Cisco 3750 switch
noordeen2229
Why not working sfp on Cisco 3750 switch
11 Replies 11
rhallinan7387
The 'Cisco Optics-to-Device Compatibility Matrix' located at https://tmgmatrix.cisco.com/ may help you to verify compatibility of the SFP you are trying to use with your specific switch model.
now working fine. thanks
balaji.bandi
what is the full  model  ? what SFP not working ? what IOS code running ?
what you see the Logs ?
is this uplink module ? have you upgrade to latest version ?
BB
Hi now working fine .Thanks
Leo Laohoo
Post the complete output to the following command:
  1. sh version
  2. sh inventory
  3. sh log
Joseph W. Doherty
"Why not working sfp on Cisco 3750 switch"
Lots and lots (and lots) of possibilities.  Most common issues are something is defective, something isn't supported, something is misconfigured.
If you provide the information requested by the other posters, possibly we can narrow possibilities to only lots and lots.
If problem isn't obvious, such as whatever isn't supported, troubleshooting often requires comparing to other working similar solutions, such as the does SFP port work with another SFP transceiver, does SFP transceiver work in another SFP port, etc.
Hi ,
Now working fine .Thanks
Great!
Can you tell us what the solution was?
just restarted the switch .Thanks
I have another problem. Could you help me ?
I had incorrectly updated the firmware of Cisco Air-cap3602i-a-k9.
now not responding in gui
only connecting through PUTTY
Suggest posting wap issue in new post.
