Cisco 3560CX How to copy a config.text to my PC ,USB not work.
quinterc1
I cant transfer this configuration file to my PC from the Flash of the 3560cx 8port switch. The USBflash0 is not work in the switch.
witch: copy flash: xmodem:
flash:: no such file or directory
switch: dir
ERR: usbd_bulk_transfer fail status 32
ERR: Read ERROR start 0 blks 1
usbflash0: contains unexpected values in partition table or boot sector.
Device needs formatting before use!
List of filesystems currently registered:
bs[1]: (read-only)
flash[9]: (read-write)
xmodem[10]: (read-only)
null[11]: (read-write)
usbflash0[13]: (read-write)
switch: dir usbflash0:
unable to stat usbflash0:/: unknown error
switch:
8 Replies 8
balaji.bandi
check this URL :
start with :
switch: flash_init
switch: set
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
Make sure USB 4 or 8GB FAT 16 format.
BB
BB,
The usb pen drive is format in FAT16 (2Gb), still with the same problem !
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: dir
ERR: usbd_bulk_transfer fail status 8
bs[1]: (read-only)
@balaji.bandi Just out of curiosity, and since there seem to be different 'opinions': where did you get that information (>4GB) ?
I seem to recall that it has to be LESS than 4GB.
Not sure if i could get the information correctly - 4GB and 8GB work and are available in the market?
or you looking for cisco documentation?
BB
marce1000
            - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuj31969
 M.
make sure you are using an USB stick no larger than 2GB, formatted with FAT 16 and a cluster allocation size of 16 or 32K (not 64)...
My friend,
USB drive is 2Gb format in FAT16.
And the cluster allocation size, is that 16K ?
