Cisco 3020 switches in C-Class Enclosure
nawas
Level 4
Level 4
Has any been able to configure Cisco 3020 switches from within the Onboard administrator of HP C-Class enclosures?
I'm trying to find a way to do this but have no luck so far.
Thanks.
rsohi
I usually use the cli and console to configure the switches. I believe that the on board adminstrator only allows you to configure the management port fa0.
You can use Device Manager by entering in the switch module ip address. Device manager runs in the switch module memory.
hth,
Raj
