cisco 3750x wont boot - HELP
carl_townshend
Hi all
I had an issue where my 3750x wouldnt join a stack, I tried a manual update in the stack it didnt work.
I unplugged the stacking cables, and it boots straight to rommon
its trying to boot from an image in the upgrade directory but fails
I have copied an image from USB into flash and tried to boot from that, it seems to be stuck on loadin, with loads of @ symbols appearing.
How long should it take to boot the image? or am i doing something wrong?
cheers
Carl
egemen1981
IN normal conditions this process should be completed in 3-4 minutes for first boot, after this it can upgrade the microcodes this process also take the same time.
Please check my blog for steps.
http://egementanirer.blogspot.com/2012/10/cisco-catalyst-3750-ios-upgrade.html
http://egementanirer.blogspot.com/2012/10/catalyst-3750-series-switches-in-stack.html
