Nexus 7k FSCK
benweber
Does anyone know how to check a file system on a Nexus switch?  I'm thinking of the old fsck functionality that some other devices have available.
I have some cores I need to reboot and want to verify the health of the flash before doing so.
Thanks!
James Clifford
I don't think you can do a FSCK but try this hidden command - 'slot 5 show system internal raid'
Will show you whether your disks are healthy or not. Do it for slot 6 as well.
James
