Cisco 3845 - archive command time-period does not work
I have a Cisco 3845 wiht the archive command configured:
archive
path tftp://x.x.x.x/$h
write-memory
time-period 60
The archive command works with the execution of the write mem, but with the "time-period" doesn't work.
Am I doing something wrong?
Or Do you know if my IOS is affected for some bug?...
This is the show version of my 3845:
NTP_Server#SH VER
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 23-Mar-06 01:59 by pwade
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
NTP_Server uptime is 19 weeks, 5 days, 17 hours, 24 minutes
System restarted at 19:20:38 MEXICO Tue May 29 2012
System image file is "flash:c3845-spservicesk9-mz.123-14.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 224256K/37888K bytes of memory.
Processor board ID FHK0846F193
2 Gigabit Ethernet interfaces
1 Subrate T3/E3 port
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
I'll appreciate all of your aportations.
Thanks a lot.
Héctor.
MICHAEL OLIVER
Hector, did you ever find a solution to this? I am running into the same (I think) problem with a 3640 that is also running 12.3(14)T7 (c3640-ik9o3s-mz.123-14.T7.bin to be specific) and I have not found a solution. When manually issuing the 'wr' command the config is copied to the tftp server in whole, but the time-period automation only saves a very small file with only 'boot-start-marker' and 'boot-end-marker'. Very odd.
EDIT: I discovered another thread that described exactly the same behavior:
https://supportforums.cisco.com/thread/2065652
I followed the example at the very end of the thread and created a kron job to initiate the 'archive config' command. It's a hack, but works.
Mike Oliver, KT2T
(please use personal methods of contact, not my AT&T contact info)
+1-863-606-8008
mwoliver@gmail.com
@mwoliver
-- Mike Oliver, KT2T (please use personal methods of contact, not my AT&T contact info) +1-863-606-8008 mwoliver@gmail.com @mwoliver
