10-21-2018 01:06 AM - edited 03-08-2019 04:26 PM
hello,
i am experience internal packet loss from servers to the gateway (vlan SVI), the packet loss occur only in my switch from inbound and outbound and also high latency to the gateway up to 50ms.
i am sharing my config
Current configuration : 22175 bytes ! ! Last configuration change at 05:46:34 UTC Mon Jan 2 2006 ! version 15.0 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname davidx ! boot-start-marker boot-end-marker ! ! enable secret 5 $1$Jbvf$JFUVs/BfdfgcX87pTeQ/un0 ! username xxxxx password 7 050Ahfghvb1651731C5B42167 no aaa new-model switch 1 provision ws-c3750x-48 system mtu routing 1500 ip routing ip icmp rate-limit unreachable 100 ! ! ! ip domain-name davidx.com ip device tracking ipv6 unicast-routing vtp domain TA vtp mode transparent ! mls qos srr-queue output cos-map queue 1 threshold 3 4 mls qos srr-queue output cos-map queue 2 threshold 3 0 1 2 3 5 6 7 mls qos srr-queue output dscp-map queue 1 threshold 3 32 mls qos srr-queue output dscp-map queue 2 threshold 3 0 1 2 3 4 5 6 7 mls qos srr-queue output dscp-map queue 2 threshold 3 8 9 10 11 12 13 14 15 mls qos srr-queue output dscp-map queue 2 threshold 3 16 17 18 19 20 21 22 23 mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31 mls qos srr-queue output dscp-map queue 2 threshold 3 33 34 35 36 37 38 39 40 mls qos srr-queue output dscp-map queue 2 threshold 3 41 42 43 44 45 46 47 48 mls qos srr-queue output dscp-map queue 2 threshold 3 49 50 51 52 53 54 55 56 mls qos srr-queue output dscp-map queue 2 threshold 3 57 58 59 60 61 62 63 mls qos queue-set output 1 threshold 1 3200 3200 20 3200 mls qos queue-set output 1 threshold 2 3200 3200 20 3200 mls qos queue-set output 1 threshold 3 1 1 1 1 mls qos queue-set output 1 threshold 4 1 1 1 1 mls qos queue-set output 1 buffers 20 80 0 0 mls qos ! crypto pki trustpoint TP-self-signed-4051573376 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-4051573376 revocation-check none rsakeypair TP-self-signed-4051573376 ! ! spanning-tree mode pvst spanning-tree extend system-id no spanning-tree vlan 1,3-4 ! ! ! ! ! vlan internal allocation policy ascending ! vlan 2-8 ! vlan 9 name xxx ! vlan 10 name xxx ! vlan 11 name xxx ! vlan 12 name xxx ! vlan 13 name xxx ! vlan 14 name xxx ! vlan 15 name xxx ! vlan 16-17 ! vlan 19 name xxx ! vlan 20 ! vlan 21 name xxxVlan ! vlan 22 name xxx80838 ! vlan 23 name xxxVlan ! vlan 24 name Chong ! vlan 25 name xxx ! vlan 26 name xxx93527 ! vlan 27 name Cisco-3750G ! vlan 28 name xxx4 ! vlan 160 ! ! class-map match-all BANDWIDTH-CUSTOMER_50mbps-CM match access-group name BANDWIDTH-CUSTOMER-50mbps-ACL class-map match-all BANDWIDTH-CUSTOMER_20mbps-CM match access-group name BANDWIDTH-CUSTOMER-20mbps-ACL class-map match-all BANDWIDTH-CUSTOMER_5mbps-CM match access-group name BANDWIDTH-CUSTOMER-5mbps-ACL class-map match-all BANDWIDTH-CUSTOMER_200mbps-CM match access-group name BANDWIDTH-CUSTOMER-200mbps-ACL class-map match-all BANDWIDTH-CUSTOMER_100mbps-CM match access-group name BANDWIDTH-CUSTOMER-20mbps-ACL ! policy-map BANDWIDTH-CUSTOMER_50mbps-PM class BANDWIDTH-CUSTOMER_50mbps-CM police 50000000 400000 exceed-action drop policy-map BANDWIDTH-CUSTOMER_5mbps-PM class BANDWIDTH-CUSTOMER_5mbps-CM police 5000000 8000 exceed-action drop policy-map BANDWIDTH-CUSTOMER_100mbps-PM class BANDWIDTH-CUSTOMER_100mbps-CM police 100000000 400000 exceed-action drop policy-map BANDWIDTH-CUSTOMER_200mbps-PM class BANDWIDTH-CUSTOMER_200mbps-CM police 200000000 400000 exceed-action drop policy-map BANDWIDTH-CUSTOMER_20mbps-PM class BANDWIDTH-CUSTOMER_20mbps-CM police 20000000 400000 exceed-action drop ! ! ! ! ! ! ! ! buffers tune automatic ! ! ! ! interface Null0 no ip unreachables ! interface Port-channel10 switchport trunk encapsulation dot1q switchport trunk native vlan 3 switchport trunk allowed vlan 3 switchport mode trunk ! interface FastEthernet0 ip address 192.168.1.1 255.255.255.0 no ip route-cache ! interface GigabitEthernet1/0/1 switchport access vlan 5 speed 100 srr-queue bandwidth shape 0 0 0 0 srr-queue bandwidth limit 55 service-policy input BANDWIDTH-CUSTOMER_50mbps-PM ! interface GigabitEthernet1/0/2 switchport access vlan 10 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/3 switchport access vlan 7 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/4 switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/5 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/6 description xxx switchport access vlan 22 srr-queue bandwidth shape 0 0 0 0 srr-queue bandwidth limit 90 service-policy input BANDWIDTH-CUSTOMER_20mbps-PM ! interface GigabitEthernet1/0/7 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/8 description xxx switchport access vlan 2 ip access-group antispoof in srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/9 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/10 description xxx switchport access vlan 21 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/11 description xxx switchport access vlan 12 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/12 description xxx switchport access vlan 22 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/13 description xxx switchport access vlan 6 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/14 description xxx switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/15 description xxx switchport access vlan 4 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/16 description Cisco 3750G trunk switchport trunk encapsulation dot1q switchport trunk native vlan 27 switchport trunk allowed vlan 1,27 switchport mode trunk srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/17 description xxx switchport access vlan 8 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/18 description xxx switchport access vlan 8 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/19 description xxx switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 srr-queue bandwidth limit 90 service-policy input BANDWIDTH-CUSTOMER_20mbps-PM ! interface GigabitEthernet1/0/20 description xxx switchport access vlan 8 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_100mbps-PM ! interface GigabitEthernet1/0/21 description xxx switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/22 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/23 description xxx switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_20mbps-PM ! interface GigabitEthernet1/0/24 description switch switchport trunk encapsulation dot1q switchport trunk native vlan 4 switchport trunk allowed vlan 4 switchport mode trunk srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/25 description xxx switchport access vlan 23 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/26 description xxx switchport access vlan 15 switchport trunk encapsulation dot1q switchport mode trunk srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/27 description xxx switchport access vlan 23 switchport trunk allowed vlan 1,27 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/28 description xxx switchport access vlan 23 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/29 description xxx switchport access vlan 24 ip access-group antispoof in srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/30 description xxx switchport access vlan 19 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/31 description xxx switchport access vlan 25 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/32 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/33 description xxx switchport access vlan 15 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/34 description xxx switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/35 description xxx switchport access vlan 26 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/36 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 srr-queue bandwidth limit 20 service-policy input BANDWIDTH-CUSTOMER_5mbps-PM ! interface GigabitEthernet1/0/37 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/38 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/39 description xxx switchport access vlan 28 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/40 description LACP port switchport trunk encapsulation dot1q switchport trunk native vlan 3 switchport trunk allowed vlan 3 switchport mode trunk srr-queue bandwidth share 1 255 1 1 srr-queue bandwidth shape 0 0 0 0 priority-queue out mls qos trust dscp channel-protocol lacp channel-group 10 mode active ! interface GigabitEthernet1/0/41 description xxx switchport access vlan 2 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/42 description xxx switchport access vlan 17 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/43 description xxx0 switchport access vlan 13 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/44 description xxx switchport access vlan 3 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/45 description xxx switchport access vlan 15 srr-queue bandwidth shape 0 0 0 0 service-policy input BANDWIDTH-CUSTOMER_20mbps-PM ! interface GigabitEthernet1/0/46 description xxx switchport access vlan 16 srr-queue bandwidth shape 0 0 0 0 ! interface GigabitEthernet1/0/47 description WAN - 400Mbps IL / 40 INT switchport trunk encapsulation dot1q switchport trunk native vlan 4 switchport trunk allowed vlan 4 switchport mode trunk srr-queue bandwidth shape 0 0 0 0 mls qos trust dscp ! interface GigabitEthernet1/0/48 description WAN - 1Gbps switchport trunk encapsulation dot1q switchport trunk native vlan 3 switchport trunk allowed vlan 3 switchport mode trunk srr-queue bandwidth share 1 255 1 1 srr-queue bandwidth shape 0 0 0 0 priority-queue out mls qos trust dscp channel-protocol lacp channel-group 10 mode active ! interface GigabitEthernet1/1/1 ! interface GigabitEthernet1/1/2 ! interface GigabitEthernet1/1/3 ! interface GigabitEthernet1/1/4 ! interface TenGigabitEthernet1/1/1 ! interface TenGigabitEthernet1/1/2 ! interface Vlan1 no ip address no ip route-cache ! interface Vlan2 ip address xxx.8.166.185 255.255.255.248 secondary ip address xxx.145.204.65 255.255.255.192 secondary ip address xxx.169.61.17 255.255.255.240 secondary ip address xxx.145.205.73 255.255.255.248 secondary ip address xxx.145.204.177 255.255.255.248 secondary ip address xxx.145.206.1 255.255.255.248 secondary ip address xxx.145.207.1 255.255.255.248 secondary ip address xxx.179.42.33 255.255.255.224 secondary ip address xxx.169.61.33 255.255.255.224 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan3 ip address xxx.169.61.4 255.255.255.240 secondary ip address xxx.179.42.4 255.255.255.224 secondary ip address xxx.8.166.180 255.255.255.248 no ip route-cache ! interface Vlan4 description 20Mbps private feed ip address xxx.8.199.4 255.255.255.240 no ip route-cache ip policy route-map wan2 ipv6 address FE80::69 link-local ipv6 address 1005:70A2:5::4/120 ipv6 enable ! interface Vlan5 description Volodymyr 185.191.204.0 - 185.191.204.15 ip address xxx.145.204.1 255.255.255.240 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan6 description KVM VLAN ip address xxx.145.204.33 255.255.255.224 secondary ip address xxx.145.204.209 255.255.255.240 secondary ip address xxx.145.204.225 255.255.255.240 secondary ip address xxx.145.204.185 255.255.255.248 secondary ip address xxx.145.205.177 255.255.255.240 secondary ip address xxx.145.204.193 255.255.255.240 secondary ip address xxx.145.204.241 255.255.255.248 secondary ip address xxx.145.205.241 255.255.255.240 secondary ip address xxx.145.205.113 255.255.255.240 secondary ip address xxx.145.205.129 255.255.255.248 secondary ip address xxx.179.96.161 255.255.255.224 secondary ip address xxx.145.204.17 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan7 ip address xxx.145.205.137 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan8 ip address xxx.145.204.153 255.255.255.248 secondary ip address xxx.145.204.161 255.255.255.248 secondary ip address xxx.145.204.145 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan9 no ip address ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan10 ip address xxx.145.204.253 255.255.255.252 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan11 ip address xxx.145.204.25 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan12 description Peter ip address xxx.145.206.253 255.255.255.252 ip verify unicast source reachable-via rx allow-default no ip route-cache ipv6 address 2R0H:1GC0:1::1/64 ! interface Vlan13 description Appstractor_corp Vlan ip address xxx.145.204.169 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan14 no ip address ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan15 ip address xxx.145.205.233 255.255.255.248 secondary ip address xxx.145.205.225 255.255.255.248 secondary ip address xxx.145.205.217 255.255.255.248 secondary ip address xxx.154.166.17 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan16 ip address xxx.145.204.129 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan17 ip address xxx.145.204.137 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan18 no ip address ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan19 ip address xxx.145.205.193 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan20 ip address xxx.145.205.105 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan21 ip address xxx.145.205.65 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan22 ip address xxx.145.205.161 255.255.255.240 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan23 ip address xxx.145.205.17 255.255.255.240 secondary ip address xxx.145.205.33 255.255.255.240 secondary ip address xxx.145.205.1 255.255.255.240 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan24 ip address xxx.145.206.33 255.255.255.224 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan25 ip address xxx.147.141.1 255.255.255.0 secondary ip address xxx.147.142.1 255.255.255.0 secondary ip address xxx.147.143.1 255.255.255.0 secondary ip address xxx.147.140.1 255.255.255.0 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan26 ip address xxx.145.205.49 255.255.255.240 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan27 description Cisco 3750G ip address xxx.145.205.201 255.255.255.248 secondary ip address xxx.145.205.97 255.255.255.248 ip verify unicast source reachable-via rx allow-default no ip route-cache ! interface Vlan28 description xxxx ip address xxx.239.255.65 255.255.255.224 ip verify unicast source reachable-via rx allow-default no ip route-cache ! router bgp 24650 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 1005:70A2:5::2 remote-as 31502 neighbor 1005:70A2:5::2 password 7 046F06dsfxcwer619546082604 neighbor 1005:70A2:5::3 remote-as 12400 neighbor 1005:70A2:5::3 password 7 03305dsf190wer1A0B3C230F2E2A neighbor xxx.169.61.2 remote-as 31502 neighbor xxx.169.61.2 password 7 112F4D1ssdfA1Eer163F361D3204 neighbor xxx.169.61.3 remote-as 31502 neighbor xxx.169.61.3 password 7 0807dsf201085D5B363D2E0C3824 neighbor xxx.8.199.12 remote-as 45887 ! address-family ipv4 network xxx.154.166.16 mask 255.255.255.248 network xxx.179.96.160 mask 255.255.255.224 network xxx.147.140.0 mask 255.255.252.0 network xxx.145.204.0 mask 255.255.252.0 network xxx.145.204.0 mask 255.255.255.0 network xxx.145.205.0 mask 255.255.255.0 network xxx.145.206.0 mask 255.255.255.0 network xxx.145.207.0 mask 255.255.255.0 neighbor xxx.169.61.2 activate neighbor xxx.169.61.3 activate exit-address-family ! address-family ipv6 network 2R0H:1GC0::/29 neighbor 1005:70A2:5::2 activate neighbor 1005:70A2:5::3 activate exit-address-family ! ! no ip http server no ip http secure-server ! ip route 0.0.0.0 0.0.0.0 xxx.169.61.1 ip route xxx.147.140.0 255.255.252.0 Null0 ip route xxx.145.204.0 255.255.252.0 Null0 ip route xxx.145.204.0 255.255.255.0 Null0 ! ip access-list extended BANDWIDTH-CUSTOMER-100mbps-ACL permit ip any any ip access-list extended BANDWIDTH-CUSTOMER-20mbps-ACL permit ip any any ip access-list extended BANDWIDTH-CUSTOMER-5mbps-ACL permit ip any any ip access-list extended BANDWIDTH-CUSTOMER_20mbps-CM permit ip any any ip access-list extended BANDWIDTH-CUSTOMER_50mbps-CM permit ip any any ip access-list extended BLOCKPING deny icmp any any permit ip any any ip access-list extended antispoof deny ip 0.0.0.0 0.255.255.255 any deny ip 10.0.0.0 0.255.255.255 any deny ip 100.64.0.0 0.63.255.255 any deny ip 127.0.0.0 0.255.255.255 any deny ip 169.254.0.0 0.0.255.255 any deny ip 172.16.0.0 0.15.255.255 any deny ip 192.0.0.0 0.0.0.255 any deny ip 192.0.2.0 0.0.0.255 any deny ip 192.168.0.0 0.0.255.255 any deny ip 198.18.0.0 0.1.255.255 any deny ip 198.51.100.0 0.0.0.255 any deny ip 203.0.113.0 0.0.0.255 any deny ip 224.0.0.0 31.255.255.255 any permit ip any any ip access-list extended wan2 permit ip any any ! ! ip prefix-list filter_gpl seq 10 permit xxx.74.236.0/24 access-list 20 permit xxx.145.204.66 access-list 30 permit any ipv6 route 2R0H:1GC0::/29 Null0 ipv6 route ::/0 1005:70A2:5::1 ! route-map wan2 permit 10 set ip next-hop xxx.8.199.1 ! ! no vstack ! line con 0 logging synchronous login local line vty 0 4 access-class 20 in password 7 12640F0C357E25655E login local transport input ssh line vty 5 15 password 7 1513137E2167342861 login ! end
10-21-2018 01:12 AM
which (VLAN) interface(s) is/are seeing the packet loss ? Post the output of 'show interfaces x' where 'x' represents the interfaces that are losing traffic...
10-21-2018 01:16 AM - edited 10-21-2018 01:17 AM
this happens in all vlans, when i do MTR from outside or from one of the servers to outside i see the switch losing packets up to 40%.
this is the LACP port channel interface to ISP
Port-channel10 is up, line protocol is up (connected) Hardware is EtherChannel, address is e4d3.f17e.1ab0 (bia e4d3.f17e.1ab0) MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec, reliability 255/255, txload 95/255, rxload 94/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, link type is auto, media type is unknown input flow-control is off, output flow-control is unsupported Members in this channel: Gi1/0/40 Gi1/0/48 ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:01, output never, output hang never Last clearing of "show interface" counters 1d16h Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 41770 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 738757000 bits/sec, 118094 packets/sec 5 minute output rate 749018000 bits/sec, 122088 packets/sec 14062531561 packets input, 11015927520066 bytes, 0 no buffer Received 5242693 broadcasts (755335 multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 755335 multicast, 0 pause input 0 input packets with dribble condition detected 14429433715 packets output, 11366948587242 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out
10-21-2018 01:23 AM
You have numerous policers, check if these are responsible for any traffic being dropped. The amount of output drops on your port channel is very small, it can never represent 40 percent of the total. Either way, try and increase the hold queue on your port channel:
interface port-channel10
hold-queue out 2000
Also, post the output of:
show buffers
show proc cpu
10-21-2018 02:34 AM
i did hold-queue 2000 out for int 40,48 and po10
here is the output of show buffers:
Buffer elements: 1643 in free list (500 max allowed) 29393530 hits, 0 misses, 1641 created Public buffer pools: Small buffers, 104 bytes (total 147, permanent 50, peak 191 @ 2d01h): 142 in free list (20 min, 150 max allowed) 11002499 hits, 455 misses, 1103 trims, 1200 created 0 failures (0 no memory) Middle buffers, 600 bytes (total 61, permanent 25, peak 76 @ 2d01h): 55 in free list (10 min, 150 max allowed) 1300247 hits, 188 misses, 320 trims, 356 created 8 failures (0 no memory) Big buffers, 1536 bytes (total 63, permanent 50, peak 185 @ 2d01h): 63 in free list (5 min, 150 max allowed) 1888610 hits, 124 misses, 329 trims, 342 created 8 failures (0 no memory) VeryBig buffers, 4520 bytes (total 25, permanent 20, peak 27 @ 09:36:40): 10 in free list (5 min, 25 max allowed) 75 hits, 10 misses, 16 trims, 21 created 7 failures (0 no memory) Large buffers, 5024 bytes (total 2, permanent 2, peak 4 @ 09:36:40): 2 in free list (0 min, 2 max allowed) 1 hits, 6 misses, 16 trims, 16 created 6 failures (0 no memory) Huge buffers, 18024 bytes (total 2, permanent 2, peak 4 @ 09:36:40): 2 in free list (0 min, 2 max allowed) 2 hits, 5 misses, 16 trims, 16 created 5 failures (0 no memory) Interface buffer pools: Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 2d01h): 101 in free list (132 min, 132 max allowed) 19428 hits, 0 misses FastEthernet0-Physical buffers, 1524 bytes (total 32, permanent 32): 8 in free list (0 min, 32 max allowed) 24 hits, 0 fallbacks 8 max cache size, 8 in cache 0 hits in cache, 0 misses in cache RxQ1 buffers, 2040 bytes (total 384, permanent 384): 2 in free list (0 min, 384 max allowed) 198613 hits, 742 fallbacks RxQ2 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 128 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) RxQ3 buffers, 2040 bytes (total 128, permanent 128): 6 in free list (0 min, 128 max allowed) 11240597 hits, 1567549 fallbacks RxQ4 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 14985 hits, 558869 misses RxQ5 buffers, 2040 bytes (total 128, permanent 128): 64 in free list (0 min, 128 max allowed) 64 hits, 0 misses RxQ6 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 2563721 hits, 34642300 misses RxQ7 buffers, 2040 bytes (total 1200, permanent 1200): 343 in free list (0 min, 1200 max allowed) 5302800 hits, 594 misses RxQ8 buffers, 2040 bytes (total 64, permanent 64): 0 in free list (0 min, 64 max allowed) 242856 hits, 7315887 misses RxQ9 buffers, 2040 bytes (total 1, permanent 1): 0 in free list (0 min, 1 max allowed) 1 hits, 0 misses RxQ10 buffers, 2040 bytes (total 64, permanent 64): 1 in free list (0 min, 64 max allowed) 1201360 hits, 19028 fallbacks RxQ11 buffers, 2040 bytes (total 16, permanent 16): 0 in free list (0 min, 16 max allowed) 718665441 hits, 720925554 misses RxQ12 buffers, 2040 bytes (total 96, permanent 96): 0 in free list (0 min, 96 max allowed) 96 hits, 0 misses RxQ13 buffers, 2040 bytes (total 16, permanent 16): 0 in free list (0 min, 16 max allowed) 16 hits, 0 misses RxQ15 buffers, 2040 bytes (total 4, permanent 4): 0 in free list (0 min, 4 max allowed) 3441914 hits, 3441910 misses HRPCRespFallback buffers, 1500 bytes (total 80, permanent 80): 80 in free list (0 min, 80 max allowed) 0 hits, 0 misses RxQFB buffers, 2040 bytes (total 904, permanent 904): 895 in free list (0 min, 904 max allowed) 1881059 hits, 0 misses RxQ0 buffers, 2040 bytes (total 1200, permanent 1200): 700 in free list (0 min, 1200 max allowed) 500 hits, 0 misses IPC buffers, 2048 bytes (total 300, permanent 300): 295 in free list (150 min, 500 max allowed) 23745 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) Jumbo buffers, 9240 bytes (total 200, permanent 200): 200 in free list (0 min, 200 max allowed) 0 hits, 0 misses IPC Medium buffers, 16384 bytes (total 2, permanent 2): 2 in free list (1 min, 8 max allowed) 0 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) IPC Large buffers, 65535 bytes (total 2, permanent 2, peak 17 @ 2d01h): 2 in free list (1 min, 8 max allowed) 0 hits, 0 misses, 1 trims, 1 created 0 failures (0 no memory) Header pools:
and show proc cpu:
CPU utilization for five seconds: 61%/18%; one minute: 69%; five minutes: 69% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 1 0 67 0 0.00% 0.00% 0.00% 0 Chunk Manager 2 17452 35656 489 0.00% 0.00% 0.00% 0 Load Meter 3 76 67 1134 0.00% 0.00% 0.00% 0 hulc_entropy_thr 4 0 1 0 0.00% 0.00% 0.00% 0 Connection Mgr 5 4303714 179740 23944 0.00% 1.53% 1.87% 0 Check heaps 6 201 140 1435 0.00% 0.00% 0.00% 0 Pool Manager 7 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro 8 0 2 0 0.00% 0.00% 0.00% 0 Timers 9 1096 25818 42 0.00% 0.00% 0.00% 0 WATCH_AFS 10 427 12 35583 0.00% 0.00% 0.00% 0 License Client N 11 706138 10597 66635 0.00% 0.51% 0.33% 0 Licensing Auto U 12 177 14 12642 0.00% 0.00% 0.00% 0 Image License br 13 4603062 2868748 1604 2.07% 1.95% 2.03% 0 ARP Input 14 222152 184637 1203 0.00% 0.07% 0.10% 0 ARP Background 15 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API 16 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT 17 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager 18 33 6 5500 0.00% 0.00% 0.00% 0 Entity MIB API 19 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage 20 2626 35394 74 0.00% 0.00% 0.00% 0 IPC Event Notifi 21 9967 172133 57 0.00% 0.00% 0.00% 0 IPC Mcast Pendin 22 118 2973 39 0.00% 0.00% 0.00% 0 IPC Dynamic Cach 23 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv 24 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager 25 11166 172130 64 0.00% 0.00% 0.00% 0 IPC Periodic Tim 26 10344 172131 60 0.00% 0.01% 0.00% 0 IPC Deferred Por 27 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve 28 1644 11873 138 0.00% 0.00% 0.00% 0 IPC Seat Manager 29 470 10184 46 0.00% 0.00% 0.00% 0 IPC Check Queue 30 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat RX Cont 31 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont 32 617 17836 34 0.00% 0.00% 0.00% 0 IPC Keep Alive M 33 2804 35604 78 0.00% 0.00% 0.00% 0 IPC Loadometer 34 42 4 10500 0.00% 0.00% 0.00% 0 PrstVbl 35 0 1 0 0.00% 0.00% 0.00% 0 Crash writer 36 0 1 0 0.00% 0.00% 0.00% 0 Exception contro 37 0 1 0 0.00% 0.00% 0.00% 0 License IPC stat 38 0 1 0 0.00% 0.00% 0.00% 0 License IPC serv 39 9393 178272 52 0.00% 0.00% 0.00% 0 GraphIt 40 192548 11679 16486 0.00% 0.00% 0.00% 0 crypto sw pk pro 41 0 2 0 0.00% 0.00% 0.00% 0 SMART 42 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client 43 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop 44 8147 176119 46 0.00% 0.00% 0.00% 0 Dynamic ARP Insp 45 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd 46 216118 509835 423 0.15% 0.15% 0.14% 0 Net Background 47 8 3 2666 0.00% 0.00% 0.00% 0 IDB Work 48 4583 37797 121 0.00% 0.00% 0.00% 0 Logger 49 11390 176058 64 0.15% 0.01% 0.00% 0 TTY Background 50 0 3 0 0.00% 0.00% 0.00% 0 CTS CORE 51 81 105 771 0.00% 0.00% 0.00% 0 SXP CORE 52 8 26 307 0.00% 0.00% 0.00% 0 IF-MGR control p 53 32 535 59 0.00% 0.00% 0.00% 0 IF-MGR event pro 54 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest 55 0 3 0 0.00% 0.00% 0.00% 0 IP Admission HA 56 16 95 168 0.00% 0.00% 0.00% 0 Net Input 57 75847 35656 2127 0.00% 0.06% 0.03% 0 Compute load avg 58 165358 5238 31568 0.00% 0.05% 0.05% 0 Per-minute Jobs 59 424933 178334 2382 0.00% 0.19% 0.20% 0 Per-Second Jobs 60 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 61 73732 827196 89 0.00% 0.05% 0.01% 0 Transport Port A 62 73664 52914 1392 0.15% 0.04% 0.01% 0 HC Counter Timer 63 0 1 0 0.00% 0.00% 0.00% 0 SFF8472 64 0 47 0 0.00% 0.00% 0.00% 0 EEM ED Identity 65 0 93 0 0.00% 0.00% 0.00% 0 EEM ED MAT 66 1325 9846 134 0.00% 0.00% 0.00% 0 EEM ED ND 67 35 82 426 0.00% 0.00% 0.00% 0 USB Startup 68 128486 3316840 38 0.00% 0.07% 0.04% 0 DownWhenLooped 69 0 1 0 0.00% 0.00% 0.00% 0 HULC PBR Tcam Me 70 0 1 0 0.00% 0.00% 0.00% 0 HULC ACL Tcam Me 71 0 1 0 0.00% 0.00% 0.00% 0 Hulc Warm Upgrad 72 0 1 0 0.00% 0.00% 0.00% 0 HRPC hdwl reques 73 0 1 0 0.00% 0.00% 0.00% 0 Hulc EEM Process 74 0 1 0 0.00% 0.00% 0.00% 0 HRPC lpip reques 75 0 2 0 0.00% 0.00% 0.00% 0 HLPIP Sync Proce 76 0 1 0 0.00% 0.00% 0.00% 0 HRPC Multi-FS Sy 77 0 11 0 0.00% 0.00% 0.00% 0 HULC multifs pro 78 0 1 0 0.00% 0.00% 0.00% 0 HRPC hnetwpol re 79 0 1 0 0.00% 0.00% 0.00% 0 HRPC EnergyWise 80 0 1 0 0.00% 0.00% 0.00% 0 HRPC actual powe 81 44727 713032 62 0.00% 0.01% 0.00% 0 HUSB Console 82 0 1 0 0.00% 0.00% 0.00% 0 HRPC ipadm reque 83 0 2 0 0.00% 0.00% 0.00% 0 SM RBCP Monitor 84 435 5943 73 0.00% 0.00% 0.00% 0 PSP Timer 85 0 1 0 0.00% 0.00% 0.00% 0 HULC QM Tcam Mem 86 9 2 4500 0.00% 0.00% 0.00% 0 X2 HAMM detect p 87 0 1 0 0.00% 0.00% 0.00% 0 Madmax Process 88 0 1 0 0.00% 0.00% 0.00% 0 HRPC asic-stats 89 2527456 1307468 1933 1.59% 1.34% 1.28% 0 RedEarth I2C dri 90 5457817 870923 6266 2.71% 2.51% 2.45% 0 RedEarth Tx Mana 91 120298 653736 184 0.00% 0.03% 0.03% 0 RedEarth Rx Mana 92 6605 35658 185 0.00% 0.00% 0.00% 0 HULC Thermal Pro 93 0 1 0 0.00% 0.00% 0.00% 0 HRPC hsm request 94 0 8 0 0.00% 0.00% 0.00% 0 Stack Mgr 95 302 13 23230 0.00% 0.00% 0.00% 0 Stack Mgr Notifi 96 1830862 70406 26004 0.79% 0.80% 0.83% 0 Adjust Regions 97 12678 88639 143 0.00% 0.00% 0.00% 0 hrpc -> response 98 8 283 28 0.00% 0.00% 0.00% 0 hrpc -> request 99 14910 29923 498 0.00% 0.00% 0.00% 0 hrpc <- response 100 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcomp reque 101 188751 891227 211 0.15% 0.07% 0.08% 0 yeti2_emac_proce 102 0 11 0 0.00% 0.00% 0.00% 0 HULC Device Mana 103 0 3 0 0.00% 0.00% 0.00% 0 HRPC hdm non blo 104 0 2 0 0.00% 0.00% 0.00% 0 HRPC hdm blockin 105 3533 35384 99 0.00% 0.00% 0.00% 0 HIPC bkgrd proce 106 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process 107 91 891 102 0.00% 0.00% 0.00% 0 Hulc Port-Securi 108 0 1 0 0.00% 0.00% 0.00% 0 HRPC hpsecure re 109 0 1 0 0.00% 0.00% 0.00% 0 HRPC hfbm reques 110 2815 1922 1464 0.00% 0.40% 0.43% 1 SSH Process 111 0 1 0 0.00% 0.00% 0.00% 0 HRPC hlfm reques 112 1077374 4262786 252 0.79% 0.49% 0.49% 0 HLFM address lea 113 18345 176066 104 0.00% 0.01% 0.00% 0 HLFM aging proce 114 411249 4263600 96 0.47% 0.16% 0.17% 0 HLFM address ret 115 0 1 0 0.00% 0.00% 0.00% 0 HRPC hrcmd reque 116 0 9 0 0.00% 0.00% 0.00% 0 HRPC emac reques 117 8 6 1333 0.00% 0.00% 0.00% 0 HULC EMAC Proces 118 0 1 0 0.00% 0.00% 0.00% 0 HRPC isis reques 119 60 89 674 0.00% 0.00% 0.00% 0 HRPC hulc misc r 120 5010 59260 84 0.00% 0.00% 0.00% 0 HVLAN main bkgrd 121 0 2 0 0.00% 0.00% 0.00% 0 HVLAN Mapped Vla 122 0 2 0 0.00% 0.00% 0.00% 0 Vlan shutdown Pr PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 123 0 3 0 0.00% 0.00% 0.00% 0 HRPC vlan reques 124 0 1 0 0.00% 0.00% 0.00% 0 HULC VLAN REF Ba 125 68 2973 22 0.00% 0.00% 0.00% 0 hulc_xps_process 126 8 1 8000 0.00% 0.00% 0.00% 0 HRPC ilp request 127 82191 11870 6924 0.00% 0.03% 0.00% 0 Strider Tcam Mem 128 0 1 0 0.00% 0.00% 0.00% 0 HULC PM Vector P 129 0 1 0 0.00% 0.00% 0.00% 0 HPM Msg Retry Pr 130 0 1 0 0.00% 0.00% 0.00% 0 LICENSE AGENT 131 68197 867466 78 0.31% 0.03% 0.00% 0 hpm main process 132 119 774 153 0.00% 0.00% 0.00% 0 HPM Stack Sync P 133 0 1 0 0.00% 0.00% 0.00% 0 HRPC pm request 134 0 4 0 0.00% 0.00% 0.00% 0 HPM if_num mappi 135 5179204 178277 29051 1.91% 2.41% 2.44% 0 hpm counter proc 136 0 1 0 0.00% 0.00% 0.00% 0 HRPC pm-counters 137 0 3 0 0.00% 0.00% 0.00% 0 hpm vp events ca 138 10476 176482 59 0.00% 0.00% 0.00% 0 Hulc CTS Process 139 0 1 0 0.00% 0.00% 0.00% 0 HRPC cts request 140 0 1 0 0.00% 0.00% 0.00% 0 HULC Msg Retry P 141 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcmp reques 142 541 425 1272 0.00% 0.00% 0.00% 0 HCEF ADJ Refresh 143 0 1 0 0.00% 0.00% 0.00% 0 hl3md_rpfq_thrl_ 144 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl3mm ipv6 145 7789 121528 64 0.00% 0.00% 0.00% 0 hl3mm_mfib_ipv6 146 2888 88628 32 0.00% 0.00% 0.00% 0 hl3mm_mrib_rp 147 3441 88628 38 0.00% 0.00% 0.00% 0 hl3mm_rp 148 0 1 0 0.00% 0.00% 0.00% 0 HACL Queue Proce 149 0 1 0 0.00% 0.00% 0.00% 0 HRPC acl request 150 33 237 139 0.00% 0.00% 0.00% 0 HACL Acl Manager 151 0 1 0 0.00% 0.00% 0.00% 0 HRPC aim request 152 0 3 0 0.00% 0.00% 0.00% 0 HRPC axiom-mgmt 153 4018 88625 45 0.00% 0.00% 0.00% 0 Hulc Axiom Mgmt 154 0 1 0 0.00% 0.00% 0.00% 0 HRPC backup inte 155 81005 1655255 48 0.00% 0.01% 0.00% 0 OBFL TEMP obfl0 156 0 1 0 0.00% 0.00% 0.00% 0 HRPC cdp request 157 0 1 0 0.00% 0.00% 0.00% 0 HULC CISP Proces 158 0 1 0 0.00% 0.00% 0.00% 0 HRPC dot1x reque 159 0 1 0 0.00% 0.00% 0.00% 0 Dot1X Msg Retry 160 8 3 2666 0.00% 0.00% 0.00% 0 HULC DOT1X Proce 161 0 1 0 0.00% 0.00% 0.00% 0 HRPC foxhound re 162 0 2 0 0.00% 0.00% 0.00% 0 Hulc Foxhound Pr 163 0 1 0 0.00% 0.00% 0.00% 0 HRPC lldp reques 164 0 2 0 0.00% 0.00% 0.00% 0 MACsec Process 165 0 1 0 0.00% 0.00% 0.00% 0 HRPC macsec requ 166 0 1 0 0.00% 0.00% 0.00% 0 HRPC system mtu 167 0 1 0 0.00% 0.00% 0.00% 0 HRPC rep request 168 0 3 0 0.00% 0.00% 0.00% 0 REP Helper Proc 169 0 1 0 0.00% 0.00% 0.00% 0 HRPC sdm request 170 0 1 0 0.00% 0.00% 0.00% 0 SMI MSG Retry Pr 171 0 1 0 0.00% 0.00% 0.00% 0 HRPC Smart Insta 172 119092 867126 137 0.15% 0.03% 0.03% 0 Hulc Storm Contr 173 0 2 0 0.00% 0.00% 0.00% 0 HSTP Sync Proces 174 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_cli req 175 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_state_s 176 0 2 0 0.00% 0.00% 0.00% 0 S/W Bridge Proce 177 0 1 0 0.00% 0.00% 0.00% 0 HRPC hudld reque 178 0 1 0 0.00% 0.00% 0.00% 0 HRPC vqpc reques 179 0 1 0 0.00% 0.00% 0.00% 0 HRPC iec_load_ba 180 6875 176080 39 0.00% 0.00% 0.00% 0 IEC Load balance 181 0 1 0 0.00% 0.00% 0.00% 0 HRPC l2pt qnq rp 182 0 1 0 0.00% 0.00% 0.00% 0 HRPC hled reques 183 42321965 4369231 9686 18.55% 17.98% 17.82% 0 Hulc LED Process 184 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl3mm reque PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 185 8556 121495 70 0.00% 0.00% 0.00% 0 hl3mm 186 339835 442885 767 0.15% 0.21% 0.19% 0 HL3U bkgrd proce 187 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl3u reques 188 13844 40668 340 0.00% 0.00% 0.00% 0 HIPV6 bkgrd proc 189 0 1 0 0.00% 0.00% 0.00% 0 HRPC IPv6 Unicas 190 2775 40811 67 0.00% 0.00% 0.00% 0 HL3U PBR bkgrd p 191 244 1489 163 0.00% 0.00% 0.00% 0 HL3U PBR n-h res 192 0 1 0 0.00% 0.00% 0.00% 0 HRPC obfl reques 194 0 1 0 0.00% 0.00% 0.00% 0 HRPC dtp request 195 0 1 0 0.00% 0.00% 0.00% 0 HRPC hmedianet p 196 0 1 0 0.00% 0.00% 0.00% 0 HRPC show_forwar 197 0 1 0 0.00% 0.00% 0.00% 0 HRPC snmp reques 198 0 1 0 0.00% 0.00% 0.00% 0 HULC SNMP Proces 199 998923 35400 28218 0.31% 0.41% 0.43% 0 HQM Stack Proces 200 187153 70976 2636 0.00% 0.05% 0.08% 0 HRPC qos request 201 0 1 0 0.00% 0.00% 0.00% 0 HRPC span reques 202 8 7 1142 0.00% 0.00% 0.00% 0 HRPC system post 203 0 1 0 0.00% 0.00% 0.00% 0 Hulc Reload Mana 204 0 1 0 0.00% 0.00% 0.00% 0 HRPC hrcli-event 205 57 991 57 0.00% 0.00% 0.00% 0 HCMP sync proces 206 0 2 0 0.00% 0.00% 0.00% 0 image mgr 207 0 1 0 0.00% 0.00% 0.00% 0 HRFS OIR Proc 208 32 9 3555 0.00% 0.00% 0.00% 0 HL2MCM 209 42 9 4666 0.00% 0.00% 0.00% 0 HL2MCM 210 0 4 0 0.00% 0.00% 0.00% 0 Hulc SM10G Infra 211 53 176 301 0.00% 0.00% 0.00% 0 AAA Server 212 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc 213 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr 214 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct 215 0 1 0 0.00% 0.00% 0.00% 0 AUTH POLICY Fram 216 17122 173671 98 0.00% 0.00% 0.00% 0 Auth Manager 217 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B 218 60 595 100 0.00% 0.00% 0.00% 0 IP Admin SM Proc 219 136111 102102 1333 0.00% 0.08% 0.06% 0 CDP Protocol 220 893 389 2295 0.00% 0.00% 0.00% 0 SpanTree Helper 221 847774 270949 3128 0.47% 0.39% 0.41% 0 CEF: IPv4 proces 222 0 2 0 0.00% 0.00% 0.00% 0 CMD HANDLER 223 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R 224 153 1486 102 0.00% 0.00% 0.00% 0 DHCP Snooping 225 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping db 226 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces 227 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework 228 0 1 0 0.00% 0.00% 0.00% 0 EAP Test 229 0 2 0 0.00% 0.00% 0.00% 0 EAPoUDP Process 230 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba 231 27454 7291 3765 0.00% 0.01% 0.00% 0 IP ARP Adjacency 232 412400 4262723 96 0.15% 0.16% 0.16% 0 IP ARP Retry Age 233 5662402 5835989 970 1.91% 1.80% 2.01% 0 IP Input 234 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl 235 20867 341417 61 0.00% 0.00% 0.00% 0 IP ARP Track 236 4145 176627 23 0.00% 0.00% 0.00% 0 fnvRootHubPortSt 237 0 1 0 0.00% 0.00% 0.00% 0 tHUB 238 113741 1723455 65 0.00% 0.04% 0.04% 0 MDFS MFIB Proces 239 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process 240 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces 241 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA 242 0 2 0 0.00% 0.00% 0.00% 0 MKA 243 16 19 842 0.00% 0.00% 0.00% 6 Virtual Exec 244 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha 245 0 3 0 0.00% 0.00% 0.00% 0 SMI Director DB 246 1487 8919 166 0.00% 0.00% 0.00% 0 SMI CDP Update H 247 0 1 0 0.00% 0.00% 0.00% 0 SMI Backup Proce PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 248 16 66 242 0.00% 0.00% 0.00% 0 hulc cfg mgr mas 249 0 1 0 0.00% 0.00% 0.00% 0 SMI IBC client p 250 0 2 0 0.00% 0.00% 0.00% 0 SMI IBC Download 251 711224 1019238 697 0.15% 0.24% 0.26% 0 Spanning Tree 252 132 2973 44 0.00% 0.00% 0.00% 0 Spanning Tree St 253 0 2 0 0.00% 0.00% 0.00% 0 CDP Forward Proc 254 17637 687 25672 0.00% 0.00% 0.00% 0 802.1x switch 255 0 1 0 0.00% 0.00% 0.00% 0 802.1x Webauth F 256 106433 134101 793 0.00% 0.01% 0.01% 0 DTP Protocol 257 0 1 0 0.00% 0.00% 0.00% 0 HRPC IPv6 Host r 258 4600 35385 129 0.00% 0.00% 0.00% 0 IPv6 Platform Ho 259 0 1 0 0.00% 0.00% 0.00% 0 axiom-module cra 260 0 1 0 0.00% 0.00% 0.00% 0 HRPC dai request 261 4130594 2987794 1382 0.31% 1.91% 2.02% 0 HULC DAI Process 262 0 1 0 0.00% 0.00% 0.00% 0 HRPC power down 263 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip device t 264 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip source g 265 0 1 0 0.00% 0.00% 0.00% 0 HULC IP Source g 266 0 1 0 0.00% 0.00% 0.00% 0 HRPC sisf reques 267 0 2 0 0.00% 0.00% 0.00% 0 HULC SISF Proces 268 0 1 0 0.00% 0.00% 0.00% 0 HULC SISF Source 269 200741 176045 1140 0.00% 0.09% 0.11% 0 PI MATM Aging Pr 270 233179 1782325 130 0.00% 0.08% 0.08% 0 UDLD 271 187 5943 31 0.00% 0.00% 0.00% 0 Port-Security 272 0 2 0 0.00% 0.00% 0.00% 0 Switch Backup In 273 102 466 218 0.00% 0.00% 0.00% 0 IP Host Track Pr 274 0 1 0 0.00% 0.00% 0.00% 0 Link State Group 275 156 2971 52 0.00% 0.00% 0.00% 0 MMN bkgrd proces 276 856 17809 48 0.00% 0.00% 0.00% 0 Ethchnl 277 254 336 755 0.00% 0.00% 0.00% 0 VMATM Callback 278 0 1 0 0.00% 0.00% 0.00% 0 IPC UDP Input 279 590 3628 162 0.00% 0.00% 0.00% 0 CEF background p 280 0 1 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e 281 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP 282 0 1 0 0.00% 0.00% 0.00% 0 CEF RF HULC Conv 283 0 1 0 0.00% 0.00% 0.00% 0 XDR background p 284 0 1 0 0.00% 0.00% 0.00% 0 XDR mcast 285 777 17808 43 0.00% 0.00% 0.00% 0 IP ACL XDR LC Ba 286 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back 287 0 1 0 0.00% 0.00% 0.00% 0 XDR mcast rcv 288 116 2971 39 0.00% 0.00% 0.00% 0 XDR RP backgroun 289 0 1 0 0.00% 0.00% 0.00% 0 IPC LC Message H 290 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back 291 354 3604 98 0.00% 0.00% 0.00% 0 ADJ background 292 8 3 2666 0.00% 0.00% 0.00% 0 MDFS LC Process 293 0 1 0 0.00% 0.00% 0.00% 0 Critical Auth 294 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology 295 920 107 8598 0.00% 0.00% 0.00% 0 IP RIB Update 296 0 2 0 0.00% 0.00% 0.00% 0 MRIB Process 297 915814 836491 1094 0.63% 0.85% 0.88% 0 ADJ resolve proc 298 378840 1378166 274 0.31% 0.16% 0.17% 0 TCP Timer 299 383739 813812 471 0.00% 0.19% 0.19% 0 TCP Protocols 300 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers 301 41 600 68 0.00% 0.00% 0.00% 0 HTTP CORE 302 42 2231 18 0.00% 0.00% 0.00% 0 Cluster L2 303 1143 17808 64 0.00% 0.00% 0.00% 0 Cluster RARP 304 2911 25236 115 0.00% 0.00% 0.00% 0 Cluster Base 305 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 306 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 307 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 308 0 3 0 0.00% 0.00% 0.00% 0 Flow Exporter Ti 309 24 590 40 0.00% 0.00% 0.00% 0 MFIB Master back PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 310 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl2mcm igmp 311 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl2mcm mlds 312 0 1 0 0.00% 0.00% 0.00% 0 MRIB RP Proxy 313 0 2 0 0.00% 0.00% 0.00% 0 Multicast Offloa 314 0 8 0 0.00% 0.00% 0.00% 0 RARP Input 315 8 81 98 0.00% 0.00% 0.00% 0 static 316 16 11 1454 0.00% 0.00% 0.00% 0 IPv6 RIB Event H 317 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework 318 6023 17808 338 0.00% 0.00% 0.00% 0 QoS stats proces 319 23148 223505 103 0.00% 0.00% 0.00% 0 BGP Router 320 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Proc 321 0 2 0 0.00% 0.00% 0.00% 0 REP BPA/EPA Proc 322 0 6 0 0.00% 0.00% 0.00% 0 SNMP Timers 323 0 1 0 0.00% 0.00% 0.00% 0 HRPC hwccp reque 324 0 1 0 0.00% 0.00% 0.00% 0 HULC_WCCP_BACKGR 325 0 1 0 0.00% 0.00% 0.00% 0 HRPC dhcp snoopi 326 0 4 0 0.00% 0.00% 0.00% 0 HULC DHCP Snoopi 327 843 8912 94 0.00% 0.00% 0.00% 0 HULC stack power 328 0 1 0 0.00% 0.00% 0.00% 0 HRPC stack power 329 630 535 1177 0.00% 0.00% 0.00% 0 IGMPSN L2MCM 330 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD 331 84 95 884 0.00% 0.00% 0.00% 0 IGMPSN 332 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR 333 0 3 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER 334 729 501 1455 0.00% 0.00% 0.00% 0 MLDSN L2MCM 335 0 1 0 0.00% 0.00% 0.00% 0 MRD 336 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP 337 11637 158 73651 0.00% 0.00% 0.00% 0 NIST rng proc 338 135427 1666370 81 0.15% 0.06% 0.05% 0 MDFS RP process 339 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr 340 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve 341 20552 341421 60 0.00% 0.00% 0.00% 0 Timer Library 342 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA 343 0 3 0 0.00% 0.00% 0.00% 0 LDAP process 344 0 2 0 0.00% 0.00% 0.00% 0 Crypto Support 345 0 1 0 0.00% 0.00% 0.00% 0 IPSECv6 PS Proc 346 40 35 1142 0.00% 0.00% 0.00% 0 Collection proce 347 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA 348 33 176 187 0.00% 0.00% 0.00% 0 LOCAL AAA 349 0 2 0 0.00% 0.00% 0.00% 0 EPM MAIN PROCESS 350 14259 172082 82 0.00% 0.01% 0.00% 0 BGP Scheduler 351 0 2 0 0.00% 0.00% 0.00% 0 TPLUS 352 26073 8908 2926 0.00% 0.01% 0.00% 0 HULC ISM FNF 353 338297 16921 19992 0.00% 5.22% 4.44% 0 hulc running con 354 470 33 14242 0.00% 0.00% 0.00% 0 crypto engine pr 355 23779 177227 134 0.00% 0.00% 0.00% 0 Crypto IKEv2 356 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 AAA handle 357 0 1 0 0.00% 0.00% 0.00% 0 CEF RP IPC Backg 358 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc 359 0 2 0 0.00% 0.00% 0.00% 0 CRYPTO MAP FREE 360 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT 361 0 2 0 0.00% 0.00% 0.00% 0 Crypto IKE Dispa 362 0 3 0 0.00% 0.00% 0.00% 0 Crypto IKMP 363 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key 364 584 8910 65 0.00% 0.00% 0.00% 0 IPSEC key engine 365 8 5 1600 0.00% 0.00% 0.00% 0 Crypto ACL 366 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc 367 0 4 0 0.00% 0.00% 0.00% 0 IPSec background 368 335 202 1658 0.00% 0.00% 0.00% 0 Crypto CA 369 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL 370 0 2 0 0.00% 0.00% 0.00% 0 MMON PROCESS 371 268393 5430281 49 0.15% 0.09% 0.08% 0 MMON MENG PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 372 0 1 0 0.00% 0.00% 0.00% 0 HRPC x_setup req 373 0 2 0 0.00% 0.00% 0.00% 0 REP Switch Helpe 374 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr 375 9 42 214 0.00% 0.00% 0.00% 0 VTP Trap Process 376 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr 377 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector 378 67 984 68 0.00% 0.00% 0.00% 0 ASP Process Crea 379 16413 172678 95 0.00% 0.00% 0.00% 0 AAA SEND STOP EV 380 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client 381 0 2 0 0.00% 0.00% 0.00% 0 DHCP Security He 382 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Routing 383 2485 19365 128 0.00% 0.00% 0.00% 0 EEM ED Syslog 384 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps 385 1034 5941 174 0.00% 0.00% 0.00% 0 URPF stats 386 84 2971 28 0.00% 0.00% 0.00% 0 vlmap logger 387 0 1 0 0.00% 0.00% 0.00% 0 HCD Process 388 0 1 0 0.00% 0.00% 0.00% 0 HRPC cable diagn 389 0 1 0 0.00% 0.00% 0.00% 0 HRPC rsu request 390 34114 96654 352 0.00% 0.00% 0.00% 0 BGP I/O 391 0 2 0 0.00% 0.00% 0.00% 0 DiagCard1/-1 392 0 1 0 0.00% 0.00% 0.00% 0 Online Diag EEM 393 83472 878716 94 0.15% 0.03% 0.00% 0 PM Callback 394 92464 2969 31143 0.00% 0.04% 0.00% 0 BGP Scanner 395 947 14249 66 0.00% 0.01% 0.00% 0 dhcp snooping sw 396 0 3 0 0.00% 0.00% 0.00% 0 BGP Event 397 24 156 153 0.00% 0.00% 0.00% 0 EEM Server 398 25 2 12500 0.00% 0.00% 0.00% 0 Call Home proces 399 0 4 0 0.00% 0.00% 0.00% 0 CTS credentials 400 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc 401 0 27 0 0.00% 0.00% 0.00% 7 Virtual Exec 402 0 2 0 0.00% 0.00% 0.00% 0 EEM ED CLI 403 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Config 404 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Counter 405 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env 406 0 3 0 0.00% 0.00% 0.00% 0 EM ED GOLD 407 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Interface 408 8 3 2666 0.00% 0.00% 0.00% 0 EEM ED IOSWD 409 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla 410 0 3 0 0.00% 0.00% 0.00% 0 EEM ED None 411 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR 412 242 2971 81 0.00% 0.00% 0.00% 0 Call Home Timer 413 0 3 0 0.00% 0.00% 0.00% 0 EEM ED RPC 414 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP 415 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje 416 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti 417 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test 418 418 4880 85 0.00% 0.00% 0.00% 0 EEM ED Timer 419 3452 18984 181 0.00% 0.00% 0.00% 0 Syslog 420 17 79 215 0.00% 0.00% 0.00% 0 RBM CORE 421 0 1 0 0.00% 0.00% 0.00% 0 HRPC eee request 422 0 2 0 0.00% 0.00% 0.00% 0 STP FAST TRANSIT 423 0 2 0 0.00% 0.00% 0.00% 0 CSRT RAPID TRANS 424 25 10 2500 0.00% 0.00% 0.00% 0 VLAN Manager 425 17 101 168 0.00% 0.00% 0.00% 0 SSH Event handle 426 373 3408 109 0.00% 0.00% 0.00% 0 IP Background 427 250 734 340 0.00% 0.00% 0.00% 0 IP Connected Rou 428 7421 88260 84 0.00% 0.00% 0.00% 0 CEF: IPv6 proces 429 167068 600921 278 0.15% 0.05% 0.05% 0 LACP Protocol 430 8 5 1600 0.00% 0.00% 0.00% 0 IPv6 IDB 431 2169 23637 91 0.00% 0.00% 0.00% 0 IPv6 background 432 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Address 433 18787 39775 472 0.00% 0.01% 0.00% 0 IPv6 Input PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 434 5450 21567 252 0.00% 0.00% 0.00% 0 IPv6 ND 435 69081 713060 96 0.15% 0.03% 0.00% 0 MLD 436 8 21 380 0.00% 0.00% 0.00% 0 BGP Task 437 2858 11871 240 0.00% 0.00% 0.00% 0 MDFS LC Download 438 0 3 0 0.00% 0.00% 0.00% 0 TCP Listener 439 301551 561197 537 0.00% 0.08% 0.10% 0 IP SNMP 440 63130 281190 224 0.00% 0.01% 0.00% 0 PDU DISPATCHER 441 256768 281232 913 0.00% 0.07% 0.09% 0 SNMP ENGINE 442 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6 443 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro 444 8 4 2000 0.00% 0.00% 0.00% 0 SNMP Traps 445 81079 1655251 48 0.00% 0.01% 0.00% 0 OBFL UPTIME obfl 446 134 4 33500 0.00% 0.00% 0.00% 0 OBFL MSG obfl0 447 69 4 17250 0.00% 0.00% 0.00% 0 OBFL ENV obfl0 448 80087 1655262 48 0.00% 0.01% 0.00% 0 OBFL VOLT obfl0 449 776 11842 65 0.00% 0.00% 0.00% 0 OBFL I/O Buffer 450 17 30 566 0.00% 0.00% 0.00% 8 Virtual Exec 451 0 2 0 0.00% 0.00% 0.00% 9 Virtual Exec 452 0 10 0 0.00% 0.00% 0.00% 10 Virtual Exec 453 0 1 0 0.00% 0.00% 0.00% 12 Virtual Exec 454 0 5 0 0.00% 0.00% 0.00% 11 Virtual Exec 458 0 2 0 0.00% 0.00% 0.00% 16 Virtual Exec
10-21-2018 04:46 AM
your CPU is consistently above 60 percent. I think with all the stuff configured including BGP your switch is not capable of handling that amount of traffic.
Either way, try to adjust the buffers as below (you can copy and paste the entire string). Not sure this will help. I would look at either offloading some of the traffic, or getting a higher scale model...
davidx(config)#buffers small permanent 150
davidx(config)#buffers small min-free 60
davidx(config)#buffers small max-free 300
davidx(config)#buffers middle permanent 100
davidx(config)#buffers middle min-free 30
davidx(config)#buffers middle max-free 300
davidx(config)#buffers big permanent 150
davidx(config)#buffers big min-free 30
davidx(config)#buffers big max-free 300
davidx(config)#buffers verybig permanent 60
davidx(config)#buffers verybig min-free 30
davidx(config)#buffers verybig max-free 75
davidx(config)#buffers large permanent 10
davidx(config)#buffers large min-free 4
davidx(config)#buffers large max-free 10
davidx(config)#buffers huge permanent 10
davidx(config)#buffers huge min-free 4
davidx(config)#buffers huge max-free 10
10-21-2018 07:16 AM
still experience output drops after applying this
Gi1/0/40 0 0 0 0 0 535
Gi1/0/41 0 0 0 0 0 0
Gi1/0/42 0 0 0 0 0 0
Gi1/0/43 0 0 0 0 0 0
Gi1/0/44 0 0 0 0 0 0
Gi1/0/45 0 0 0 0 0 0
Gi1/0/46 0 0 0 0 0 0
Gi1/0/47 0 0 0 0 0 0
Gi1/0/48 0 0 0 0 0 0
Po10 0 0 0 0 0 535
davidx(config)#buffers small permanent 150 davidx(config)#buffers small min-free 60 davidx(config)#buffers small max-free 300 davidx(config)#buffers middle permanent 100 davidx(config)#buffers middle min-free 30 davidx(config)#buffers middle max-free 300 davidx(config)#buffers big permanent 150 davidx(config)#buffers big min-free 30 davidx(config)#buffers big max-free 300 davidx(config)#buffers verybig permanent 60 davidx(config)#buffers verybig min-free 30 davidx(config)#buffers verybig max-free 75 davidx(config)#buffers large permanent 10 davidx(config)#buffers large min-free 4 davidx(config)#buffers large max-free 10 davidx(config)#buffers huge permanent 10 davidx(config)#buffers huge min-free 4 davidx(config)#buffers huge max-free 10
10-21-2018 08:31 AM - edited 10-21-2018 08:33 AM
post the output of 'show buffers' again now you have applied the new values...
show mls qos queue-set
show mls qos maps dscp-output-q
10-21-2018 01:24 PM
show buffers:
Buffer elements: 1624 in free list (500 max allowed) 35031893 hits, 0 misses, 1641 created Public buffer pools: Small buffers, 104 bytes (total 187, permanent 150, peak 191 @ 2d12h): 163 in free list (60 min, 300 max allowed) 13260598 hits, 522 misses, 1283 trims, 1320 created 0 failures (0 no memory) Middle buffers, 600 bytes (total 100, permanent 100, peak 128 @ 06:16:04): 95 in free list (30 min, 300 max allowed) 1587516 hits, 208 misses, 391 trims, 391 created 9 failures (0 no memory) Big buffers, 1536 bytes (total 150, permanent 150, peak 185 @ 2d12h): 123 in free list (30 min, 300 max allowed) 2304972 hits, 133 misses, 367 trims, 367 created 8 failures (0 no memory) VeryBig buffers, 4520 bytes (total 65, permanent 60, peak 65 @ 06:15:38): 50 in free list (30 min, 75 max allowed) 75 hits, 10 misses, 16 trims, 21 created 7 failures (0 no memory) Large buffers, 5024 bytes (total 10, permanent 10): 10 in free list (4 min, 10 max allowed) 1 hits, 6 misses, 16 trims, 16 created 6 failures (0 no memory) Huge buffers, 18024 bytes (total 10, permanent 10): 10 in free list (4 min, 10 max allowed) 2 hits, 5 misses, 16 trims, 16 created 5 failures (0 no memory) Interface buffer pools: Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 2d12h): 101 in free list (132 min, 132 max allowed) 27096 hits, 0 misses FastEthernet0-Physical buffers, 1524 bytes (total 32, permanent 32): 8 in free list (0 min, 32 max allowed) 24 hits, 0 fallbacks 8 max cache size, 8 in cache 0 hits in cache, 0 misses in cache RxQ1 buffers, 2040 bytes (total 384, permanent 384): 1 in free list (0 min, 384 max allowed) 241996 hits, 904 fallbacks RxQ2 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 128 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) RxQ3 buffers, 2040 bytes (total 128, permanent 128): 1 in free list (0 min, 128 max allowed) 13645713 hits, 1906561 fallbacks RxQ4 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 18235 hits, 721812 misses RxQ5 buffers, 2040 bytes (total 128, permanent 128): 64 in free list (0 min, 128 max allowed) 64 hits, 0 misses RxQ6 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 3148188 hits, 35227867 misses RxQ7 buffers, 2040 bytes (total 1200, permanent 1200): 330 in free list (0 min, 1200 max allowed) 6364669 hits, 594 misses RxQ8 buffers, 2040 bytes (total 64, permanent 64): 0 in free list (0 min, 64 max allowed) 279750 hits, 8954243 misses RxQ9 buffers, 2040 bytes (total 1, permanent 1): 0 in free list (0 min, 1 max allowed) 1 hits, 0 misses RxQ10 buffers, 2040 bytes (total 64, permanent 64): 1 in free list (0 min, 64 max allowed) 1464345 hits, 23215 fallbacks RxQ11 buffers, 2040 bytes (total 16, permanent 16): 1 in free list (0 min, 16 max allowed) 911404446 hits, 914156306 misses RxQ12 buffers, 2040 bytes (total 96, permanent 96): 0 in free list (0 min, 96 max allowed) 96 hits, 0 misses RxQ13 buffers, 2040 bytes (total 16, permanent 16): 0 in free list (0 min, 16 max allowed) 16 hits, 0 misses RxQ15 buffers, 2040 bytes (total 4, permanent 4): 0 in free list (0 min, 4 max allowed) 4190816 hits, 4190812 misses HRPCRespFallback buffers, 1500 bytes (total 80, permanent 80): 80 in free list (0 min, 80 max allowed) 0 hits, 0 misses RxQFB buffers, 2040 bytes (total 904, permanent 904): 900 in free list (0 min, 904 max allowed) 2287192 hits, 0 misses RxQ0 buffers, 2040 bytes (total 1200, permanent 1200): 700 in free list (0 min, 1200 max allowed) 500 hits, 0 misses IPC buffers, 2048 bytes (total 300, permanent 300): 295 in free list (150 min, 500 max allowed) 28941 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) Jumbo buffers, 9240 bytes (total 200, permanent 200): 200 in free list (0 min, 200 max allowed) 0 hits, 0 misses IPC Medium buffers, 16384 bytes (total 2, permanent 2): 2 in free list (1 min, 8 max allowed) 0 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) IPC Large buffers, 65535 bytes (total 2, permanent 2, peak 17 @ 2d12h): 2 in free list (1 min, 8 max allowed) 0 hits, 0 misses, 1 trims, 1 created 0 failures (0 no memory) Header pools:
Queueset: 1 Queue : 1 2 3 4 ---------------------------------------------- buffers : 20 50 15 15 threshold1: 3200 3200 3200 3200 threshold2: 3200 3200 3200 3200 reserved : 20 20 20 20 maximum : 3200 3200 3200 3200 Queueset: 2 Queue : 1 2 3 4 ---------------------------------------------- buffers : 25 25 25 25 threshold1: 100 200 100 100 threshold2: 100 200 100 100 reserved : 50 50 50 50 maximum : 400 400 400 400
Dscp-outputq-threshold map: d1 :d2 0 1 2 3 4 5 6 7 8 9 ------------------------------------------------------------ 0 : 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 1 : 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 2 : 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 3 : 02-03 02-03 01-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 4 : 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 5 : 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 6 : 02-03 02-03 02-03 02-03
10-21-2018 01:32 PM
increase the buffers until you don't see any misses. This is pretty much trial and error, I would first double the values that you currently have:
davidx(config)#buffers small permanent 300
davidx(config)#buffers small min-free 120
davidx(config)#buffers small max-free 600
davidx(config)#buffers middle permanent 200
davidx(config)#buffers middle min-free 60
davidx(config)#buffers middle max-free 600
davidx(config)#buffers big permanent 300
davidx(config)#buffers big min-free 60
davidx(config)#buffers big max-free 600
davidx(config)#buffers verybig permanent 120
davidx(config)#buffers verybig min-free 60
davidx(config)#buffers verybig max-free 150
davidx(config)#buffers large permanent 20
davidx(config)#buffers large min-free 8
davidx(config)#buffers large max-free 20
davidx(config)#buffers huge permanent 20
davidx(config)#buffers huge min-free 8
davidx(config)#buffers huge max-free 20
10-21-2018 10:42 PM
after increasing buffers:
Buffer elements: 1624 in free list (500 max allowed) 39816009 hits, 0 misses, 1641 created Public buffer pools: Small buffers, 104 bytes (total 301, permanent 300, peak 301 @ 08:49:29): 276 in free list (120 min, 600 max allowed) 15226463 hits, 522 misses, 1319 trims, 1320 created 0 failures (0 no memory) Middle buffers, 600 bytes (total 200, permanent 200): 196 in free list (60 min, 600 max allowed) 1817309 hits, 208 misses, 391 trims, 391 created 9 failures (0 no memory) Big buffers, 1536 bytes (total 300, permanent 300): 300 in free list (60 min, 600 max allowed) 2662810 hits, 133 misses, 367 trims, 367 created 8 failures (0 no memory) VeryBig buffers, 4520 bytes (total 125, permanent 120, peak 125 @ 08:48:45): 110 in free list (60 min, 150 max allowed) 75 hits, 10 misses, 16 trims, 21 created 7 failures (0 no memory) Large buffers, 5024 bytes (total 20, permanent 20): 20 in free list (8 min, 20 max allowed) 1 hits, 6 misses, 16 trims, 16 created 6 failures (0 no memory) Huge buffers, 18024 bytes (total 20, permanent 20): 20 in free list (8 min, 20 max allowed) 2 hits, 5 misses, 16 trims, 16 created 5 failures (0 no memory) Interface buffer pools: Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 2d21h): 101 in free list (132 min, 132 max allowed) 33685 hits, 0 misses FastEthernet0-Physical buffers, 1524 bytes (total 32, permanent 32): 8 in free list (0 min, 32 max allowed) 24 hits, 0 fallbacks 8 max cache size, 8 in cache 0 hits in cache, 0 misses in cache RxQ1 buffers, 2040 bytes (total 384, permanent 384): 1 in free list (0 min, 384 max allowed) 279259 hits, 1040 fallbacks RxQ2 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 128 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) RxQ3 buffers, 2040 bytes (total 128, permanent 128): 3 in free list (0 min, 128 max allowed) 15749936 hits, 2194561 fallbacks RxQ4 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 21025 hits, 828484 misses RxQ5 buffers, 2040 bytes (total 128, permanent 128): 64 in free list (0 min, 128 max allowed) 64 hits, 0 misses RxQ6 buffers, 2040 bytes (total 128, permanent 128): 0 in free list (0 min, 128 max allowed) 3694960 hits, 35774695 misses RxQ7 buffers, 2040 bytes (total 1200, permanent 1200): 305 in free list (0 min, 1200 max allowed) 7277113 hits, 613 misses RxQ8 buffers, 2040 bytes (total 64, permanent 64): 0 in free list (0 min, 64 max allowed) 332371 hits, 10459220 misses RxQ9 buffers, 2040 bytes (total 1, permanent 1): 0 in free list (0 min, 1 max allowed) 1 hits, 0 misses RxQ10 buffers, 2040 bytes (total 64, permanent 64): 1 in free list (0 min, 64 max allowed) 1690202 hits, 26745 fallbacks RxQ11 buffers, 2040 bytes (total 16, permanent 16): 1 in free list (0 min, 16 max allowed) 1048422130 hits, 1051896132 misses RxQ12 buffers, 2040 bytes (total 96, permanent 96): 0 in free list (0 min, 96 max allowed) 96 hits, 0 misses RxQ13 buffers, 2040 bytes (total 16, permanent 16): 0 in free list (0 min, 16 max allowed) 16 hits, 0 misses RxQ15 buffers, 2040 bytes (total 4, permanent 4): 0 in free list (0 min, 4 max allowed) 4836904 hits, 4836900 misses HRPCRespFallback buffers, 1500 bytes (total 80, permanent 80): 80 in free list (0 min, 80 max allowed) 0 hits, 0 misses RxQFB buffers, 2040 bytes (total 904, permanent 904): 898 in free list (0 min, 904 max allowed) 2633574 hits, 0 misses RxQ0 buffers, 2040 bytes (total 1200, permanent 1200): 700 in free list (0 min, 1200 max allowed) 500 hits, 0 misses IPC buffers, 2048 bytes (total 300, permanent 300): 295 in free list (150 min, 500 max allowed) 33403 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) Jumbo buffers, 9240 bytes (total 200, permanent 200): 200 in free list (0 min, 200 max allowed) 0 hits, 0 misses IPC Medium buffers, 16384 bytes (total 2, permanent 2): 2 in free list (1 min, 8 max allowed) 0 hits, 0 fallbacks, 0 trims, 0 created 0 failures (0 no memory) IPC Large buffers, 65535 bytes (total 2, permanent 2, peak 17 @ 2d21h): 2 in free list (1 min, 8 max allowed) 0 hits, 0 misses, 1 trims, 1 created 0 failures (0 no memory) Header pools:
10-21-2018 05:53 AM
Hello
My first thought when i viewed your configuration is you have process switching enabled and then you also so high cpu interrupt percentage - This suggests your switch to busy processing network traffic.
Possible enable fast/cef switching in the interim to see if this negates you high cpu utilization
int vlan x/x
ip route-cache
or
ip route-cache cef
Can you also post the post the output of :
sh process cpu sorted 5sec
10-21-2018 07:06 AM
this with route-cache enabled
show proc cpu sorted 5sec :
CPU utilization for five seconds: 84%/20%; one minute: 75%; five minutes: 67% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 183 46232327 4766478 9699 20.44% 20.08% 19.50% 0 Hulc LED Process 5 4716240 196880 23954 9.42% 2.01% 1.98% 0 Check heaps 13 5018570 3123937 1606 3.83% 2.16% 2.03% 0 ARP Input 233 6087064 6271654 970 3.03% 2.79% 2.17% 0 IP Input 261 4540040 3253081 1395 2.55% 2.15% 2.09% 0 HULC DAI Process 135 5688657 194541 29241 2.39% 2.41% 2.41% 0 hpm counter proc 90 5974041 950494 6285 2.39% 2.31% 2.38% 0 RedEarth Tx Mana 297 1080247 972155 1111 1.11% 0.78% 0.76% 0 ADJ resolve proc 89 2792666 1426759 1957 0.79% 1.06% 1.13% 0 RedEarth I2C dri 112 1197804 4646891 257 0.79% 0.52% 0.56% 0 HLFM address lea 96 2001708 76828 26054 0.79% 0.83% 0.81% 0 Adjust Regions 110 10298 5376 1915 0.63% 5.08% 2.00% 1 SSH Process 199 1093512 38627 28309 0.47% 0.41% 0.45% 0 HQM Stack Proces 221 934007 295670 3158 0.47% 0.44% 0.40% 0 CEF: IPv4 proces 68 141715 3618523 39 0.47% 0.07% 0.06% 0 DownWhenLooped 232 460394 4646782 99 0.31% 0.16% 0.18% 0 IP ARP Retry Age 14 245126 201413 1217 0.15% 0.13% 0.12% 0 ARP Background 450 16 22 727 0.15% 0.01% 0.00% 8 Virtual Exec 298 417430 1500187 278 0.15% 0.07% 0.12% 0 TCP Timer 81 49190 778086 63 0.15% 0.02% 0.00% 0 HUSB Console 251 764845 1092123 700 0.15% 0.25% 0.24% 0 Spanning Tree 270 259060 1944925 133 0.15% 0.15% 0.14% 0 UDLD 200 204449 77430 2640 0.15% 0.08% 0.06% 0 HRPC qos request 114 457220 4647767 98 0.15% 0.14% 0.17% 0 HLFM address ret 371 296583 5919634 50 0.15% 0.08% 0.09% 0 MMON MENG 46 241399 564799 427 0.15% 0.12% 0.11% 0 Net Background 188 15558 44380 350 0.15% 0.02% 0.00% 0 HIPV6 bkgrd proc 186 372635 486920 765 0.15% 0.16% 0.16% 0 HL3U bkgrd proce 269 222883 192100 1160 0.15% 0.09% 0.10% 0 PI MATM Aging Pr 238 125108 1880365 66 0.15% 0.09% 0.05% 0 MDFS MFIB Proces 379 17989 187774 95 0.15% 0.01% 0.00% 0 AAA SEND STOP EV 131 74170 946377 78 0.15% 0.02% 0.00% 0 hpm main process 33 3168 38852 81 0.00% 0.00% 0.00% 0 IPC Loadometer 32 717 19463 36 0.00% 0.00% 0.00% 0 IPC Keep Alive M 35 0 1 0 0.00% 0.00% 0.00% 0 Crash writer 31 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont 34 42 4 10500 0.00% 0.00% 0.00% 0 PrstVbl 38 0 1 0 0.00% 0.00% 0.00% 0 License IPC serv 30 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat RX Cont 40 209383 12696 16492 0.00% 0.00% 0.00% 0 crypto sw pk pro 41 0 2 0 0.00% 0.00% 0.00% 0 SMART 29 510 11113 45 0.00% 0.00% 0.00% 0 IPC Check Queue 28 1780 12957 137 0.00% 0.00% 0.00% 0 IPC Seat Manager 27 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve 26 11425 187823 60 0.00% 0.01% 0.00% 0 IPC Deferred Por 25 12105 187824 64 0.00% 0.00% 0.00% 0 IPC Periodic Tim 24 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager 23 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv 36 0 1 0 0.00% 0.00% 0.00% 0 Exception contro 37 0 1 0 0.00% 0.00% 0.00% 0 License IPC stat 51 81 107 757 0.00% 0.00% 0.00% 0 SXP CORE 39 10416 194540 53 0.00% 0.00% 0.00% 0 GraphIt 53 32 547 58 0.00% 0.00% 0.00% 0 IF-MGR event pro 54 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest 42 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client 56 16 137 116 0.00% 0.00% 0.00% 0 Net Input 57 84015 38910 2159 0.00% 0.03% 0.00% 0 Compute load avg 58 181053 5648 32056 0.00% 0.04% 0.05% 0 Per-minute Jobs 59 458671 194601 2356 0.00% 0.12% 0.13% 0 Per-Second Jobs 60 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 61 80841 899563 89 0.00% 0.03% 0.01% 0 Transport Port A 43 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop 44 9154 192179 47 0.00% 0.00% 0.00% 0 Dynamic ARP Insp 64 0 47 0 0.00% 0.00% 0.00% 0 EEM ED Identity 45 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd 66 1409 10677 131 0.00% 0.00% 0.00% 0 EEM ED ND 47 8 3 2666 0.00% 0.00% 0.00% 0 IDB Work 18 33 6 5500 0.00% 0.00% 0.00% 0 Entity MIB API 69 0 1 0 0.00% 0.00% 0.00% 0 HULC PBR Tcam Me 70 0 1 0 0.00% 0.00% 0.00% 0 HULC ACL Tcam Me 48 5429 44173 122 0.00% 0.00% 0.00% 0 Logger 72 0 1 0 0.00% 0.00% 0.00% 0 HRPC hdwl reques 73 0 1 0 0.00% 0.00% 0.00% 0 Hulc EEM Process 49 12844 192118 66 0.00% 0.00% 0.00% 0 TTY Background 75 0 2 0 0.00% 0.00% 0.00% 0 HLPIP Sync Proce 50 0 3 0 0.00% 0.00% 0.00% 0 CTS CORE 52 8 26 307 0.00% 0.00% 0.00% 0 IF-MGR control p 78 0 1 0 0.00% 0.00% 0.00% 0 HRPC hnetwpol re 79 0 1 0 0.00% 0.00% 0.00% 0 HRPC EnergyWise 80 0 1 0 0.00% 0.00% 0.00% 0 HRPC actual powe 20 2912 38622 75 0.00% 0.00% 0.00% 0 IPC Event Notifi 55 0 3 0 0.00% 0.00% 0.00% 0 IP Admission HA 83 0 2 0 0.00% 0.00% 0.00% 0 SM RBCP Monitor 84 493 6485 76 0.00% 0.00% 0.00% 0 PSP Timer 85 0 1 0 0.00% 0.00% 0.00% 0 HULC QM Tcam Mem 86 9 2 4500 0.00% 0.00% 0.00% 0 X2 HAMM detect p 87 0 1 0 0.00% 0.00% 0.00% 0 Madmax Process 22 126 3244 38 0.00% 0.00% 0.00% 0 IPC Dynamic Cach 17 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager 16 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT 91 132710 713382 186 0.00% 0.11% 0.07% 0 RedEarth Rx Mana 92 7338 38911 188 0.00% 0.00% 0.00% 0 HULC Thermal Pro 93 0 1 0 0.00% 0.00% 0.00% 0 HRPC hsm request 94 0 8 0 0.00% 0.00% 0.00% 0 Stack Mgr 95 302 13 23230 0.00% 0.00% 0.00% 0 Stack Mgr Notifi 15 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API 97 13859 96724 143 0.00% 0.00% 0.00% 0 hrpc -> response 98 8 283 28 0.00% 0.00% 0.00% 0 hrpc -> request 99 16552 32628 507 0.00% 0.00% 0.00% 0 hrpc <- response 100 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcomp reque 101 210224 972543 216 0.00% 0.09% 0.08% 0 yeti2_emac_proce 62 81207 57737 1406 0.00% 0.03% 0.00% 0 HC Counter Timer 63 0 1 0 0.00% 0.00% 0.00% 0 SFF8472 65 0 93 0 0.00% 0.00% 0.00% 0 EEM ED MAT 105 3922 38611 101 0.00% 0.00% 0.00% 0 HIPC bkgrd proce 106 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process 107 91 903 100 0.00% 0.00% 0.00% 0 Hulc Port-Securi 108 0 1 0 0.00% 0.00% 0.00% 0 HRPC hpsecure re 67 35 82 426 0.00% 0.00% 0.00% 0 USB Startup 12 177 14 12642 0.00% 0.00% 0.00% 0 Image License br 111 0 1 0 0.00% 0.00% 0.00% 0 HRPC hlfm reques 11 773586 11572 66849 0.00% 0.30% 0.29% 0 Licensing Auto U 113 20144 192123 104 0.00% 0.00% 0.00% 0 HLFM aging proce 71 0 1 0 0.00% 0.00% 0.00% 0 Hulc Warm Upgrad 115 0 1 0 0.00% 0.00% 0.00% 0 HRPC hrcmd reque 116 0 9 0 0.00% 0.00% 0.00% 0 HRPC emac reques 117 8 6 1333 0.00% 0.00% 0.00% 0 HULC EMAC Proces 118 0 1 0 0.00% 0.00% 0.00% 0 HRPC isis reques 119 60 89 674 0.00% 0.00% 0.00% 0 HRPC hulc misc r 120 5529 64665 85 0.00% 0.00% 0.00% 0 HVLAN main bkgrd 121 0 2 0 0.00% 0.00% 0.00% 0 HVLAN Mapped Vla 74 0 1 0 0.00% 0.00% 0.00% 0 HRPC lpip reques PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 123 0 3 0 0.00% 0.00% 0.00% 0 HRPC vlan reques 124 0 1 0 0.00% 0.00% 0.00% 0 HULC VLAN REF Ba 125 77 3244 23 0.00% 0.00% 0.00% 0 hulc_xps_process 126 8 1 8000 0.00% 0.00% 0.00% 0 HRPC ilp request 127 90342 12953 6974 0.00% 0.04% 0.00% 0 Strider Tcam Mem 76 0 1 0 0.00% 0.00% 0.00% 0 HRPC Multi-FS Sy 129 0 1 0 0.00% 0.00% 0.00% 0 HPM Msg Retry Pr 130 0 1 0 0.00% 0.00% 0.00% 0 LICENSE AGENT 77 0 11 0 0.00% 0.00% 0.00% 0 HULC multifs pro 132 119 786 151 0.00% 0.00% 0.00% 0 HPM Stack Sync P 133 0 1 0 0.00% 0.00% 0.00% 0 HRPC pm request 21 11051 187827 58 0.00% 0.00% 0.00% 0 IPC Mcast Pendin 10 427 12 35583 0.00% 0.00% 0.00% 0 License Client N 136 0 1 0 0.00% 0.00% 0.00% 0 HRPC pm-counters 137 0 3 0 0.00% 0.00% 0.00% 0 hpm vp events ca 138 11700 192546 60 0.00% 0.00% 0.00% 0 Hulc CTS Process 139 0 1 0 0.00% 0.00% 0.00% 0 HRPC cts request 140 0 1 0 0.00% 0.00% 0.00% 0 HULC Msg Retry P 141 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcmp reques 142 592 465 1273 0.00% 0.00% 0.00% 0 HCEF ADJ Refresh 82 0 1 0 0.00% 0.00% 0.00% 0 HRPC ipadm reque 88 0 1 0 0.00% 0.00% 0.00% 0 HRPC asic-stats 145 8760 132570 66 0.00% 0.01% 0.00% 0 hl3mm_mfib_ipv6 146 3166 96712 32 0.00% 0.00% 0.00% 0 hl3mm_mrib_rp 147 3794 96712 39 0.00% 0.00% 0.00% 0 hl3mm_rp 148 0 1 0 0.00% 0.00% 0.00% 0 HACL Queue Proce 9 1140 26340 43 0.00% 0.00% 0.00% 0 WATCH_AFS 150 33 237 139 0.00% 0.00% 0.00% 0 HACL Acl Manager 151 0 1 0 0.00% 0.00% 0.00% 0 HRPC aim request 152 0 3 0 0.00% 0.00% 0.00% 0 HRPC axiom-mgmt 153 4334 96709 44 0.00% 0.00% 0.00% 0 Hulc Axiom Mgmt 154 0 1 0 0.00% 0.00% 0.00% 0 HRPC backup inte 155 89598 1805231 49 0.00% 0.03% 0.01% 0 OBFL TEMP obfl0 156 0 1 0 0.00% 0.00% 0.00% 0 HRPC cdp request 157 0 1 0 0.00% 0.00% 0.00% 0 HULC CISP Proces 19 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage 159 0 1 0 0.00% 0.00% 0.00% 0 Dot1X Msg Retry 160 8 3 2666 0.00% 0.00% 0.00% 0 HULC DOT1X Proce 161 0 1 0 0.00% 0.00% 0.00% 0 HRPC foxhound re 162 0 2 0 0.00% 0.00% 0.00% 0 Hulc Foxhound Pr 163 0 1 0 0.00% 0.00% 0.00% 0 HRPC lldp reques 164 0 2 0 0.00% 0.00% 0.00% 0 MACsec Process 165 0 1 0 0.00% 0.00% 0.00% 0 HRPC macsec requ 166 0 1 0 0.00% 0.00% 0.00% 0 HRPC system mtu 167 0 1 0 0.00% 0.00% 0.00% 0 HRPC rep request 168 0 3 0 0.00% 0.00% 0.00% 0 REP Helper Proc 169 0 1 0 0.00% 0.00% 0.00% 0 HRPC sdm request 170 0 1 0 0.00% 0.00% 0.00% 0 SMI MSG Retry Pr 171 0 1 0 0.00% 0.00% 0.00% 0 HRPC Smart Insta 172 131577 946031 139 0.00% 0.05% 0.04% 0 Hulc Storm Contr 173 0 2 0 0.00% 0.00% 0.00% 0 HSTP Sync Proces 174 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_cli req 175 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_state_s 176 0 2 0 0.00% 0.00% 0.00% 0 S/W Bridge Proce 177 0 1 0 0.00% 0.00% 0.00% 0 HRPC hudld reque 178 0 1 0 0.00% 0.00% 0.00% 0 HRPC vqpc reques 179 0 1 0 0.00% 0.00% 0.00% 0 HRPC iec_load_ba 180 7563 192138 39 0.00% 0.00% 0.00% 0 IEC Load balance 181 0 1 0 0.00% 0.00% 0.00% 0 HRPC l2pt qnq rp 182 0 1 0 0.00% 0.00% 0.00% 0 HRPC hled reques 8 0 2 0 0.00% 0.00% 0.00% 0 Timers 184 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl3mm reque PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 102 0 11 0 0.00% 0.00% 0.00% 0 HULC Device Mana 103 0 3 0 0.00% 0.00% 0.00% 0 HRPC hdm non blo 187 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl3u reques 104 0 2 0 0.00% 0.00% 0.00% 0 HRPC hdm blockin 109 0 1 0 0.00% 0.00% 0.00% 0 HRPC hfbm reques 190 3069 44531 68 0.00% 0.00% 0.00% 0 HL3U PBR bkgrd p 191 244 1624 150 0.00% 0.00% 0.00% 0 HL3U PBR n-h res 192 0 1 0 0.00% 0.00% 0.00% 0 HRPC obfl reques 194 0 1 0 0.00% 0.00% 0.00% 0 HRPC dtp request 195 0 1 0 0.00% 0.00% 0.00% 0 HRPC hmedianet p 196 0 1 0 0.00% 0.00% 0.00% 0 HRPC show_forwar 197 0 1 0 0.00% 0.00% 0.00% 0 HRPC snmp reques 198 0 1 0 0.00% 0.00% 0.00% 0 HULC SNMP Proces 7 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro 122 0 2 0 0.00% 0.00% 0.00% 0 Vlan shutdown Pr 201 0 1 0 0.00% 0.00% 0.00% 0 HRPC span reques 202 8 7 1142 0.00% 0.00% 0.00% 0 HRPC system post 203 0 1 0 0.00% 0.00% 0.00% 0 Hulc Reload Mana 204 0 1 0 0.00% 0.00% 0.00% 0 HRPC hrcli-event 205 57 1081 52 0.00% 0.00% 0.00% 0 HCMP sync proces 206 0 2 0 0.00% 0.00% 0.00% 0 image mgr 207 0 1 0 0.00% 0.00% 0.00% 0 HRFS OIR Proc 208 32 9 3555 0.00% 0.00% 0.00% 0 HL2MCM 209 42 9 4666 0.00% 0.00% 0.00% 0 HL2MCM 210 0 4 0 0.00% 0.00% 0.00% 0 Hulc SM10G Infra 211 53 180 294 0.00% 0.00% 0.00% 0 AAA Server 212 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc 213 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr 214 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct 215 0 1 0 0.00% 0.00% 0.00% 0 AUTH POLICY Fram 216 18367 189388 96 0.00% 0.00% 0.00% 0 Auth Manager 217 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B 218 68 649 104 0.00% 0.00% 0.00% 0 IP Admin SM Proc 219 150670 111907 1346 0.00% 0.06% 0.06% 0 CDP Protocol 220 901 398 2263 0.00% 0.00% 0.00% 0 SpanTree Helper 6 218 160 1362 0.00% 0.00% 0.00% 0 Pool Manager 222 0 2 0 0.00% 0.00% 0.00% 0 CMD HANDLER 223 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R 224 162 1622 99 0.00% 0.00% 0.00% 0 DHCP Snooping 225 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping db 128 0 1 0 0.00% 0.00% 0.00% 0 HULC PM Vector P 227 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework 228 0 1 0 0.00% 0.00% 0.00% 0 EAP Test 229 0 2 0 0.00% 0.00% 0.00% 0 EAPoUDP Process 230 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba 231 29487 7857 3752 0.00% 0.01% 0.00% 0 IP ARP Adjacency 4 0 1 0 0.00% 0.00% 0.00% 0 Connection Mgr 3 76 72 1055 0.00% 0.00% 0.00% 0 hulc_entropy_thr 234 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl 235 23066 372533 61 0.00% 0.00% 0.00% 0 IP ARP Track 236 4572 192745 23 0.00% 0.00% 0.00% 0 fnvRootHubPortSt 237 0 1 0 0.00% 0.00% 0.00% 0 tHUB 134 0 4 0 0.00% 0.00% 0.00% 0 HPM if_num mappi 239 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process 240 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces 241 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA 242 0 2 0 0.00% 0.00% 0.00% 0 MKA 243 16 12 1333 0.00% 0.00% 0.00% 6 Virtual Exec 244 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha 245 0 3 0 0.00% 0.00% 0.00% 0 SMI Director DB 246 1648 9732 169 0.00% 0.00% 0.00% 0 SMI CDP Update H 247 0 1 0 0.00% 0.00% 0.00% 0 SMI Backup Proce PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 248 16 68 235 0.00% 0.00% 0.00% 0 hulc cfg mgr mas 249 0 1 0 0.00% 0.00% 0.00% 0 SMI IBC client p 250 0 2 0 0.00% 0.00% 0.00% 0 SMI IBC Download 143 0 1 0 0.00% 0.00% 0.00% 0 hl3md_rpfq_thrl_ 252 140 3245 43 0.00% 0.00% 0.00% 0 Spanning Tree St 253 0 2 0 0.00% 0.00% 0.00% 0 CDP Forward Proc 254 17881 696 25691 0.00% 0.00% 0.00% 0 802.1x switch 255 0 1 0 0.00% 0.00% 0.00% 0 802.1x Webauth F 256 117607 147277 798 0.00% 0.01% 0.04% 0 DTP Protocol 257 0 1 0 0.00% 0.00% 0.00% 0 HRPC IPv6 Host r 258 5027 38612 130 0.00% 0.00% 0.00% 0 IPv6 Platform Ho 259 0 1 0 0.00% 0.00% 0.00% 0 axiom-module cra 260 0 1 0 0.00% 0.00% 0.00% 0 HRPC dai request 2 19346 38909 497 0.00% 0.00% 0.00% 0 Load Meter 262 0 1 0 0.00% 0.00% 0.00% 0 HRPC power down 263 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip device t 264 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip source g 265 0 1 0 0.00% 0.00% 0.00% 0 HULC IP Source g 266 0 1 0 0.00% 0.00% 0.00% 0 HRPC sisf reques 267 0 2 0 0.00% 0.00% 0.00% 0 HULC SISF Proces 268 0 1 0 0.00% 0.00% 0.00% 0 HULC SISF Source 144 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl3mm ipv6 158 0 1 0 0.00% 0.00% 0.00% 0 HRPC dot1x reque 271 220 6486 33 0.00% 0.00% 0.00% 0 Port-Security 272 0 2 0 0.00% 0.00% 0.00% 0 Switch Backup In 273 102 472 216 0.00% 0.00% 0.00% 0 IP Host Track Pr 274 0 1 0 0.00% 0.00% 0.00% 0 Link State Group 275 156 3242 48 0.00% 0.00% 0.00% 0 MMN bkgrd proces 276 1017 19433 52 0.00% 0.00% 0.00% 0 Ethchnl 277 271 348 778 0.00% 0.00% 0.00% 0 VMATM Callback 278 0 1 0 0.00% 0.00% 0.00% 0 IPC UDP Input 279 666 3999 166 0.00% 0.00% 0.00% 0 CEF background p 280 0 1 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e 281 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP 282 0 1 0 0.00% 0.00% 0.00% 0 CEF RF HULC Conv 283 0 1 0 0.00% 0.00% 0.00% 0 XDR background p 284 0 1 0 0.00% 0.00% 0.00% 0 XDR mcast 285 894 19433 46 0.00% 0.00% 0.00% 0 IP ACL XDR LC Ba 286 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back 287 0 1 0 0.00% 0.00% 0.00% 0 XDR mcast rcv 288 124 3242 38 0.00% 0.00% 0.00% 0 XDR RP backgroun 289 0 1 0 0.00% 0.00% 0.00% 0 IPC LC Message H 290 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back 291 387 3941 98 0.00% 0.00% 0.00% 0 ADJ background 292 8 3 2666 0.00% 0.00% 0.00% 0 MDFS LC Process 293 0 1 0 0.00% 0.00% 0.00% 0 Critical Auth 294 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology 295 946 113 8371 0.00% 0.00% 0.00% 0 IP RIB Update 296 0 2 0 0.00% 0.00% 0.00% 0 MRIB Process 149 0 1 0 0.00% 0.00% 0.00% 0 HRPC acl request 185 9371 132556 70 0.00% 0.00% 0.00% 0 hl3mm 299 418067 884230 472 0.00% 0.08% 0.10% 0 TCP Protocols 300 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers 301 41 654 62 0.00% 0.00% 0.00% 0 HTTP CORE 302 51 2434 20 0.00% 0.00% 0.00% 0 Cluster L2 303 1275 19433 65 0.00% 0.00% 0.00% 0 Cluster RARP 304 3176 27538 115 0.00% 0.00% 0.00% 0 Cluster Base 305 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 306 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 307 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 308 0 3 0 0.00% 0.00% 0.00% 0 Flow Exporter Ti 309 32 642 49 0.00% 0.00% 0.00% 0 MFIB Master back PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 310 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl2mcm igmp 311 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl2mcm mlds 312 0 1 0 0.00% 0.00% 0.00% 0 MRIB RP Proxy 313 0 2 0 0.00% 0.00% 0.00% 0 Multicast Offloa 314 0 8 0 0.00% 0.00% 0.00% 0 RARP Input 315 8 87 91 0.00% 0.00% 0.00% 0 static 316 16 11 1454 0.00% 0.00% 0.00% 0 IPv6 RIB Event H 317 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework 318 6431 19433 330 0.00% 0.00% 0.00% 0 QoS stats proces 319 25362 243876 103 0.00% 0.01% 0.00% 0 BGP Router 320 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Proc 321 0 2 0 0.00% 0.00% 0.00% 0 REP BPA/EPA Proc 322 0 6 0 0.00% 0.00% 0.00% 0 SNMP Timers 323 0 1 0 0.00% 0.00% 0.00% 0 HRPC hwccp reque 324 0 1 0 0.00% 0.00% 0.00% 0 HULC_WCCP_BACKGR 325 0 1 0 0.00% 0.00% 0.00% 0 HRPC dhcp snoopi 326 0 4 0 0.00% 0.00% 0.00% 0 HULC DHCP Snoopi 327 919 9725 94 0.00% 0.00% 0.00% 0 HULC stack power 328 0 1 0 0.00% 0.00% 0.00% 0 HRPC stack power 329 638 544 1172 0.00% 0.00% 0.00% 0 IGMPSN L2MCM 330 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD 331 84 95 884 0.00% 0.00% 0.00% 0 IGMPSN 332 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR 333 0 3 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER 334 738 507 1455 0.00% 0.00% 0.00% 0 MLDSN L2MCM 335 0 1 0 0.00% 0.00% 0.00% 0 MRD 336 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP 337 12877 173 74433 0.00% 0.07% 0.04% 0 NIST rng proc 338 150258 1817061 82 0.00% 0.04% 0.05% 0 MDFS RP process 339 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr 340 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve 341 22710 372538 60 0.00% 0.00% 0.00% 0 Timer Library 342 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA 343 0 3 0 0.00% 0.00% 0.00% 0 LDAP process 344 0 2 0 0.00% 0.00% 0.00% 0 Crypto Support 345 0 1 0 0.00% 0.00% 0.00% 0 IPSECv6 PS Proc 346 40 35 1142 0.00% 0.00% 0.00% 0 Collection proce 347 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA 348 33 180 183 0.00% 0.00% 0.00% 0 LOCAL AAA 349 0 2 0 0.00% 0.00% 0.00% 0 EPM MAIN PROCESS 350 15813 187771 84 0.00% 0.00% 0.00% 0 BGP Scheduler 351 0 2 0 0.00% 0.00% 0.00% 0 TPLUS 352 28586 9721 2940 0.00% 0.00% 0.00% 0 HULC ISM FNF 353 348809 17427 20015 0.00% 0.00% 0.00% 0 hulc running con 354 470 33 14242 0.00% 0.00% 0.00% 0 crypto engine pr 355 26244 193395 135 0.00% 0.00% 0.00% 0 Crypto IKEv2 356 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 AAA handle 357 0 1 0 0.00% 0.00% 0.00% 0 CEF RP IPC Backg 358 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc 359 0 2 0 0.00% 0.00% 0.00% 0 CRYPTO MAP FREE 360 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT 361 0 2 0 0.00% 0.00% 0.00% 0 Crypto IKE Dispa 362 0 3 0 0.00% 0.00% 0.00% 0 Crypto IKMP 363 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key 364 624 9723 64 0.00% 0.00% 0.00% 0 IPSEC key engine 365 8 5 1600 0.00% 0.00% 0.00% 0 Crypto ACL 366 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc 367 0 4 0 0.00% 0.00% 0.00% 0 IPSec background 368 335 220 1522 0.00% 0.00% 0.00% 0 Crypto CA 369 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL 370 0 2 0 0.00% 0.00% 0.00% 0 MMON PROCESS 189 0 1 0 0.00% 0.00% 0.00% 0 HRPC IPv6 Unicas PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 372 0 1 0 0.00% 0.00% 0.00% 0 HRPC x_setup req 373 0 2 0 0.00% 0.00% 0.00% 0 REP Switch Helpe 374 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr 375 9 42 214 0.00% 0.00% 0.00% 0 VTP Trap Process 376 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr 377 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector 378 67 1003 66 0.00% 0.00% 0.00% 0 ASP Process Crea 1 0 67 0 0.00% 0.00% 0.00% 0 Chunk Manager 380 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client 381 0 2 0 0.00% 0.00% 0.00% 0 DHCP Security He 382 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Routing 383 2917 22563 129 0.00% 0.01% 0.00% 0 EEM ED Syslog 384 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps 385 1151 6483 177 0.00% 0.00% 0.00% 0 URPF stats 386 84 3242 25 0.00% 0.00% 0.00% 0 vlmap logger 387 0 1 0 0.00% 0.00% 0.00% 0 HCD Process 388 0 1 0 0.00% 0.00% 0.00% 0 HRPC cable diagn 389 0 1 0 0.00% 0.00% 0.00% 0 HRPC rsu request 390 37440 105429 355 0.00% 0.01% 0.00% 0 BGP I/O 391 0 2 0 0.00% 0.00% 0.00% 0 DiagCard1/-1 392 0 1 0 0.00% 0.00% 0.00% 0 Online Diag EEM 393 93911 967682 97 0.00% 0.05% 0.01% 0 PM Callback 394 101333 3240 31275 0.00% 0.05% 0.00% 0 BGP Scanner 395 1079 15548 69 0.00% 0.00% 0.00% 0 dhcp snooping sw 396 0 3 0 0.00% 0.00% 0.00% 0 BGP Event 397 24 159 150 0.00% 0.00% 0.00% 0 EEM Server 398 25 2 12500 0.00% 0.00% 0.00% 0 Call Home proces 399 0 4 0 0.00% 0.00% 0.00% 0 CTS credentials 400 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc 401 167 426 392 0.00% 0.00% 0.00% 7 Virtual Exec 402 0 2 0 0.00% 0.00% 0.00% 0 EEM ED CLI 403 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Config 404 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Counter 405 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env 406 0 3 0 0.00% 0.00% 0.00% 0 EM ED GOLD 407 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Interface 408 8 3 2666 0.00% 0.00% 0.00% 0 EEM ED IOSWD 409 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla 410 0 3 0 0.00% 0.00% 0.00% 0 EEM ED None 411 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR 412 268 3242 82 0.00% 0.00% 0.00% 0 Call Home Timer 413 0 3 0 0.00% 0.00% 0.00% 0 EEM ED RPC 414 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP 415 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje 416 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti 417 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test 418 450 5330 84 0.00% 0.00% 0.00% 0 EEM ED Timer 419 4051 22174 182 0.00% 0.00% 0.00% 0 Syslog 420 17 79 215 0.00% 0.00% 0.00% 0 RBM CORE 421 0 1 0 0.00% 0.00% 0.00% 0 HRPC eee request 422 0 2 0 0.00% 0.00% 0.00% 0 STP FAST TRANSIT 423 0 2 0 0.00% 0.00% 0.00% 0 CSRT RAPID TRANS 424 25 10 2500 0.00% 0.00% 0.00% 0 VLAN Manager 425 25 109 229 0.00% 0.00% 0.00% 0 SSH Event handle 426 422 3691 114 0.00% 0.00% 0.00% 0 IP Background 427 250 749 333 0.00% 0.00% 0.00% 0 IP Connected Rou 428 8148 96317 84 0.00% 0.00% 0.00% 0 CEF: IPv6 proces 429 185071 655345 282 0.00% 0.07% 0.09% 0 LACP Protocol 430 8 5 1600 0.00% 0.00% 0.00% 0 IPv6 IDB 431 2387 25793 92 0.00% 0.00% 0.00% 0 IPv6 background 432 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Address 433 20909 43433 481 0.00% 0.00% 0.00% 0 IPv6 Input PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 434 5994 23573 254 0.00% 0.00% 0.00% 0 IPv6 ND 435 76491 778108 98 0.00% 0.02% 0.00% 0 MLD 436 8 21 380 0.00% 0.00% 0.00% 0 BGP Task 437 3141 12955 242 0.00% 0.00% 0.00% 0 MDFS LC Download 438 0 3 0 0.00% 0.00% 0.00% 0 TCP Listener 439 329965 612265 538 0.00% 0.07% 0.10% 0 IP SNMP 440 69217 306733 225 0.00% 0.01% 0.00% 0 PDU DISPATCHER 441 279630 306775 911 0.00% 0.05% 0.05% 0 SNMP ENGINE 442 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6 443 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro 444 8 4 2000 0.00% 0.00% 0.00% 0 SNMP Traps 445 89642 1805217 49 0.00% 0.01% 0.00% 0 OBFL UPTIME obfl 446 134 4 33500 0.00% 0.00% 0.00% 0 OBFL MSG obfl0 447 69 4 17250 0.00% 0.00% 0.00% 0 OBFL ENV obfl0 448 88970 1805221 49 0.00% 0.04% 0.01% 0 OBFL VOLT obfl0 449 841 12923 65 0.00% 0.00% 0.00% 0 OBFL I/O Buffer 226 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces
10-21-2018 02:23 PM
what is the model of the switch and IOS Version ( i have seen in the config 15.0) but like to know full version.
show version (post the output)
10-21-2018 10:39 PM
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE10a, RELEASE SOFTWARE (fc3)
