QoS in c3850 not working
JRDIAZ758
Hey, ive been trying to get a simple QoS Implementation to work. we purchased a stack of 3850s  for incoming traffic from clients. so ive been trying to marking incoming packets from the client network with specific DSCP and then apply priority based on those DSCP values. it doesnt seem to be marking anything thus making the outbound policy-map restrict have lots of output drops.
what am i missing here?
so its:
client ----------->  ( g1/0/23 .core. g1/1/4)  -------> MPLS Link
!!!! creating ACLs/Class Maps for traffic
ip access-list extended priority_mark_voip
permit udp any any range 5000 65535
ip access-list extended priority_mark_data
 permit tcp any any eq www
 permit tcp any any eq 443
 permit tcp any any eq 4172
 permit udp any any eq 4172
class-map match-any priority_Data
 match access-group name priority_mark_data
class-map match-any priority_voip_marking
 match access-group name priority_mark_voip
class-map match-any client_traffic_data
 match dscp cs2
class-map match-any client_traffic_voip
 match dscp ef
!!!!!! policy-Map for incoming traffic
policy-map classifying_traffic
 class priority_voip_marking
  set dscp ef
 class priority_data_marking
  set dscp cs2
!!!!!!!! policy map for outging traffic
policy-map priority_traffic_prod
 class client_traffic_voip
  priority percent 50
 class client_traffic_data
  priority percent 40
policy-map port_child_policy
 class non-client-nrt-class
  bandwidth remaining ratio 10
!!!!!!!!!! applying Policy-MAPs
interface g1/0/23
 service-policy input classifying_traffic
interface GigabitEthernet1/1/4
 service-policy output priority_traffic_prod
!!!! show policy-map show no packets being marked/classified.
GigabitEthernet1/0/23
  Service-policy input: classifying_traffic
    Class-map: priority_voip_marking (match-any)
      870640040 packets
      Match: access-group name priority_mark_voip
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        dscp ef
    Class-map: priority_data_marking (match-any)
      117512 packets
      Match: access-group name priority_mark_data
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        dscp cs2
    Class-map: class-default (match-any)
      13515093 packets
      Match: any
Dennis Mink
Tomas,
are you accesslist that define your intersting traffic getting hit?
do sh ip access list priority_mark_voip  for instance
Looking at the default traffic there is traffic getting passed on the service-policy input classifying_traffic
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
i dont see any hits, but the traffic coming into the g1/0/23 is pretty much what its coming from the client, (RTP traffic and WMview traffic) is what i put in the ACL.
show access-lists priority_mark_voip
Extended IP access list priority_mark_voip
80 permit udp any any range 5000 65535
show access-lists priority_mark_data
Extended IP access list priority_mark_data
80 permit tcp any any eq www
90 permit tcp any any eq 443
100 permit tcp any any eq 4172
110 permit udp any any eq 4172
