04-06-2016 10:30 AM - edited 03-08-2019 05:15 AM
I have some problems conecting two cisco in stack mode.
How can I update the WS-C3750X-24 to have the same version in both ciscos??
here are some captures:
Switch Ports Model SW Version SW Image
* 1 30 WS-C3750X-24 12.2(55)SE3 C3750E-UNIVERSALK9-M
2 0 WS-C3750X-12S 12.2(58)SE2 C3750E-UNIVERSALK9-M
Switch Master/ Mac Address Version Current
Number Member (maj.min) State
1 Master ccef.48e3.2500 1.45 Ready
2 Member 5c83.8fa0.5a80 1.46 VerMis
Nicolás
Solved! Go to Solution.
04-06-2016 12:15 PM
Since WS-C3750X-24 is the master you can simply upgrade the IOS on that switch to match WS-C3750X-12S switch. Once that is completed save the config and reboot the stack. Now both switches should have the same image (12.2(58)SE2).
04-06-2016 12:15 PM
04-08-2016 04:40 AM
Thanks, thats work fine!!!
