Cisco 3550 (SMI 12.2) Inter Vlan Routing
kevinang74
Hi, I'm trying to setup inter vlan routing with my cisco 3550 layer 3 switch. My router is a cisco 2621XM.
Inter Vlan routing and access list is working fine. However, Internet access is not working. None of the machine in all the Vlan have internet access.
Ping test fail at the router 192.168.1.1
Is there anything I missed out?
Siwtch Config
version 12.2
no service pad
hostname switch
enable secret 5 $1$VIUk$X4CgzXTlrvQ/MdJMreQX21
enable password
no aaa new-model
clock timezone SIN 8
ip subnet-zero
ip routing
ip dhcp excluded-address 192.168.2.1 192.168.2.100
ip dhcp excluded-address 192.168.2.201 192.168.2.254
ip dhcp excluded-address 192.168.3.1 192.168.3.100
ip dhcp excluded-address 192.168.3.201 192.168.3.254
ip dhcp excluded-address 192.168.4.1 192.168.4.100
ip dhcp excluded-address 192.168.4.201 192.168.4.254
ip dhcp excluded-address 192.168.5.1 192.168.5.100
ip dhcp excluded-address 192.168.5.201 192.168.5.254
ip dhcp pool labpool
    network 192.168.4.0 255.255.255.0
    dns-server 165.21.83.88 165.21.100.88
    default-router 192.168.4.254
ip dhcp pool userpool
    network 192.168.2.0 255.255.255.0
    default-router 192.168.2.254
ip dhcp pool wireless
    network 192.168.5.0 255.255.255.0
    default-router 192.168.5.254
ip dhcp pool production
    network 192.168.3.0 255.255.255.0
    default-router 192.168.3.254
crypto pki trustpoint TP-self-signed-2461056768
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2461056768
revocation-check none
rsakeypair TP-self-signed-2461056768
crypto pki certificate chain TP-self-signed-2461056768
certificate self-signed 01 nvram:IOS-Self-Sig#3801.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 200
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
switchport access vlan 500
interface FastEthernet0/16
interface FastEthernet0/17
switchport access vlan 400
interface FastEthernet0/18
interface FastEthernet0/19
switchport access vlan 300
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
no switchport
ip address 192.168.1.254 255.255.255.0
speed 100
duplex full
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode dynamic desirable
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan200
description Users
ip address 192.168.2.254 255.255.255.0
interface Vlan300
description Production
ip address 192.168.3.254 255.255.255.0
interface Vlan400
description Testlab
ip address 192.168.4.254 255.255.255.0
ip access-group 101 in
interface Vlan500
description Wireless
ip address 192.168.5.254 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http secure-server
access-list 101 permit tcp 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255 established
access-list 101 permit icmp 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255 echo-reply
access-list 101 permit udp any any eq bootpc
access-list 101 permit udp any any eq bootps
access-list 101 deny   ip 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
control-plane
line con 0
password
login
line vty 0 4
password
login
line vty 5 15
login
end
The router config is
version 12.3
service password-encryption
hostname aggarouter
boot-start-marker
boot system flash:2600-ik9s-mz.123-26.bin
boot-end-marker
enable secret 5 $1$.Af7$mlxHi9HoWKx07pKpoopEX.
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip domain lookup source-interface FastEthernet0/0
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh rsa keypair-name
description WAN INTERFACE
ip address dhcp
ip nat outside
ip route-cache flow
speed auto
full-duplex
description LAN INTERFACE
ip nat inside
ip route-cache flow
speed auto
full-duplex
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.1.20 22 interface FastEthernet0/0 1022
ip nat inside source static tcp 192.168.1.8 21 interface FastEthernet0/0 21
ip nat inside source static tcp 192.168.1.3 22 interface FastEthernet0/0 22
ip nat inside source static tcp 192.168.1.11 67 interface FastEthernet0/0 67
ip nat inside source static tcp 192.168.1.11 800 interface FastEthernet0/0 800
ip nat inside source static tcp 192.168.1.10 3389 interface FastEthernet0/0 3389
ip http server
ip http access-class 1
no ip http secure-server
no ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip dns server
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
line 33 48
line aux 0
line vty 0 4
password 7 060708264D5D100A
login
transport input telnet ssh
line vty 5 15
login
end
CSCO11780655
Hi, I was just looking at glance and I see your DNS ip address has a different subnet compared with your users and management ips. Please enable ip classless on your switch an look for any differences.
15 Replies 15
nkarpysh
So from LAN you are reaching the router - is Good.
The problem is now with routing or NAT I guess, First of all on router check if you hav a route to internet. If yes - good, if not - sort it applying static on ding dynamic routing with provider.
Next steps is NAT - if routing presnt your LAN host can send traffic to internet, but those send it with source address of 192.168.x.x. And internet servers have no idea how to forward it back. You need to configure NAT or PAT in your case to to make the translation of source address.
You can learn more about NAT/PAT here or other resources:
http://www.cisco.com/en/US/partner/technologies/tk648/tk361/tk438/technologies_white_paper09186a0080091cb9.html
http://www.cisco.com/en/US/partner/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml
Hope this helps,
Nik
HTH,
Niko
Thanks for your reponse.
To add, I can ping internet from the switch itself but from machine, cannot ping the router
See your curent NAT on WAN interface:
So you only NATing network 192.168.1.0 0.0.0.255 to the WAN. So when you do ping from Switch it is going from switch ip 192.168.1.254 which is within this range and that is working. Your LAN subnets are not within this range so NAT is not applied to those. You need to add you LAN subnets to ACL 1 for NAT to be applied to those as well.
Nik
HTH,
Niko
I added other LAN subnet to the ACL 1 already but still not working.
Any other ideas?
Put ip address 192.168.1.2/24 on int vlan1 on the switch and do a no shut on that interface then try your pings.
No luck. I get an error when I do that
192.168.1.2 overlapps with Fastethernet 0/23
Port 23 on the switch is plugged directly to fao/1 on the router?
yes, it is connected directly to the router fa0/1
no switchport
speed 100
duplex full
Add additional statements to acces-list 1 on the router to include your other subnets you've defined on the switch.
I have change my access-list 1 to
access-list 1 permit any
Still no luck. Thank you very much for the help so far!
Add to your router:
ip route 192.168.0.0 255.255.248.0 192.168.1.254
-Matt
After adding the line you suggested. i get this error when I ping www.google.com
%unrecognized host or address, or protocol not running.
CSCO11780655
Million Thanks!
Finally, I got it working!
