Cisco 3524-PWR-XL uplink configuration
dberthoud
Has anyone used 2 cisco 3524-PWR-XL switches uplinked together to make 48 ports? Is it possible to uplink 2 fastethernet ports so the switches talk to each other. If it can be done does any know what the configuration should be I have used the following with no success.
interface FastEthernet0/24
 description Uplink to DBSwitch2 Room 202
 switchport trunk native vlan 235
 switchport trunk allowed vlan 1,135,235,1002-1005
 switchport mode trunk
 switchport priority extend trust
Thanks for any help it is greatly appreciated.
Donovan
nehmaan123
I think you might be looking to build an etherchannel between the two switches.
Please check this link: http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/21041-131.html
Thanks  I went through link and tried commands but it doesn't seem to work.
Donovan
