Cisco 3560 configured trunk port staying in VLAN 1
jdavid6568
I am configuring a 3560 switch and configuring the port in trunking mode but when I do show interface status it keeps showing up in VLAN 1. I also tried to verify via the show in trunk command and it is not showing the port being trunked. Below is the port configuration and the output of each show command. Interfaces Gi0/19 and Gi0/20 are the ones in question. Any ideas on how to fix this?
interface GigabitEthernet0/19
description phlphoef2 gi0/1
switchport trunk allowed vlan 30
switchport mode trunk
speed 100
duplex full
interface GigabitEthernet0/20
description phlphoef2 gi0/2
switchport trunk allowed vlan 50,60
speed 100
duplex full
phlphoes9#show int status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/19    phlphoef2 gi0/1    notconnect   1            full    100 10/100/1000BaseTX
Gi0/20    phlphoef2 gi0/2    notconnect   1            full    100 10/100/1000BaseTX
phlphoes9#show int trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi0/10      on           802.1q         trunking      1
Gi0/11      on           802.1q         trunking      1
Gi0/12      on           802.1q         trunking      1
Gi0/13      on           802.1q         trunking      1
Gi0/14      on           802.1q         trunking      1
Gi0/15      on           802.1q         trunking      1
Gi0/16      on           802.1q         trunking      1
Gi0/17      on           802.1q         trunking      1
Gi0/23      on           802.1q         trunking      1
2 Accepted Solutions
IAN WHITMORE
Level 4
Level 4
This is normal. One because it's not trunking (i.e. the interface isn't up), no vlan is being negotiated.
Also, VLAN 1 is the native VLAN and is also enabled by default. You can change this though if you wish, but you must change it on both ends of the trunk.
HTH,
Ian
Edwin Summers
Level 3
Level 3
Looks like Ian pretty much covered it, so I just wanted to ask if you had connected the interfaces to another device yet as they are showing "not connected".  Ensure the interfaces on the far side (if connected) are not shutdown.
5 Replies 5
IAN WHITMORE
Level 4
Level 4
HTH,
Ian
Edwin Summers
Level 3
Level 3
Thank you both. This is just prep work for a new firewall migration. So the interfaces are not connected to anything until Saturday. I was under the impression that once you configured the trunk and allowed the vlans that it was a static configuration. But what both of you answered makes perfect sense. Thanks again for the clarification.
No worries. Can you mark the post as solved.
thanks,
Ian
I was facing the same situation on Cisco Catalyst 3850, but I came to know this is normal behavior, when you configured a port as a "Trunk Port"and it is down then it will reflect under a native Vlan ports and as soon you turn it on it will be removed from Vlan ports.
