Cisco 3650 Switch (WS-C3650-24TD-S) as a Layer 3
CSCO12094806
Hi, could you please help me to understand following,
can we use Cisco 3650 Switch (WS-C3650-24TD-S) as a Layer 3 device in addition with Layer 2, we need to configure following.
1. Inter-Vlan routng.
2. Static & Default routing.
Our Cisco Bill of Material are mentioned below.
Cisco Part Number             Description
WS-C3650-24TD-S          Cisco Catalyst 3650 24 Port Data 2x10G Uplink IP Base
CON-SNT-WSC365BU       SNTC-8X5XNBD Cisco Catalyst 3650 24 Port Data 2x10G U
S3650UK9-163                   UNIVERSAL
Deepak Kumar
The Switch "WS-C3650-24TD-S" is an IP base switch so basic L3 routing as static and dynamic (stub) routing is available by default.
For more feature you can visit at Datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet-c78-729449.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Thanks Deepak.
