04-08-2011 08:59 AM - edited 03-06-2019 04:31 PM
Dear All,
I need to configure VLANS on my cisco 3560E, I wish to have more that 3 VLAN which cannot access each other and one VLAN that can access all VLAN, Please assist.
Thank you
04-08-2011 09:10 AM
Are you planning to do the routing between VLANs on the 3560E or with a different devices? If you want to do the InterVLAN routing on the 3560 the you just neeed to configure the Interface VLANs for each segment and then configure Access Lists to restrict traffic.
04-08-2011 09:34 AM
That's what I want to do. Please provide any sample configurations or a detailed manual.
Thank you.
04-08-2011 09:43 AM
The following guide describes how to enable Intervlan Routing on the switch:
And this one describes how to configure access list:
It is improtant that you defined first the IP asigment of the VLANs and exactly what traffic you want to restrict or allow....
04-08-2011 09:56 AM
I do not have access to those links. Can you send as files please.
04-08-2011 10:22 AM
This is one way of doing it.
ok first we setup the physical ports for VLAN
int gig1/0/1
switchport mode access
switchport access vlan10
int gig1/0/2
switchport access vlan20
int gig1/0/3
switchport access vlan30
no we set the access-lists so we have them ready for when we add them
the access-list will allow the local lan to speak to 10.10.30.0/24 network.
ip access-list extended vlan10
permit ip 10.10.10.0 0.0.0.255 10.10.30.0 0.0.0.255
deny ip any any
the last line is almost redundant but i like to be able to se how many hits it have had and/or log those hits.
ip access-list extended vlan20
permit ip 10.10.20.0 0.0.0.255 10.10.30.0 0.0.0.255
deny ip any any
int vlan10
no shut
ip address 10.10.10.254 255.255.255.0
ip access-group vlan10 in
int vlan 20
no shut
ip address 10.10.20.254 255.255.255.0
ip access-group vlan20 in
04-09-2011 08:06 AM
NB: VLAN4 is supposed to access VLAN3 and VLAN2. VLAN2 and VLAN3 should not access VLAN4.
I have tried the configs but it's not working. The access-list seems not to work. I have pasted my configurations below( my router detailsCisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(50)SE,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Feb-09 02:53 by weiliu
Image text-base: 0x00003000, data-base: 0x02400000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3))
interface GigabitEthernet0/1
no switchport
no ip address
interface GigabitEthernet0/2
switchport access vlan 4
interface GigabitEthernet0/3
switchport access vlan 3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.16.1 255.255.255.240
ip access-group vlan2 in
interface Vlan3
ip address 192.168.32.1 255.255.255.240
interface Vlan4
ip address 192.168.48.2 255.255.255.240
ip classless
ip http server
ip http secure-server
permit ip 192.168.16.0 0.0.0.15 192.168.48.0 0.0.0.15
deny ip any any
ip access-list extended vlan3
permit ip 192.168.32.0 0.0.0.15 192.168.48.0 0.0.0.15
deny ip any any
04-09-2011 09:05 AM
Hi again
so how far have you come ?
Have you gotten the routing to work ?
Does the acess-lists work ?
if you want vlan 4 to be able to speak to vlan 2 and 3 but they should not be able to "speak back"
what do you mean by that ? and what protocols do you want to use ?
1) do you mean that any tcp session should be able to be initiated from vlan 4 and answers in that session should be able to respond from vlan3and2 back to vlan 4 ?
or
2) do you mean that no traffic whatsoever should be able to traverse from vlan3 and vlan2 to vlan4 ?
if you mean 2) then only oneway connection with udp such as fx syslog will be able to function in such an environment.
if you mean 1) this does not support 2 way communication with fx udp. if you want that then you need to use a firewall or a router that can do nat. the 3560 does not have that capability.
If you mean 1) and only use tcp (will not work with anything else than tcp) then you add a line for the response traffic from the vlans
permit tcp 192.168.16.0 0.0.0.15 192.168.48.0 0.0.0.15 established
to filter it down even more you can add source and destination ports.
good luck
