Cisco 3750, add stack while running...
perpaal
Level 4
Level 4
Hi I have a Cisco 3750G-12SE running in my core. Now I need more than the 12 ports, and have got another 3750G-12SE, and stack cable. Can I create a stack, and add this new one as slave while the current one is running in production?
Leo Laohoo
Yes as long as the new stack member is powered OFF before attaching the stacking cable.
Leo Laohoo
Ok, tanks. But after connecting the cable, I power it on, and them add configuration for stack (there is no stack now, just a single 3750), or do I add configuration also before powering up the slave?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You can do either.  The latter is known as preprovisioning.
Agree with Joseph.  You can configure, aka pre-provisioning, before you add the stack member.  Personally, I'm a big user of pre-provisioning because people can start using the ports as soon as the new stack member boots up.
