is a bit flaky , lot of posts regarding it not working fully , if you tried everything on PC end , try sort it from switch side
one thing to try is another version of CNA, i see c2960x-cwml.01_06_00.tar is available or roll back if already on it and try on of the earlier ones
are you using same version CNA on both switches ?
https://software.cisco.com/download/home/284795755/type/286310882/release/01.06.00
