05-15-2016 10:49 PM - edited 03-08-2019 05:46 AM
Hi.. I am not sure whether Cisco make any 2960X non PoE with 1G uplink module(Not 10G). If it is.. could you please confirm model name.
05-15-2016 10:59 PM
There are lots of options.
WS-C2960X-48TS-L
WS-C2960X-24TS-L
WS-C2960X-48TS-LL
WS-C2960X-24TS-LL
05-16-2016 01:57 AM
Thanks Philip, one more query.. I want to stack six 2960X switches, where first and last switch will be of model C2960X-48TD-L because I want to have 10G uplinks and rest middle four switches will be of C2960X-48TS-L model because these will not have uplinks connectivity so choosed it. This I will be doing due to cost cutting. I would like to know what would be impact in this case.
Thanks.
05-16-2016 02:07 AM
Your choice of uplinks and port density is a question of what you want the over-subscription ratio to be.
If you had 6 x 48 ports 1Gb/s, or 288Gb/s (in one direction) and you used 4 x 10Gbe uplinks, then you'll have a 7.2:1 over-subscription ratio. Actually it'll be worse than that, because I think FlexStack has an 80Gb/s connection.
What when you are talking about users, the ports are not very busy most of the time, so it should be fine.
