Cisco 350x as alternate for Aruba 2930f
adeebtaqui
Level 4
Level 4
My customer wants aruba switches but i want to recommend for cisco switches instead.
Can someone please recommend the best cisco alternate for below aruba items
Solution should equivalent and cost effective
Aruba core 5406r : cisco 9400
Aruba 7205 wlc
the SG350X would be a good alternative for the Aruba 2930f. Certainly a lot cheaper than the Catalyst 9200.
Whether you go with the HP/Aruba or the Cisco devices depends on what else you have in your network. I would recommend to avoid multi-vendor environments as much as possible...
Can you please share some disadvantages of multi vendor envoironment as I want to use them in my discussion with customers?
