Cisco 3120X - blade mac-addresses in wrong VLAN
jamesl0112
Summary of problem:
- Incoming frames on three of a blade's four switchports are being put into VLAN 1 even though the ports are either in other access VLANs, or are configured as trunks with different VLAN IDs being tagged by the server.
- When the ports go down the access VLAN is removed from the port.
Switch stack: 4x WS-CBS3120X-S, 12.2(58)SE1
HP blade: HP BL460c Gen8
This combination has been used successfully elsewhere.
Switchport configuration:
interface GigabitEthernet1/0/13 -------> THIS PORT IS OK
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
end
interface GigabitEthernet2/0/13 -------> NOT OK
switchport access vlan 100
switchport mode access
flowcontrol receive desired
spanning-tree bpduguard enable
end
interface GigabitEthernet3/0/13 -------> NOT OK
end
interface GigabitEthernet4/0/13 -------> NOT OK
end
mac-address table shows that these are being put into VLAN 1:
Vlan    Mac Address       Type        Ports
   1    1060.4b01.44d1    DYNAMIC     Gi3/0/13
   1    1060.4b01.44d5    DYNAMIC     Gi4/0/13
   1    1060.4bab.e66d    DYNAMIC     Gi2/0/13
- These mac-addresses are correct so we know they are coming from the correct NICs into the correct switchports.
- If the blade is powered off - the switchports go down. When this happens, the access VLAN is somehow removed from the switchports that are configured as access ports:
end
end
Suggestions welcome - thanks.
jamesl0112
A reload of the stack resolved this problem.
