Cisco 3750 etherchannel configuration
KAMAL MISHRA
I have cisco3750 switch i am trying to make ether channel on that switch below is the configuration i have done on same switch
interface GigabitEthernet1/0/23
switchport mode trunk
speed auto 10 100 1000
duplex full
channel-group 1 mode on
interface GigabitEthernet1/0/24
duplex full
spanning-tree bpdufilter enable
interface Port-channel1
kindly suggest that configuration is proper or any other configuration is required
second switch is nortel l2 switch, we are creating l2 etherchannel
4 Accepted Solutions
as far as I know Nortel supports LACP. you need to specify channel-protocol LACP. furthermore, port-channel and interface configs must be identical
yes. like
interface xxxx
channel-protocol lacp
kabuelenain
Hello Kamal,
Actually for the Ether-Channel to come up, the configuration on both physical interfaces have to be identical, not the configuration between the physical interfaces and the port-channels. As a matter of fact, you can have "some" configuration under the physical interfaces and the rest, under the port-channel.
Good practice is to place the minimum configuration under the physical interfaces to have them join the port-channel group, and once joined, place all other configurations under the port-channel.
Another good practice, if you have a multi-vendor environement, you better not use LACP. Although LACP is a standards based protocol, different vendors may have slightly different implementations for it. Better go for static ether channel, as you have in your original post.
when you configure speed auto, you do not need to specify 10, 100 and 1000. These options are only there if you want to limit the speed negotiation. By default all of them wil be attempted.
Having said that, please see below the steps:
config t
default interface Gig1/0/23
default interface Gig1/0/24
Then make sure the interfaces have joined the Ether-Channel by entering the command:
show etherchannel summary
Then enter the rest of the commands under the port channel:
duplex full
speed auto
kevincantor
Just an additional input, prior to configuration, it's best practice to shutdown the interfaces before the etherchannel configuration. I had an experience wherein the etherchannel won't work for some reason.
So in this case, shutdown gi 1/0/23 and 24 first, configure with etherchannel, then no shut.
9 Replies 9
Thanks emmanuel for ur prompt help so I need to put lacp protocol at my cisco switch.
yes. like
interface xxxx
Thanks a lot I will made these changes
kabuelenain
Hello Kamal,
config t
duplex full
speed auto
Hussein Omar
To configure LACP you have two config option
Option1
interface
Option2
interface
channel-group 1 mode active
Thanks ibrahim
Dear Ibrahim / Emmaunel,
so i need to create channel
or
and remove my old port channel
kevincantor
