WS-C3750X-12S-E issues with C3KX-NM-10GT uplink module and GLC-T SFPs
adaniells
I have a stack of 2 WS-C3750X-12S-E switches running C3750E-UNIVERSALK9-M Version 12.2(55)SE8.
If I insert a C3KX-NM-10GT (Two 10GB-T ports) network module in either stack member it logs "%PLATFORM-4-FRULINK_UNSUPPORTED: Unsupported FRULink 10G NS module inserted in Switch 1. Remove the unsupported module and insert a supported FRULink module."  If I remove said module then the stack member crashes.  These modules are listed on the 3750X datasheet so I thought they should work.  Any idea what the problem is?
Also one stack member with Model revision number: A0 will recognise GLC-T SPFs but the other stack member which was recently replaced and has Model revision number: R0 does not recongnise these SFPs.  They don't show up on show inventory if inserted in the second stack member.  Fibre SFPs show up OK though.  Any ideas?
Furose M
Level 3
Level 3
The min supported version is
15.0(1)SE
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/release/notes/OL25302.html
can you try upgrading first and then investigate the issue?
Thanks Furose I'll look into that.
