Cisco 3560 IOS recommendation
Tupe_kunal
I have a Cisco WS-C3560G-48PS switch with IOS c3560-ipbase-mz.122-35.SE5.
I need to upgrade it to a newer version to fix bug issues.
I am confused to which IOS should i upgrade it to so that the switch remains stable.
Please suggest.
Best Regards,
Kunal Tupe
2 Accepted Solutions
For best stability, I would use the 12.2(55)SE9. For some more features you could also use 15.0(2)SE7. The 15.0 release is not that respected for stability, but I still would say that it's already very stable.
julijime
Hi Tupe_kunal,
A good option for your platform would be Release 12.2.55-SE9 which is the Cisco suggested release based on the software quality and stability, please take a look at the following link for further information:
https://software.cisco.com/download/release.html?mdfid=279486491&flowid=2537&softwareid=280805680&release=12.2.55-SE9&relind=AVAILABLE&rellifecycle=MD&reltype=latest
However you should take into account that if you need to fix an specific bug, you might need to take a look first in the Release Notes of the version in order to confirm that the fix you're looking for is in there.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/release/notes/OL23054.html
HTH,
Julio
5 Replies 5
Hi All,
Yes, 12.2(55)SE9 version is stable so far. I upgraded the switch to the recommended version.
Will observe it for a few days.
Thanks to everyone of you..... Cheers!!!
Best Regards,
Kunal Tupe
julijime
Hi Tupe_kunal,
HTH,
Julio
acampbell
Kunal,
I would go with 12.2.55(SE9).
This train this been very stable for me and it is also
a "suggested" verion on CCO
Alex
Regards, Alex. Please rate useful posts.
Leo Laohoo
12.2(55)SE9.  You can't find any stable IOS for the 3560/3750 than this one.
It's a shame Cisco won't be developing/improving this version:  End-of-Sale and End-of-Life Announcement for the Cisco IOS Software Release 12.2(55)SE for Cisco Catalyst 3750-X, 3750-E, 3750G, 3750V2, 3560-X, 3560-E, 3560-C, 3560G, 3560V2, 2960-S, 2960-C, and 2960 Series Switches
