Cisco 3560 not reloading
i have cisco 3560 switch which while reloading stuck in the below line
Xmodel File system is available
"the password-recovery mechanism is enabled"
i have manually load the IOS everything i reboot i have to go to ROMMON mode and boot from flash:
this is happening after i upgraded the IOS from 12.2(35) to 12.2(58)...it boots perfectly if i do i manually ...then after reload it just stuck in the above mentioned place i also downgraded the IOS but still the same issue...can any one help
Leo Laohoo
Do the reboot again.  Post everything from the time of the reload all the way until the switch gets "stuck".  Sounds like one of the component has failed the POST.
9 Replies 9
dasiimwe
Do a 'show ver'  and confirm the config register is set to 0xf
If not make sure its set to 0xf or 0x2102
Leo Laohoo
after i do the reload all i see is
i dont see anything else...then i have to reload again and press the mode button break to ROMMON and from switch: prompt i give the boot flash: command...please let me know if i can do something else
p.mcgowan
Level 3
Level 3
once you have manually booted up the switch do "show bootvar" and "show flash" make sure the value in the bootvar is thwe exact same as the image on the flash, if there is a mismatch this could explain why the image does not automatically boot
the values actually match..any other suggestions
smogra
Check the following:
1. Config register value should be set to 0x2102 or 0xf.
2. Boot variable should have the correct path of the image.
3. Image should be compatible with the hardware.
Cheers
Sweta
P.s.please rate the answer if it helped.
1. config register is 0xf
2 boot variable is having correct path of the image
3. image is compatiable i have several other switches of the same model got installed with new IOS
I would recommend that you delete the new image from the switch. Copy it again, set the boot variable one more time and try reloading after that.
Also, please make sure that image is properly copied and the boot variable is set properly.
It should help.
Otherwise I would suggest that you open a case with TAC then.
Hope that helps.
Sweta
*please rate the content if it helped you.
