Cisco 3560 switch - static route entry
myounger
I have a 3560 switch (ip routing is NOT turned on) that has a route entry for a particular host? This switch is not acting as a router. How do I remove the entry (trying to avoid a switch reboot)?  This route was auto generated and is not listed in the config.
myounger
Figured it out.....
The route was created by a ICMP redirect.
show ip redirect (shows the entry)
CLEAR IP REDIRECT - removes the ICMP redirect from the table.
