Cisco 3750-x won't power up
birukgetachew
Hi guys,
I recently bought a bunch of cisco 3750-x switches. I configured them all and started deploying them. A day later, some of the switches started failing on me. When I connect the power cord to the AC main, the power supply module on the back shows "AC OK" LED Green but the "PS OK" LED shows Red. I started referring to the installation guide and it told me that "PS OK" LED turns RED when output has failed. Guessing this I checked with another power supply module that was working, but still I get the same LED indicators.
The original power supply module works with other switches. What could be the problem? IOS crash...?
7 Replies 7
Leo Laohoo
What happens when you console into the switch?  What output do you get?
There is no console output via a serial port. Its just dead.
Lee Watkins
we've had a few 3750X switches expoerience this same issue.  if i find anything online i'll post it here, but so far not much.
Check the PS at the back, is there a light?  If there's no light, then you need to RMA the PS as it could be faulty.
If there's a light on the PS, then you need to RMA the switch.
dynamitec1
Just what leo had said.
manolotanzi
I have
the same problem with 6 devices.
Did you found any solution?
hhao
me too, the same situation, the same LED shows.
cisco WS-C3750X-12S is dead。I change a new power supply, It is still dead.
