Bookmark
Subscribe
38263
Cisco 3560 L2 or L3?
Hieu Cao
Level 4
Level 4
Is there a simple way to really verify that the cisco 3560 is a layer 2 or layer 3 switch? or is it actually dependent upon the ios image that it's running?
Switch model number is WS-C3560-48PS-S
Thanks.
2 Accepted Solutions
Marwan ALshawi
3560 is L2/L3 switch
if you do not enable ip routing the switch will operate as L2
switch
use this command to make it L3
ip routing
to make only L2
no ip routing
good luck
if helpful rate
jonesm111
I would try and setup 2 gateways, connect 2 hosts and see if they can ping eachother;
example:
Int vlan 100
ip adress 10.10.10.1 255.255.255.0
no shut
conf t
int gi 0/1
switchport mode access
switchport access vlan 100
no shut
connect host 1 to gi 0/1
repeat for 2nd host
9 Replies 9
Marwan ALshawi
switch
ip routing
to make only L2
no ip routing
good luck
if helpful rate
Thank you!
i am trying to configure 2 vlan with different network
vlan10 - 192.168.10.1/24
vlan50 - 192.168.50.1/24
port assigned to vlan10 is fa0/1-4 and fa0/5-8 for vlan50
client ips are
192.168.10.11-14 /24 for vlan10 with gateway 192.168.10.1
192.168.50.11-14 /24 for vlan 50 with gateway 192.168.50.1
however they cant reach each other, i am trying Layer3 switching and i am did the ip routing as what you advise but did not work..
please advise if i did wrong.. thanks and advance.!!
Have you try with interface VLAN ?
(Config)#Int VLAn 10
            #ip address 192.168.10.1 255.255.255.0
(Config)#Int VLAn 50
            #ip address 192.168.50.1 255.255.255.0
Please try this and let me know if its working or not
Hi Roy,
Do you have a solution for this case?
I have this case too and am still searching and learning to solve it
thanks for your help
also please advise which iOS which be the best to install on Catalyst 3560series PoE 48 so as to get all features available from hardware , atm i have c3560-ipbase-mz.122-25.SEE3.bin
jonesm111
example:
Int vlan 100
no shut
conf t
int gi 0/1
no shut
repeat for 2nd host
Thank you!
daakon
 I have c3560cx-12pd-s and i am not able to reach a host on the second vlan(20). I can ping to vlan 10, vlan 20, but the host in vlan 20 is unreachable for me. Can anybody advice me please? Is it necessary to use two switches or I am able to rout on this switch(c3560cx)?
