Cisco 3750-X: difference between universal and ipbase image
vlad.mihailov
There are two firmware files for Cisco 3750-X: Universal and the IPBase. We have a switch with Universal image and the lanbase license feature set. We do need now to have routing between the SVIs on that switch so IPBase license for the Universal is what we need.
Question (likely very silly but I will ask it anyway): Do we need to purchase the license if we would like to run an IPBase image (not the Jniversal with the IPBase license - but the IPBase image firmware version 12.2.58) or is it still a purchasable upgrade?
Thank you.
2 Accepted Solutions
Reza Sharifi
Yes, with the new universal image, you need to purchase a license to use IP Base. If not when you do a sh license you only see lan Base license.
InayathUlla Sharieff
vlad,
Agree with Reza, A brief explanation can be found on the below link which will help you to get clarity on these query:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-579326_ps10745_Products_White_Paper.html
Inayath
Reza Sharifi
vlad,
Inayath
Thank you. Just wanted a second pair of eyes to look at it.
