Cisco 3560 switch password issue.
hernjalukund
hi,
Pls help..
I have created 2 login password. But i forget my 1 login password. How can i see that hide password.
eg:
username Prakash privilege 15 secret 5 $1$4ZUc$aSKhlnuncChdhi7H2lCnj.
username Cisco privilege 15 secret 5 $1$4ZUc$aSKhlnuncChdhi7H2lCnj.
 i know the Prakash user name & password but  i forget Cisco user name login password... how can i see secret 5 $1$4ZUc$aSKhlnuncChdhi7H2lCnj. hide password. ?????
And also how can i see console passowrd..
line con 0
password 7 047A0F0B5E2F6C4D5917
login
8 Replies 8
Philip D'Ath
You can't easily.  If you have a lot of time you could try:
http://www.ifm.net.nz/cookbooks/cisco-ios-enable-secret-password-cracker.html
You are better offing logging in as Prakash and resetting the Cisco password.
thanks sir,
How can i reset factory default switch ....???
following commands in privilege mode should do it:
delete flash:vlan.dat
write erase
reload
Thank you sir
Julio E. Moisa
You cannot decrypt the password just replace it.
As Philip mentioned, you can decrypt it using third party softwares/applications or links
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
third party softwares/applications means???
give me any link....
You could use the link mentioned by Philip, third party means that they are created by other companies, below you will find other link:
http://packetlife.net/toolbox/type7/
Hope it is useful
thanks sir
