CISCO 3750 SWITCH UNABLE TO START
biju.digiana
Hi All,
I am having a switch of model  3750.
But the switch is trying to load again and again,it is not able to start normally.
Can Anybody tell what is happening with my switch.
It is third time that one of my cisco 3750 switch got defected.
Kindly suggest me what should i do ?
Below i am giving the details of the switch while trying to reboot.
%Crashinfo not stored: cannot open "flash:/crashinfo/crashinfo_242".
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:4) walking-one test failed
  Write: 80_02000000_00000000-00_00000000_00000000
  Read:  80_00000000_00000000-00_00000000_00000000
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
*Mar  1 00:00:55.608: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console d
ebugging output.
*Mar  1 00:00:55.608: %SYS-2-ASSERTION_FAILED: Assertion failed: "reg_used_xdr_p
ortid_to_lc_logical_slot()" -Process= "Init", ipl= 0, pid= 3
-Traceback= 1F05BF0 11D7EFC 11D80EC 27CD974 27CDA0C 1FAA76C 1FAA9A8 1B8D06C 1B83
AF8
%Software-forced reload
 00:00:56 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 1B8B0
9C
-Traceback= 1B8B09C 1B8B060 11D7EFC 11D80EC 27CD974 27CDA0C 1FAA76C 1FAA9A8 1B8D
06C 1B83AF8
=== Flushing messages (00:00:56 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar  1 00:00:56.404: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console d
ebugging output.
*Mar  1 00:00:56.019: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to e
nsure console debugging output.
*Mar  1 00:00:56.279: %Insufficient flash filespace for extended crashinfo.
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(53)SE2, RELE
ASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 04:49 by prod_rel_team
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x0179C880  SRR1 = 0x00029230  SRR2 = 0x01B8B09C  SRR3 = 0x00029230
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000  PC = 0x01B8B09C  MSR = 0x00029230  CR = 0x33000053
LR = 0x01B8B060  CTR = 0x0254A060  XER = 0xC0000002
R0 = 0x01B8B060  R1 = 0x03EFB190  R2 = 0x00000000  R3 = 0x04408B84
R4 = 0xFFFFFFFE  R5 = 0x00000000  R6 = 0x03EFB178  R7 = 0x00000000
R8 = 0x00000000  R9 = 0x00000000  R10 = 0x034A0000  R11 = 0x04408B80
R12 = 0x0000DAD3  R13 = 0x00110000  R14 = 0x01FAA948  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19 = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23 = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27 = 0x00000001
R28 = 0x000004A5  R29 = 0x02C19BA4  R30 = 0x02E4CF48  R31 = 0x00000000
Stack trace:
PC = 0x01B8B09C, SP = 0x03EFB190
Frame 00: SP = 0x03EFB1A0    PC = 0x01B8B060
Frame 01: SP = 0x03EFB468    PC = 0x01F05CCC
Frame 02: SP = 0x03EFB480    PC = 0x011D7EFC
Frame 03: SP = 0x03EFB4D0    PC = 0x011D80EC
Frame 04: SP = 0x03EFB4D8    PC = 0x027CD974
Frame 05: SP = 0x03EFB4F0    PC = 0x027CDA0C
Frame 06: SP = 0x03EFB510    PC = 0x01FAA76C
Frame 07: SP = 0x03EFB618    PC = 0x01FAA9A8
Frame 08: SP = 0x03EFB620    PC = 0x01B8D06C
Frame 09: SP = 0x00000000    PC = 0x01B83AF8
Switch uptime is 58 seconds
cisco WS-C3750G-24TS (PowerPC405) processor (revision R0) with 131072K bytes of
memory.
Processor board ID FDO1235X0UL
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:23:05:0a:a6:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 257 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 15998976
flashfs[0]: Bytes available: 0
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
done.
Loading "flash:/c3750-ipbasek9-mz.122-53.SE2.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Mark Malone
Looks like its hitting a bug , have you already upgraded the software image ? , you have tracebacks errors which could be software or hardware , if you have already upgraded through software you may have a defect itself in hardware and need to replace it
1 upgrade the software try and fix it that way
2 Run it by TAC  if software is not fixing it , may need replacement
Similar bug
Last Modified
Feb 08, 2017
Product
Cisco Catalyst 3750 Series Switches
Known Affected Releases
12.2(52)SE
Description (partial)
Symptom:
After reload, a WS-C3750G-12S switch crashes in loop with following messages :
POST: POST Failed
and
%SYS-2-ASSERTION_FAILED: Assertion failed: "reg_used_xdr_portid_to_lc_logical_slot()" -Process= "Init", ipl= 0, pid= 3
Conditions:
The WS-C3750G-12S has been configured with SDM template IPe, which is unsupported although configurable
