Cisco 3550 48SMI lights solid Amber
Mesrop Saakyan
I turn on the switch and the lights are solid amber. I can't console into the device. I checked the fan and it seems to be working properly. Any advice will be appreciated. Thank you.
Mesrop Saakyan
Also forgot to state, that the System and RPS lights are amber also.
