Cisco 3750 -- %% Low on memory; try again later
nishant.nk
Today, one of our Cisco 3750 got unmanaged from NOC, we were able to ping the switch, also, traffic was flowing fine but not able to telnet or local login.
On trying to login through console following messages were coming:
004107: Oct  7 09:26:09.525: %SYS-2-MALLOCFAIL: Memory allocation of 4120 bytes failed from 0x9D2A08, alignment 0
Pool: Processor  Free: 10613572  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Spanning Tree", ipl= 0, pid= 197
-Traceback= D667B8 D66F04 1595DD4 15982F4 1598558 178821C 9D2A0C 86CCAC 14B336C 1490C1C 1490EE8 149109C 14918F8 1491C98 148D80C 14937A8
004108: Oct  7 09:26:51.443: %SYS-2-MALLOCFAIL: Memory allocation of 4120 bytes failed from 0x9D2A08, alignment 0
Pool: Processor  Free: 10613592  Cause: Memory fragmentation
We given power on reset, after which we were able to login switch again.
I wanted to know the actual reason behind it and if there is any other way to recover switch other than power reset.???
We are facing this issue every 2-3 days.
Nishant
17 Replies 17
manju.cisco
Level 3
Level 3
Hi Nishant,
Not sure if i can be correct, but let me try. However please wait for experts advise.
The CPU was not able to get a chunk of memory allocated for a process to execute "Memory allocation of 4120 bytes failed", this means the CPU didnt get 4120 bytes of memory for the process
Could you please tell us:
1. Was there any recent IOS upgrade or config changes happened on your switch? [There may be a SW bug on the IOS if you have one upgraded]
2. What is the IOS you are running on the switch?
3. From how long you are facing this problem?
krahmani323
Level 3
Level 3
As Manju stated It could probably due to a software bug (as per the regular memory leaks the switch is experiencing)…
Depending on your version it could be due to CSCtf79423 (the analysis of the traceback from Cisco may confirm this fact)
============CSCtf79423 Bug Details - Memory Leak on STP process============
Symptom: 3750 Experience high memory leak for the STP process
Conditions:Symptoms observed on switch running 12.2(50)SE software
Workaround: Disable all the ports and bring it back up.Issue will reappear once the switch reloads.
1st Found-in: (1) 12.2(50)SE
Known Affected Versions: (47) => 12.2(54)SE,12.2(53)SE2,12.2(53)SE1,12.2(53)SE 12.2(52)SE1,12.2(52)SE,12.2(52)EX,12.2(50)SE4 and so on….
Anyway in this situation I would have upgraded (depending on the type of 3750 you have) to 12.2(55) or 12.2(58) before checking again.…
Regards.
Karim
   This seems to be an issue on some 3750's, have seen this myself .  When this starts really the only way you are going to be able to telnet in is to reload it like you did .
nkarpysh
Adding to what was said above.
It seems you are experiencing mamroy leak. Normally each process should take the memory from the pool and then release it when it is done. In some cases pasrticular process holding more and more memory and does not release it. That is called memory leak and that is usually a bug. That indeed lead to a lock condition or a natural crash in the end.
I would recomend to monitor "show proc mem sorted" to see which process continiously eating memory and does not releas it (you need to watch for number in "holding " columnt). You can do this command each hour and narrow down the suspected processes slowly.
You can paste outputs here as soone as you took those regularly for us to help to check.
P.S. Please also pasted "show ver".
Nik
HTH,
Niko
Thank you guys.
Sorry for late reply. Actually I again faced same issue with that switch and thats why I was not able to collect. Anyways after giving power reset again am able to login the switch.
We are using Stack of two 3750 switches and software version 12.2(50)SE2.
I also think that its a memory leak issue and planning to upgrade IOS as soon as possible.
switch3750MuzzMSC#sh version
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(50)SE2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 15-May-09 21:29 by nachen
Image text-base: 0x00003000, data-base: 0x01D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
switch3750MuzzMSC uptime is 13 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-50.SE2/c3750-ipservicesk9-mz.122-50.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision F0) with 118784K/12280K bytes of memory.
Processor board ID FOC1401W34B
Last reset from power-on
1 Virtual Ethernet interface
56 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 04:FE:7F:82:D4:80
Motherboard assembly number     : 73-10219-07
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC14021DL6
Power supply serial number      : DCA13509418
Model revision number           : F0
Motherboard revision number     : E0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC1401W34B
Top Assembly Part Number        : 800-26859-01
Top Assembly Revision Number    : E0
Version ID                      : V03
CLEI Code Number                : CNMWS00ARC
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS-1U  12.2(50)SE2           C3750-IPSERVICESK9-M
     2 30    WS-C3750E-24TD     12.2(50)SE2           C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 12 minutes
Base ethernet MAC Address       : 40:55:39:C1:8A:80
Motherboard assembly number     : 73-11177-14
Motherboard serial number       : FDO15131DFY
Model revision number           : G0
Motherboard revision number     : A0
Model number                    : WS-C3750E-24TD-SD
Daughterboard assembly number   : 800-29737-01
Daughterboard serial number     : FDO15120CWH
System serial number            : FDO1513Y07H
Top assembly part number        : 800-30991-04
Top assembly revision number    : B0
Version ID                      : V04
CLEI Code Number                : COMC600ARB
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
switch3750MuzzMSC#sh proc mem sorted
Processor Pool Total:   72289916 Used:   34084516 Free:   38205400
      I/O Pool Total:   12574720 Used:    8772428 Free:    3802292
Driver te Pool Total:    1048576 Used:         40 Free:    1048536
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   51138520   11087064   35262984          0          0 *Init*
   0   0   18388864   17221232    1091412   10549520    2283560 *Dead*
  59   0     849568     101160     597376       5856          0 Stack Mgr Notifi
181   0    1686216    9945564     437552       5076          0 VMATM Callback
156   0     294520      13520     294520          0          0 HL2MCM
155   0     294488      13520     294460          0          0 HL2MCM
246   0     421652   14806644     288492          0          0 MLDSN L2MCM
241   0     396296   15628580     266160          0          0 IGMPSN L2MCM
  15   0     230560          0     240612      99792          0 EEM ED Syslog
  14   0     186224     363356     164324          0      71240 Entity MIB API
284   0     146428          0     153480          0          0 EEM Server
  96   0    1208836     133396     118112          0          0 hpm main process
191   0     431256     119208      78488       6804          0 SpanTree Helper
159   0      71308          0      78360          0          0 Switch Backup In
145   0    5162040    5034184      78272      15228          0 HQM Stack Proces
  37   0     113936     152476      74136          0          0 IF-MGR control p
192   0    1280592     142844      70728     725868          0 HRPC hl2mcm igmp
168   0      93192      11116      68316          0          0 DTP Protocol
  35   0     268896       4732      66100          0          0 Per-Second Jobs
221   0    1830428    1575708      64564          0          0 HTTP CORE
  87   0     857192      85460      62744     492372          0 HRPC vlan reques
146   0    5343548    5343548      61052          0          0 HRPC qos request
111   0       2884      50212      61052          0          0 HACL Acl Manager
140   0          0          0      61052          0          0 HL3U PBR bkgrd p
  33   0      55872        180      60788      35532          0 Logger
   1   0     303596     266704      53292          0          0 Chunk Manager
251   0    1224708     142692      44180     690336          0 HRPC hl2mcm mlds
  77   0    4853896        180      41760          0          0 HLFM address lea
232   0      40180        180      38852          0          0 DHCPD Receive
  22   0      44100       1940      34616          0          0 IPC Seat Manager
276   0       8872          0      34000          0          0 LICENSE AGENT
  98   0     479132     470332      31468          0          0 HRPC pm request
283   2      29892      13820      29152          0          0 Virtual Exec
263   0      31336       1800      27208          0          0 crypto engine pr
  76   0    1026796     643776      27160     233496          0 HRPC hlfm reques
275   0     109492      88848      25560       2340          0 VLAN Manager
   8   0          0          0      25052          0          0 Crash writer
205   0   31252644      16508      22916       6804          0 Spanning Tree
190   0     163372      94740      22056          0          0 CDP Protocol
151   0      19224       3312      20312      10152          0 HRPC hrcli-event
196   0      14280       3636      19696          0          0 IP Input
279   1      53172      46912      19344          0          0 Virtual Exec
201   0       5440        180      18312          0          0 ADJ resolve proc
227   0      10224        180      17096          0          0 REP BPA/EPA Proc
274   0      66056     209316      16492          0          0 PM Callback
304   0      10056       1020      15964          0          0 SSH Event handle
285   0       9676        832      15896          0          0 EEM Policy Direc
264   0     532356     525900      15508          0          0 Crypto CA
  26   0       2888        764      15176          0          0 License IPC stat
303   0       3724          0      13776          0          0 EEM ED RPC
289   0       3724          0      13776          0          0 EEM ED Interface
300   0       3724          0      13776          0          0 EEM ED Env
299   0       3724          0      13776          0          0 EEM ED Config
290   0       3724          0      13776          0          0 EEM ED IOSWD
297   0       3724          0      13776          0          0 EEM ED Timer
287   0       3724          0      13776          0          0 EEM ED Counter
286   0       3724          0      13776          0          0 EEM ED CLI
293   0       3724          0      13776          0          0 EEM ED POWERNET
295   0       3724          0      13776          0          0 EEM ED SNMP
291   0       3724          0      13776          0          0 EEM ED None
292   0       3724          0      13776          0          0 EEM ED OIR
288   0       3724          0      13776          0          0 EM ED GOLD
298   0       3724          0      13776          0          0 EEM ED Test
296   0       3724          0      13776          0          0 EEM ED Snmp_Prox
   0   0      13652    1056712      13652          0          0 *Sched*
  31   0      14512          0      13460          0          0 Net Background
195   0        396        180      13268          0          0 CEF switching ba
209   0        396        180      13268          0          0 CEF background p
217   0       7492        180      13260          0          0 MDFS LC Process
218   0         76       1212      13128          0          0 TCP Timer
  72   0          0          0      13108          0          0 HIPC bkgrd proce
305   0       1008        408      13104          0          0 hulc cfg mgr mas
  58   0          0          0      13052          0          0 Stack Mgr
208   0        180        180      13052          0          0 KRB5 AAA
200   0        180        180      13052          0          0 MDFS MFIB Proces
282   0      26268      26268      13052          0          0 Syslog
219   0     112316          0      13052          0          0 TCP Protocols
  13   0          0          0      13052          0          0 Policy Manager
104   0          0          0      13052          0          0 HCEF ADJ Refresh
  29   0        180        180      13052          0          0 XML Proxy Client
  27   0          0          0      13052          0          0 License IPC serv
  32   0          0          0      13052          0          0 IDB Work
  80   0          0          0      13052          0          0 HRPC hrcmd reque
138   0       1140          0      13052          0          0 HL3U bkgrd proce
  84   0          0          0      13052          0          0 HVLAN main bkgrd
  63   0       5556        180      12472          0          0 Fifo Error Detec
  74   0      35092      20676      12356       5076          0 Hulc Port-Securi
118   0     202748     167532      12356       5076          0 HULC DOT1X Proce
107   0      17140      12096      12096          0          0 hl3mm
268   0       4832       9212      11704          0          0 VTP Trap Process
212   0       5468        852      11668          0          0 XDR mcast
  65   0       3660    3166528      10712        780    2020248 hrpc -> response
149   0      18408       6504      10492          0          0 HRPC system post
252   0        216          0      10268          0          0 IP RIB Update
  34   0        180       2832      10052          0       1692 TTY Background
153   0        180        180      10052          0          0 image mgr
178   0        180        180      10052          0          0 IP Host Track Pr
207   0        180        180      10052          0          0 EAPoUDP Process
237   0          0          0      10052          0          0 IPe DM Backgroun
236   0          0          0      10052          0          0 IPe DM Main
210   0          0          0      10052          0          0 IP IRDP
137   0    1417140        180      10052          0          0 Hulc LED Process
198   0        180        180      10052          0          0 IP ARP Track
278   0          0          0      10052          0          0 Licensing MIB pr
306   0     439796     439304      10028          0          0 crypto sw pk pro
203   0      28532      25880       9704          0          0 powernet proxy u
245   0       2824        180       9696          0          0 L2TRACE SERVER
260   0       2232        316       9112          0          0 OBFL Cfg Dispatc
266   0          0          0       9052          0          0 Crypto SSL
265   0          0          0       9052          0          0 Crypto PKI-CRL
261   0       2060        180       8932          0          0 TPLUS
  54   0       1544          0       8596          0          0 Hulc EEM Process
224   0       4036       3288       7800          0          0 Cluster Base
161   0       2240        452       7764          0          0 Auth Manager
176   0      11372      10820       7604          0          0 UDLD
120   0        472        180       7344          0          0 Hulc Foxhound Pr
255   0        216          0       7324          0          0 DHCPD Database
230   0        396        180       7268          0          0 Dot1x Supplicant
177   0        216          0       7268          0          0 Port-Security
183   0        216          0       7268          0          0 IPe BSSM Manager
231   0        396        180       7268          0          0 Dot1x Supplicant
229   0        396        180       7268          0          0 Dot1x Supplicant
   9   0        392        620       7196          0          0 ARP Input
  91   0       2552        680       7168          0          0 HCMP sync proces
   4   0          0          0       7104          0          0 Check heaps
   3   0          0          0       7104          0          0 MDFS LC Download
  56   0          0          0       7100          0          0 HRPC asic-stats
  95   0    9453716    3853300       7096          0          0 SpanTree Flush
152   0          0          0       7092          0          0 DHCPD Timer
204   0          0          0       7084          0          0 DiagCard2/-1
307   0          0          0       7080          0          0 hulc running con
187   0          0          0       7064          0          0 AAA System Acct
132   0          0          0       7060          0          0 HRPC iec_load_ba
130   0          0          0       7052          0          0 HRPC vqpc reques
131   0          0          0       7052          0          0 BCM cable diags
133   0          0          0       7052          0          0 HRPC l2pt qnq rp
134   0          0          0       7052          0          0 HRPC IPe request
135   0          0          0       7052          0          0 HRPC aim request
136   0       2472       2472       7052          0          0 HRPC hled reques
129   0        136        136       7052          0          0 HRPC hudld reque
  86   0        180        180       7052          0          0 Vlan shutdown Pr
139   0      20956      20956       7052          0          0 HRPC hl3u reques
  85   0        180        180       7052          0          0 HVLAN Mapped Vla
141   0          0          0       7052          0          0 HL3U PBR n-h res
142   0          0          0       7052          0          0 HRPC dtp request
143   0          0          0       7052          0          0 HRPC show_forwar
144   0          0          0       7052          0          0 HRPC snmp reques
128   0        180        180       7052          0          0 S/W Bridge Proce
  82   0        148        148       7052          0          0 HRPC hulc misc r
147   0          0          0       7052          0          0 HRPC span reques
148   0          0          0       7052          0          0 HRPC obfl reques
  81   0        728        728       7052          0          0 HRPC emac reques
150   0       3992       1964       7052          0          0 Hulc Reload Mana
  79   0        180        180       7052          0          0 HLFM address ret
127   0          0          0       7052          0          0 HRPC stp_state_s
  78   0        180        180       7052          0          0 HLFM aging proce
154   0        180        180       7052          0          0 Power RPS Proces
  75   0       1904       1904       7052          0          0 HRPC hpsecure re
157   0        180        180       7052          0          0 PI MATM Aging Pr
158   0        180        180       7052          0          0 REP Topology cha
  71   0        352        352       7052          0          0 HRPC hdm blockin
126   0          0          0       7052          0          0 HRPC stp_cli req
115   0          0          0       7052          0          0 HRPC lldp reques
125   0        180        180       7052          0          0 HSTP Sync Proces
163   0          0          0       7052          0          0 MAB Framework
164   0          0          0       7052          0          0 AUTH POLICY Fram
165   0          0      33504       7052          0          0 802.1x switch
166   0        180        180       7052          0          0 802.1x MDA Aging
167   0          0          0       7052          0          0 802.1x Webauth F
  70   0       4912       4636       7052          0          0 HRPC hdm non blo
114   0          0          0       7052          0          0 HRPC cdp request
170   0          0          0       7052          0          0 EAP Test
124   0        180        180       7052          0          0 Hulc Storm Contr
123   0          0          0       7052          0          0 HRPC sdm request
122   0        180        180       7052          0          0 REP Helper Proc
121   0       1652       1652       7052          0          0 HRPC rep request
175   0          0          0       7052          0          0 HULC IP Source g
112   0          0          0       7052          0          0 HRPC backup inte
116   0          0       2176       7052          0          0 HULC CISP Proces
103   0          0          0       7052          0          0 HRPC hcmp reques
179   0          0          0       7052          0          0 Link State Group
  89   0          0          0       7052          0          0 HRPC isis reques
119   0          0          0       7052          0          0 HRPC foxhound re
182   0          0          0       7052          0          0 UNCLIP Process
  88   0          0          0       7052          0          0 HULC VLAN REF Ba
110   0          0          0       7052          0          0 HRPC acl request
185   0          0          0       7052          0          0 AAA ACCT Proc
186   0          0          0       7052          0          0 ACCT Periodic Pr
  73   0          0          0       7052          0          0 RTTYS Process
188   0          0          0       7052          0          0 Auth-proxy AAA B
189   0          0          0       7052          0          0 IP Admin SM Proc
  68   0         68         68       7052          0          0 HRPC hcomp reque
  67   0    1058224    7224396       7052          0      27072 hrpc <- response
  66   0          0          0       7052          0          0 hrpc -> request
193   0        204        204       7052          0          0 AAA Dictionary R
194   0          0          0       7052          0          0 DHCP Snooping
160   0          0          0       7052          0          0 MMN bkgrd proces
  62   0        488        180       7052          0          0 HULC Thermal Pro
197   0          0          0       7052          0          0 ICMP event handl
102   0          0          0       7052          0          0 hpm vp events ca
199   0          0          0       7052          0          0 IPv6 Echo event
  61   0     104996     209796       7052          0          0 RedEarth Rx Mana
101   0     881496     881496       7052          0          0 HRPC pm-counters
202   0          0          0       7052          0          0 powernet proxy t
100   0     252508     101048       7052          0          0 hpm counter proc
117   0      12100       7148       7052          0          0 HRPC dot1x reque
109   0          0          0       7052          0          0 HACL Queue Proce
206   0          0          0       7052          0          0 Spanning Tree St
162   0        180        180       7052          0          0 Dot1x Mgr Proces
173   0          0          0       7052          0          0 HRPC ip device t
  55   0          0          0       7052          0          0 Hulc LED Alchemy
  92   0       2440       2440       7052          0          0 HRPC ilp request
211   0          0          0       7052          0          0 CEF RF HULC Conv
108   0          0          0       7052          0          0 hl3mm_rp
213   0       7456          0       7052          0          0 IPC LC Message H
214   0          0          0       7052          0          0 XDR RP Ping Back
215   0        396        396       7052          0          0 XDR RP backgroun
216   0          0          0       7052          0          0 XDR RP Test Back
  53   0       8120       7844       7052          0          0 Platform-IPe Pro
  52   0        180        180       7052          0          0 MIRAGE RBCP Moni
  51   0          0          0       7052          0          0 Hulc Warm Upgrad
220   0          0          0       7052          0          0 Socket Timers
  50   0       2884       2252       7052          0          0 HULC multifs pro
222   0        180        180       7052          0          0 Cluster L2
223   0          0          0       7052          0          0 Cluster RARP
  90   0        512        212       7052          0          0 HRPC hfbm reques
225   0          0          0       7052          0          0 RARP Input
226   0        180        180       7052          0          0 REP LSL Proc
  49   0          0          0       7052          0          0 HRPC Multi-FS Sy
228   0          0          0       7052          0          0 Critical Auth
174   0          0          0       7052          0          0 HRPC ip source g
169   0          0          0       7052          0          0 EAP Framework
171   0          0          0       7052          0          0 HRPC dai request
  48   0        180        180       7052          0          0 HLPIP Sync Proce
233   0        180        180       7052          0          0 IPe BS
234   0        180        180       7052          0          0 IPe P2P
105   0          0          0       7052          0          0 HRPC hl3mm reque
  97   0     102900      88140       7052          0          0 HPM Stack Sync P
  93   0          0          0       7052          0          0 HULC PM Vector P
238   0          0          0       7052          0          0 IPe Host
239   0          0          0       7052          0          0 HRPC dhcp snoopi
240   0       1304        680       7052          0          0 HULC DHCP Snoopi
  47   0          0          0       7052          0          0 HRPC lpip reques
242   0          0          0       7052          0          0 IGMPSN MRD
243   0          0          0       7052          0          0 IGMPSN
244   0          0          0       7052          0          0 IGMPQR
  69   0        732        180       7052          0          0 HULC Device Mana
  46   0          0          0       7052          0          0 HRPC hdwl reques
247   0          0          0       7052          0          0 MRD
248   0          0          0       7052          0          0 MLD_SNOOP
249   0          0          0       7052          0          0 HRPC hwccp reque
250   0          0          0       7052          0          0 HULC_WCCP_BACKGR
  45   0        180        180       7052          0          0 DownWhenLooped
  44   0          0          0       7052          0          0 HULC ASP Process
253   0          0          0       7052          0          0 HRPC x_setup req
254   0     628208          0       7052          0          0 MDFS RP process
184   0        180        180       7052          0          0 AAA Server
256   0          0          0       7052          0          0 EPM MAIN PROCESS
257   0        180        180       7052          0          0 LOCAL AAA
258   0        180        180       7052          0          0 ENABLE AAA
259   0        180        180       7052          0          0 LINE AAA
  94   0          0          0       7052          0          0 HPM Msg Retry Pr
180   0        180        180       7052          0          0 Ethchnl
262   0        180        180       7052          0          0 REP Switch Helpe
  43   0          0          0       7052          0          0 SFF8472
  42   0          0          0       7052          0          0 HC Counter Timer
  60   0    1639500    3059520       7052          0          0 RedEarth Tx Mana
  23   0          0          0       7052          0          0 IPC Session Serv
267   0          0          0       7052          0          0 encrypt proc
  41   0          0        576       7052          0          0 Transport Port A
269   0        180        180       7052          0          0 VTPMIB EDIT BUFF
270   0        180        180       7052          0          0 DHCP Security He
271   0          0          0       7052          0          0 HCD Process
272   0          0          0       7052          0          0 HRPC cable diagn
273   0        108        324       7052          0          0 DiagCard1/-1
  40   0        180        180       7052          0          0 Compute load avg
  39   0          0          0       7052          0          0 AggMgr Process
  38   0          0          0       7052          0          0 IF-MGR event pro
277   0        180        180       7052          0          0 dhcp snooping sw
  30   0          0          0       7052          0          0 Critical Bkgnd
  36   0          0          0       7052          0          0 Per-minute Jobs
280   0        180        180       7052          0          0 AAA SEND STOP EV
281   0          0          0       7052          0          0 Syslog Traps
  19   0          0          0       7052          0          0 IPC Periodic Tim
  28   0        180        180       7052          0          0 GraphIt
  25   0          0          0       7052          0          0 ARP Snoop
  24   0          0          0       7052          0          0 Dynamic ARP Insp
   5   0          0       7956       7052          0       5076 Pool Manager
  21   0          0          0       7052          0          0 IPC Deferred Por
  20   0          0          0       7052          0          0 IPC Managed Time
  17   0          0          0       7052          0          0 IPC Dynamic Cach
  18   0          0          0       7052          0          0 IPC Zone Manager
  11   0          0          0       7052          0          0 AAA_SERVER_DEADT
  16   0          0          0       7052          0          0 IFS Agent Manage
  12   0        180        180       7052          0          0 AAA high-capacit
  10   0          0          0       7052          0          0 CEF MIB API
   7   0          0          0       7052          0          0 Net Input
   6   0        180        180       7052          0          0 Timers
  57   0          0          0       4108          0          0 HRPC hsm request
  64   0        576        576       4052          0          0 Adjust Regions
235   0        180        180       4052          0          0 IPe BS SAF
301   0        180        180       4052          0          0 STP FAST TRANSIT
302   0        180        180       4052          0          0 CSRT RAPID TRANS
172   0          0          0       4052          0          0 HULC DAI Process
  83   0        192        192       4052          0          0 HRPC system mtu
   2   0        180        180       4052          0          0 Load Meter
106   0          0          0       4052          0          0 hl3md_rpfq_thrl_
  99   0       8340       7804       4052          0          0 HPM if_num mappi
                                 42844064 Total
181   0    1688264    9977900     437552       5076          0 VMATM Callback
246   0     421652   15662720     288492          0          0 MLDSN L2MCM
241   0     396296   16484444     266160          0          0 IGMPSN L2MCM
  35   0     270520       4732      66100          0          0 Per-Second Jobs
  77   0    4870280        180      41760          0          0 HLFM address lea
283   2      40196      24124      29152          0          0 Virtual Exec
  76   0    1033036     650016      27160     233496          0 HRPC hlfm reques
205   0   32977604      16508      22916       6804          0 Spanning Tree
137   0    1424268        180      10052          0          0 Hulc LED Process
203   0      28728      26076       9704          0          0 powernet proxy u
  95   0    9486052    3866320       7096          0          0 SpanTree Flush
139   0      21160      21160       7052          0          0 HRPC hl3u reques
  67   0    1061484    7249184       7052          0      27072 hrpc <- response
  61   0     105536     210876       7052          0          0 RedEarth Rx Mana
100   0     255700     102272       7052          0          0 hpm counter proc
  60   0    1647716    3074820       7052          0          0 RedEarth Tx Mana
                                 42844064 Total
181   0    1690376   10010460     437552       5076          0 VMATM Callback
  35   0     271400       4732      66100          0          0 Per-Second Jobs
146   0    5364824    5364824      61052          0          0 HRPC qos request
  77   0    4882772        180      41760          0          0 HLFM address lea
283   2      50500      34428      29152          0          0 Virtual Exec
  76   0    1033372     650352      27160     233496          0 HRPC hlfm reques
205   0   32990624      16508      22916       6804          0 Spanning Tree
137   0    1426852        180      10052          0          0 Hulc LED Process
  95   0    9518612    3879340       7096          0          0 SpanTree Flush
  67   0    1063372    7266240       7052          0      27072 hrpc <- response
  61   0     105808     211472       7052          0          0 RedEarth Rx Mana
101   0     895488     895488       7052          0          0 HRPC pm-counters
  60   0    1651408    3081088       7052          0          0 RedEarth Tx Mana
                                 42844064 Total
181   0    1692528   10043036     437552       5076          0 VMATM Callback
145   0    5200540    5072356      78272      15228          0 HQM Stack Proces
  35   0     271536       4732      66100          0          0 Per-Second Jobs
146   0    5384692    5384692      61052          0          0 HRPC qos request
  77   0    4889024        180      41760          0          0 HLFM address lea
283   2      60804      44732      29152          0          0 Virtual Exec
  76   0    1034600     651580      27160     233496          0 HRPC hlfm reques
205   0   33003644      16508      22916       6804          0 Spanning Tree
137   0    1428536        180      10052          0          0 Hulc LED Process
203   0      28924      26272       9704          0          0 powernet proxy u
  95   0    9551188    3892360       7096          0          0 SpanTree Flush
  67   0    1064472    7276072       7052          0      27072 hrpc <- response
  61   0     105944     211796       7052          0          0 RedEarth Rx Mana
  60   0    1653532    3084844       7052          0          0 RedEarth Tx Mana
                                 42844064 Total
  35   0     271672       4732      66100          0          0 Per-Second Jobs
  77   0    4893560        180      41760          0          0 HLFM address lea
283   2      71108      55036      29152          0          0 Virtual Exec
  76   0    1036316     653296      27160     233496          0 HRPC hlfm reques
137   0    1430032        180      10052          0          0 Hulc LED Process
  67   0    1065016    7281152       7052          0      27072 hrpc <- response
  61   0     106080     212068       7052          0          0 RedEarth Rx Mana
  60   0    1655344    3088152       7052          0          0 RedEarth Tx Mana
                                 42844064 Total
   0   0   18388864   17221436    1091412   10549520    2283560 *Dead*
181   0    1694744   10075612     437552       5076          0 VMATM Callback
  35   0     271808       4732      66100          0          0 Per-Second Jobs
  77   0    4904384        180      41760          0          0 HLFM address lea
283   2      81412      65340      29152          0          0 Virtual Exec
  76   0    1037472     654452      27160     233496          0 HRPC hlfm reques
205   0   33016664      16508      22916       6804          0 Spanning Tree
   0   0      13652    1063812      13652          0          0 *Sched*
137   0    1431936        180      10052          0          0 Hulc LED Process
  95   0    9583764    3905380       7096          0          0 SpanTree Flush
139   0      21364      21364       7052          0          0 HRPC hl3u reques
  67   0    1066580    7295756       7052          0      27072 hrpc <- response
  61   0     106216     212340       7052          0          0 RedEarth Rx Mana
254   0     635512          0       7052          0          0 MDFS RP process
  60   0    1657564    3092276       7052          0          0 RedEarth Tx Mana
                                 42844064 Total
Processor Pool Total:   72289916 Used:   34084460 Free:   38205456
  35   0     271944       4732      66100          0          0 Per-Second Jobs
  77   0    4907780        180      41760          0          0 HLFM address lea
283   2      91716      75644      29152          0          0 Virtual Exec
  76   0    1037776     654756      27160     233496          0 HRPC hlfm reques
137   0    1433568        180      10052          0          0 Hulc LED Process
176   0      11576      11080       7548          0          0 UDLD
  67   0    1066988    7299560       7052          0      27072 hrpc <- response
  61   0     106404     212664       7052          0          0 RedEarth Rx Mana
  60   0    1659728    3096072       7052          0          0 RedEarth Tx Mana
                                 42844008 Total
Hi Nishant,
At what intervals were these data captured ???
I glanced on it and couldn't find any increments on holding memory   Also the spanning tree process holding memory hasn't been incremented
If you have time we need more data intervals.
I just glanced at it, but i am not perfect, lets see for expert who analyses it correctly
As Karim said, Its the bug CSCtf79423, this was first found in 12.2(50)SE and you are using the same IOS too.
Karim's Quote:
This is latest output:
sh proc mem sorted
Processor Pool Total:   72289916 Used:   34209672 Free:   38080244
      I/O Pool Total:   12574720 Used:    8537604 Free:    4037116
PIDTTYAllocatedFreedHoldingGetbufsRetbufsProcess
0051138520110870643511122800*Init*
0055628488544929001447904105495202283560*Dead*
59084956810116059371658560Stack Mgr Notifi
18102087693625473860043490050760VMATM Callback
15602945201352029452000HL2MCM
15502944881352029446000HL2MCM
246043010841548838828844400MLDSN L2MCM
241040448041629671626621200IGMPSN L2MCM
1502305600240612997920EEM ED Syslog
140186224363356164324071240Entity MIB API
2840146428015348000EEM Server
960120883613339611811200hpm main process
15907130807836000Switch Backup In
3701139361524767413600IF-MGR control p
168093192111166831600DTP Protocol
35063474201506646610000Per-Second Jobs
221020277796179370366456422680HTTP CORE
19105106841286006311668040SpanTree Helper
14501.53E+0815146197662360152280HQM Stack Proces
11102884502126105200HACL Acl Manager
14601.63E+081631719326105200HRPC qos request
1400006105200HL3U PBR bkgrd p
103524683155525331600Chunk Manager
7701.18E+081804217200HLFM address lea
2320401801803885200DHCPD Receive
2204410019403461600IPC Seat Manager
279160108388603430822680Virtual Exec
2760887203400000LICENSE AGENT
9804930284842283146800HRPC pm request
26303133618002720800crypto engine pr
80002505200Crash writer
1900512105630157722212000CDP Protocol
201054401801831200ADJ resolve proc
2270102241801709600REP BPA/EPA Proc
2740691802190601649200PM Callback
30401612857321596400SSH Event handle
285096768321589600EEM Policy Direc
26405323565259001550800Crypto CA
26028887641517600License IPC stat
1960122916593881471200IP Input
2750109492888481458023400VLAN Manager
3030372401377600EEM ED RPC
3000372401377600EEM ED Env
2880372401377600EM ED GOLD
2890372401377600EEM ED Interface
2870372401377600EEM ED Counter
2860372401377600EEM ED CLI
2910372401377600EEM ED None
2950372401377600EEM ED SNMP
2920372401377600EEM ED OIR
2930372401377600EEM ED POWERNET
2990372401377600EEM ED Config
2960372401377600EEM ED Snmp_Prox
2980372401377600EEM ED Test
2970372401377600EEM ED Timer
2900372401377600EEM ED IOSWD
0013652213345481365200*Sched*
3101451201346000Net Background
20903961801326800CEF background p
19503961801326800CEF switching ba
217074921801326000MDFS LC Process
720001310800HIPC bkgrd proce
305010084081310400hulc cfg mgr mas
130001305200Policy Manager
282026268262681305200Syslog
270001305200License IPC serv
2901801801305200XML Proxy Client
3305587218013052355320Logger
320001305200IDB Work
580001305200Stack Mgr
800001305200HRPC hrcmd reque
20001801801305200MDFS MFIB Proces
1040001305200HCEF ADJ Refresh
1380114001305200HL3U bkgrd proce
20801801801305200KRB5 AAA
219014979601305200TCP Protocols
21803492327241305200TCP Timer
840001305200HVLAN main bkgrd
5011272490072126889352246176Pool Manager
20509.34E+081650812620113400Spanning Tree
7602117109621263580124802334960HRPC hlfm reques
63055561801247200Fifo Error Detec
107021748167041209600hl3mm
2680483292121170400VTP Trap Process
212054688521166800XDR mcast
149026696141041118000HRPC system post
252021601026800IP RIB Update
3060238313223839241010400crypto sw pk pro
2100001005200IP IRDP
2370001005200IPe DM Backgroun
20701801801005200EAPoUDP Process
19801801801005200IP ARP Track
2360001005200IPe DM Main
1370438214001801005200Hulc LED Process
2780001005200Licensing MIB pr
17801801801005200IP Host Track Pr
34018029681005201692TTY Background
15301801801005200image mgr
2030780584777932970400powernet proxy u
24502824180969600L2TRACE SERVER
26002232316911200OBFL Cfg Dispatc
266000905200Crypto SSL
265000905200Crypto PKI-CRL
26102060180893200TPLUS
54015440859600Hulc EEM Process
22408437283624780000Cluster Base
16102240452776400Auth Manager
1760292364291868754800UDLD
1200472180734400Hulc Foxhound Pr
25502160732400DHCPD Database
17702160726800Port-Security
2290396180726800Dot1x Supplicant
18302160726800IPe BSSM Manager
2300396180726800Dot1x Supplicant
2310396180726800Dot1x Supplicant
90392620719600ARP Input
9109224823764716800HCMP sync proces
4000710400Check heaps
3000710400MDFS LC Download
56000710000HRPC asic-stats
9502.49E+08105346680709600SpanTree Flush
152000709200DHCPD Timer
204000708400DiagCard2/-1
307000708000hulc running con
1920128059214284470807258680HRPC hl2mcm igmp
187000706400AAA System Acct
132000706000HRPC iec_load_ba
126000705200HRPC stp_cli req
127000705200HRPC stp_state_s
1250180180705200HSTP Sync Proces
1220180180705200REP Helper Proc
1240180180705200Hulc Storm Contr
131000705200BCM cable diags
1280180180705200S/W Bridge Proce
123000705200HRPC sdm request
134000705200HRPC IPe request
135000705200HRPC aim request
121016521652705200HRPC rep request
1290136136705200HRPC hudld reque
130000705200HRPC vqpc reques
1390620552620552705200HRPC hl3u reques
133000705200HRPC l2pt qnq rp
141000705200HL3U PBR n-h res
142000705200HRPC dtp request
143000705200HRPC show_forwar
144000705200HRPC snmp reques
116002176705200HULC CISP Proces
13602175621756705200HRPC hled reques
147000705200HRPC span reques
148000705200HRPC obfl reques
114000705200HRPC cdp request
150039921964705200Hulc Reload Mana
119000705200HRPC foxhound re
112000705200HRPC backup inte
110000705200HRPC acl request
1180202748167532705250760HULC DOT1X Proce
109000705200HACL Queue Proce
1170121007148705200HRPC dot1x reque
157042388814136705200PI MATM Aging Pr
1580180180705200REP Topology cha
115000705200HRPC lldp reques
160000705200MMN bkgrd proces
105000705200HRPC hl3mm reque
1620180180705200Dot1x Mgr Proces
163000705200MAB Framework
164000705200AUTH POLICY Fram
1650033504705200802.1x switch
1660180180705200802.1x MDA Aging
167000705200802.1x Webauth F
103000705200HRPC hcmp reques
169000705200EAP Framework
170000705200EAP Test
171000705200HRPC dai request
15101922433127052101520HRPC hrcli-event
173000705200HRPC ip device t
174000705200HRPC ip source g
175000705200HULC IP Source g
102000705200hpm vp events ca
10102753625627536256705200HRPC pm-counters
100061735802446256705200hpm counter proc
179000705200Link State Group
1800180180705200Ethchnl
1540180180705200Power RPS Proces
182000705200UNCLIP Process
970122776105036705200HPM Stack Sync P
1840180180705200AAA Server
185000705200AAA ACCT Proc
186000705200ACCT Periodic Pr
108000705200hl3mm_rp
188000705200Auth-proxy AAA B
189000705200IP Admin SM Proc
94000705200HPM Msg Retry Pr
93000705200HULC PM Vector P
213074560705200IPC LC Message H
1930204204705200AAA Dictionary R
194000705200DHCP Snooping
92024402440705200HRPC ilp request
900512212705200HRPC hfbm reques
197000705200ICMP event handl
89000705200HRPC isis reques
199000705200IPv6 Echo event
88000705200HULC VLAN REF Ba
8708571928546070524923720HRPC vlan reques
202000705200powernet proxy t
860180180705200Vlan shutdown Pr
249000705200HRPC hwccp reque
850180180705200HVLAN Mapped Vla
206000705200Spanning Tree St
53081207844705200Platform-IPe Pro
820148148705200HRPC hulc misc r
810728728705200HRPC emac reques
790180180705200HLFM address ret
211000705200CEF RF HULC Conv
780180180705200HLFM aging proce
2570180180705200LOCAL AAA
214000705200XDR RP Ping Back
21501295212952705200XDR RP backgroun
216000705200XDR RP Test Back
75019041904705200HRPC hpsecure re
7403509220676705250760Hulc Port-Securi
73000705200RTTYS Process
220000705200Socket Timers
710352352705200HRPC hdm blockin
2220180180705200Cluster L2
223000705200Cluster RARP
700200140199864705200HRPC hdm non blo
225000705200RARP Input
2260180180705200REP LSL Proc
690732180705200HULC Device Mana
228000705200Critical Auth
6806868705200HRPC hcomp reque
670244389081674904007052027072hrpc <- response
66000705200hrpc -> request
6503660316652870527802020248hrpc -> response
2330180180705200IPe BS
2340180180705200IPe P2P
520180180705200MIRAGE RBCP Moni
271000705200HCD Process
6205368180705200HULC Thermal Pro
238000705200IPe Host
239000705200HRPC dhcp snoopi
24001304680705200HULC DHCP Snoopi
61030297486062620705200RedEarth Rx Mana
242000705200IGMPSN MRD
243000705200IGMPSN
244000705200IGMPQR
6004999329693885100705200RedEarth Tx Mana
2690180180705200VTPMIB EDIT BUFF
247000705200MRD
248000705200MLD_SNOOP
44000705200HULC ASP Process
250000705200HULC_WCCP_BACKGR
2510122470814269270526903360HRPC hl2mcm mlds
55000705200Hulc LED Alchemy
253000705200HRPC x_setup req
2540193355200705200MDFS RP process
43000705200SFF8472
256000705200EPM MAIN PROCESS
410011772705200Transport Port A
2580180180705200ENABLE AAA
2590180180705200LINE AAA
2800180180705200AAA SEND STOP EV
51000705200Hulc Warm Upgrad
2620180180705200REP Switch Helpe
50028842252705200HULC multifs pro
49000705200HRPC Multi-FS Sy
480180180705200HLPIP Sync Proce
47000705200HRPC lpip reques
267000705200encrypt proc
46000705200HRPC hdwl reques
400180180705200Compute load avg
2700180180705200DHCP Security He
60180180705200Timers
272000705200HRPC cable diagn
2730108324705200DiagCard1/-1
450180180705200DownWhenLooped
30000705200Critical Bkgnd
24000705200Dynamic ARP Insp
2770180180705200dhcp snooping sw
42000705200HC Counter Timer
23000705200IPC Session Serv
21000705200IPC Deferred Por
281000705200Syslog Traps
20000705200IPC Managed Time
39000705200AggMgr Process
38000705200IF-MGR event pro
36000705200Per-minute Jobs
19000705200IPC Periodic Tim
280180180705200GraphIt
25000705200ARP Snoop
17000705200IPC Dynamic Cach
16000705200IFS Agent Manage
120180180705200AAA high-capacit
7000705200Net Input
10000705200CEF MIB API
18000705200IPC Zone Manager
11000705200AAA_SERVER_DEADT
57000410800HRPC hsm request
172000405200HULC DAI Process
830192192405200HRPC system mtu
3010180180405200STP FAST TRANSIT
3020180180405200CSRT RAPID TRANS
99083407804405200HPM if_num mappi
2350180180405200IPe BS SAF
640576576405200Adjust Regions
20180180405200Load Meter
106000405200hl3md_rpfq_thrl_
42731116 Total
At the moment you have enough free memory so we can't conclude on anything. It would be interesting to watch it when memory goes down to 10MB for example - then we will have more evidence on where it stuck.
Also regarding this DDTS CSCtf79423 - that is not smth to look at. Bug was declared as Junked so it is not SW defect, but just issue mis-treated as defect. So does not seem to be relevant. Anyway it seems to be defect - just need to find the leaking process to narow that down.
Nik
HTH,
Niko
Here is the latest output. We dont see any memory leaks issues yet. Please suggest way forward.
Processor PoolTotal:72289916Used:35548444Free:36741472
I/O PoolTotal:12574720Used:8542324Free:4032396
Driver te PoolTotal:1048576Used:40Free:1048536
001628207521616760882763108105517882283560*Dead*
181091544908110987405243490050760VMATM Callback
2460438656181507728028848400MLDSN L2MCM
2410413096181579842826619200IGMPSN L2MCM
350281572886837486610000Per-Second Jobs
2210887000927863478864564362880HTTP CORE
19105907841393086311268040SpanTree Helper
145066803571666250871262360152280HQM Stack Proces
14607140078047140078046105200HRPC qos request
7705348250961805386800HLFM address lea
103891883522965329200Chunk Manager
2320404801803915200DHCPD Receive
9805422285334283146800HRPC pm request
279137564213722926800Virtual Exec
205040906532041715228104816480Spanning Tree
190022263284136415962205600CDP Protocol
2740724042290721649200PM Callback
304039624240961596400SSH Event handle
19605289002678521471200IP Input
149058200422241456400HRPC system post
0013652922984761365200*Sched*
310153044721346000Net Background
282028032280321305200Syslog
2180145561345321305200TCP Timer
219022463201305200TCP Protocols
50507247568201268842084378700Pool Manager
107026356213121209600hl3mm
7608767275290589056117042334960HRPC hlfm reques
306011929324119352721008000crypto sw pk pro
13702037956081801005200Hulc LED Process
203034046443401992970400powernet proxy u
2240386688385940780000Cluster Base
176012885601288048756400UDLD
910405792104516716800HCMP sync proces
9501085149920462800860709600SpanTree Flush
139028474442847444705200HRPC hl3u reques
13609278092780705200HRPC hled reques
1180204204168080705250760HULC DOT1X Proce
1170130527692705200HRPC dot1x reque
1570214400499248705200PI MATM Aging Pr
1650033668705200802.1x switch
15102001241007052101520HRPC hrcli-event
1010120583056120583056705200HRPC pm-counters
10002656918410312156705200hpm counter proc
970150528128652705200HPM Stack Sync P
21505816458164705200XDR RP backgroun
75021762176705200HRPC hpsecure re
700866608866332705200HRPC hdm non blo
6701123402367573922007052027072hrpc <- response
62023476180705200HULC Thermal Pro
6101371757227453928705200RedEarth Rx Mana
243000705200IGMPSN
244000705200IGMPQR
600231748600435871372705200RedEarth Tx Mana
247000705200MRD
2540845444400705200MDFS RP process
43000705200SFF8472
410050516705200Transport Port A
7000705200Net Input
44071288 Total
Any later captures done?
Nik
HTH,
Niko
Hi Nik,
Here is the latest capture taken today,
sh processes memory   sorted
Processor PoolTotal:72289916Used:45110556Free:27179360
I/O PoolTotal:12574720Used:8535124Free:4039596
007.78E+087.76E+0812256384105517882283560*Dead*
18106.17E+082.64E+0943490050760VMATM Callback
246042664801.92E+0928886400MLDSN L2MCM
241041529761.92E+0926637600IGMPSN L2MCM
3501.79E+0845444286610000Per-Second Jobs
22105.64E+084.98E+08645641315440HTTP CORE
19103476484444501126376868040SpanTree Helper
14504.03E+094E+0962360253800HQM Stack Proces
146012228316122283166105200HRPC qos request
7702.97E+09618453516406080HLFM address lea
108721568352645329200Chunk Manager
14902667482283483698800HRPC system post
980314147631323243182000HRPC pm request
279146572302962939600Virtual Exec
19001.41E+08887876282212000CDP Protocol
2740144114444809441649200PM Callback
30401900441432921596400SSH Event handle
1960341864419282921471200IP Input
00136525.61E+081365200*Sched*
3102164444841346000Net Background
28201711201711201305200Syslog
1380174001305200HL3U bkgrd proce
219033690401305200TCP Protocols
2180739567017481305200TCP Timer
503043442081356126882525041099852Pool Manager
20502.36E+09203580126603583440Spanning Tree
1070197899619739521209600hl3mm
7605.14E+085.43E+08117043147120HRPC hlfm reques
34018031041005201692TTY Background
13701.33E+091801005200Hulc LED Process
306062993844630310481004800crypto sw pk pro
20302052174820519096970400powernet proxy u
224024284362427688780000Cluster Base
176075876247587116756000UDLD
9102454340654008716800HCMP sync proces
400300710400Check heaps
9502.48E+092.85E+09709600SpanTree Flush
13901697023616970236705200HRPC hl3u reques
1360567396567396705200HRPC hled reques
1180220964173776705250760HULC DOT1X Proce
11702313213948705200HRPC dot1x reque
157011795128634664705200PI MATM Aging Pr
1650035572705200802.1x switch
15101599121440007052101520HRPC hrcli-event
10107.27E+087.27E+08705200HRPC pm-counters
10001.61E+0864301736705200hpm counter proc
97062732485343828705200HPM Stack Sync P
2150381048381048705200XDR RP backgroun
75053045304705200HRPC hpsecure re
70043582724357996705200HRPC hdm non blo
6707.03E+08892154807052027072hrpc <- response
620153932180705200HULC Thermal Pro
610908918241.82E+08705200RedEarth Rx Mana
243000705200IGMPSN
244000705200IGMPQR
6001.51E+092.84E+09705200RedEarth Tx Mana
247000705200MRD
25405.1E+080705200MDFS RP process
43000705200SFF8472
4100307252705200Transport Port A
7000705200Net Input
                                 53572920   Total
Thanks Nishant,
Dead process is growing continuously and does not release memory. I think it is this defect:
CSCsz79652
Memory leak in *dead* memory
Symptoms
A memory leak may be seen in *Dead* memory.
Conditions
This issue occurs in IOS version 12.2(50)SE and l2.2(50)SE1.  IOS version
12.2(44)SE is not affected.
The problem occurs when using Cisco Network Assistant to poll the device.
ip http server or ip http secure-server need to be enabled for the leak to
occur.
Workaround
Disable the http server or stop CNA from polling the device.
You can also get following command:
sh memory processor dead totals  | in HTTP
But I guess you can try workaround above or do upgrade. It is fixed in
12.2(52)SE 12.2(52)EY 12.2(50)SE03
Hope this helps,
Nik
HTH,
Niko
Thanks Nik,
We are planning to upgrade the IOS.
Hey, just wanted to know if we can forcefully kill these dead process and relase those memory which they are holding.
Thx
Nishant
Actually Dead process is not a process itself - it just a counter showing how many memory released by the other processes. Having leak in Dead means that some process declared to release memory but actually did not. You can check what particular process released memory before - but you might not understand which one is culprit for leak.
Command to use is
show memory dead
Other thing - there is no "kill utility" in IOS so process just should be naturally stopped to release memory.
Defect I shared before was caused by http or https servers running - so possibly stopping those you can release memory and stop the leak.
You can read here about Dead process in the section for it:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6f3a.shtml#tshoot2
Nik
HTH,
Niko
