Cisco 3650 Crash After Removing WCCP configuration
randms2610
I'm using Cisco 3650 ios-xe 03.07.03E
After mistakenly remove WCCP on the global config without removing the redirection command on the interface level, I got the error "The WCCP service is now disabled but remains configured on at least one interface" and then a few seconds later the switch crash and restarted.
In my next attempt I had a typo (yeah, bad luck me) while trying to execute the "no ip wccp 0 redirect in" under interface level, what I typed was "no ip wccp 0 redirec tin", somehow the switch accepts it as I was executing "no ip wccp 0" on global config, I got the error "The WCCP service is now disabled but remains configured on at least one interface" again.... then it crash again and restarted.
A few days later, the switch suddenly restarts itself and always restarting every few hours and the reload reason always saying power failure, I have tried changing the power source and power module to make sure but it is still having the same behavior - it can't be a power failure because other devices plugged in on the same power source never experienced this issue - this made me think that the reload reason was invalid and I guess it is really an invalid reason as stated in Cisco Bug: CSCux58649 (https://supportforums.cisco.com/node/add/discussion?og_group_ref=6016)
This leads me to think that the switch is actually crashing every few hours - and wondering if the first few crashes is the trigger.
I'd like to know what can I check to confirm this, or some workaround before I'm opening case with TAC.
Please advise. Thanks.
Mark Elsen
 - First approach might be to upgrade (or sometimes downgrade) to a ios-xe gold-starred release for this platform.
M.
