Cisco 3750 -- %% Low on memory; try again later
nishant.nk
Today, one of our Cisco 3750 got unmanaged from NOC, we were able to ping the switch, also, traffic was flowing fine but not able to telnet or local login.
On trying to login through console following messages were coming:
004107: Oct  7 09:26:09.525: %SYS-2-MALLOCFAIL: Memory allocation of 4120 bytes failed from 0x9D2A08, alignment 0
Pool: Processor  Free: 10613572  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Spanning Tree", ipl= 0, pid= 197
-Traceback= D667B8 D66F04 1595DD4 15982F4 1598558 178821C 9D2A0C 86CCAC 14B336C 1490C1C 1490EE8 149109C 14918F8 1491C98 148D80C 14937A8
004108: Oct  7 09:26:51.443: %SYS-2-MALLOCFAIL: Memory allocation of 4120 bytes failed from 0x9D2A08, alignment 0
Pool: Processor  Free: 10613592  Cause: Memory fragmentation
We given power on reset, after which we were able to login switch again.
I wanted to know the actual reason behind it and if there is any other way to recover switch other than power reset.???
We are facing this issue every 2-3 days.
Nishant
17 Replies 17
Leo Laohoo
Yes.  Shove something up to the switch using SNMP.   You'll be able to regain access to the switch again.
Hi leo,
Can u explain this in detail ??
What command to send through SNMP to regain access to the switch again.
There's a third-party tool called Cisco SNMP Tool.  Use this to upload anything, a stupid and useless command (such as ntp server 1.2.3.4) up to your switch and see if you can gain access to the stack.
You should be able to gain control about 10-15 seconds after you start the upload.
