04-15-2011 12:15 AM - edited 03-06-2019 04:37 PM
I got a Cisco 3750-24T-S. I want use the switch to setup site-to-site vpn. After googling, I dont think it support site to site vpn.
Could some one please confirm whether the switch support site to site vpn?
Ta
04-15-2011 12:39 AM
Always a good idea to check the data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
Nothing about L2L VPNs. Afterwall it is a switch (with routing). For a L2L you should use a router, firewall or VPN concentrator.
HTH,
Ian
04-15-2011 01:58 AM
The 3750x does NOT support a ipsec vpn as in site to site over the internet or something like that.
what I think you have confused it with is 802.1ae wich can encrypt a L1 link with AES encryption.
but so far (-as i know) that is only towards a nexus 7000.
The new software 12.2.58 was hoped (by me and others) to include that 3750x can do 802.1ae towards eachother.
but I have yet tot test that and so far i have seen nothing to indicate that it will work.
The 802.1ae is not to be confused with a site 2 site vpn.
For a site 2 site vpn that you need a firewall or a router.
Good luck
