cisco 3850 3650 cpu punt queues
paul amaral
Level 4
Level 4
I have been trying to figure out 3850 / 3650 CPU queue traffic with not much success. I have a couple of 3850/3650 that are dropping traffic punted to the CPU. For example, on a 3650 I have traffic punted to the CPU from FED for SW forwarding queue and notice a lot of dropped packets. Are these dropped packets at the CPU itself? I’m assuming sw forwarding traffic, is traffic that can’t be processed in hardware therefore processed by the main cpu before being forwarded? If there a way to look at that RX CPU queue and look at the packets destined to it. I keep running into show buffer pool RxQ(id) but that command no longer works on IOS 16.9.x. I did setup a monitor capture to the control plane but nothing stood out to me.
looking at this closer I believe its cef packets being punted
sh platform software fed switch active punt cause sum
Statistics for all causes
Cause Cause Info Rcvd Dropped
2 IPv4 Options 975 0
7 ARP request or response 3191132 0
11 For-us data 27501786 0
21 RP<->QFP keepalive 974395 0
24 Glean adjacency 73749075 1362726
#sh platform software fed switch active punt cpuq br
Punt CPU Q Statistics Brief
 Q  |         Queue           |  Rx    |  Rx   |  Rx    |  Drop  |  Drop   |  Drop
 no |         Name            |  prev  |  cur  |  delta |  prev  |  cur    |  delta
 0  CPU_Q_DOT1X_AUTH               0        0        0        0        0        0
 1  CPU_Q_L2_CONTROL               22726839 22775124 48285    0        0        0
 2  CPU_Q_FORUS_TRAFFIC            27410316 27452377 42061    0        0        0
 3  CPU_Q_ICMP_GEN                 0        0        0        0        0        0
 4  CPU_Q_ROUTING_CONTROL          472482   473460   978      0        0        0
 5  CPU_Q_FORUS_ADDR_RESOLUTION    3230656  3236894  6238     0        0        0
 6  CPU_Q_ICMP_REDIRECT            4405728  4409997  4269     0        0        0
 7  CPU_Q_INTER_FED_TRAFFIC        0        0        0        0        0        0
 8  CPU_Q_L2LVX_CONTROL_PKT        0        0        0        0        0        0
 9  CPU_Q_EWLC_CONTROL             0        0        0        0        0        0
 10 CPU_Q_EWLC_DATA                0        0        0        0        0        0
 11 CPU_Q_L2LVX_DATA_PKT           0        0        0        0        0        0
 12 CPU_Q_BROADCAST                892821   894644   1823     0        0        0
 13 CPU_Q_LEARNING_CACHE_OVFL      0        0        0        0        0        0
 14 CPU_Q_SW_FORWARDING            73568522 73696006 127484   1364361  1366266  1905
 15 CPU_Q_TOPOLOGY_CONTROL         0        0        0        0        0        0
 16 CPU_Q_PROTO_SNOOPING           0        0        0        0        0        0
 17 CPU_Q_DHCP_SNOOPING            0        0        0        0        0        0
 18 CPU_Q_TRANSIT_TRAFFIC          0        0        0        0        0        0
 19 CPU_Q_RPF_FAILED               0        0        0        0        0        0
 20 CPU_Q_MCAST_END_STATION_SERVICE 22484    22530    46       0        0        0
 21 CPU_Q_LOGGING                  0        0        0        0        0        0
 22 CPU_Q_PUNT_WEBAUTH             0        0        0        0        0        0
 23 CPU_Q_HIGH_RATE_APP            0        0        0        0        0        0
 24 CPU_Q_EXCEPTION                0        0        0        0        0        0
 25 CPU_Q_SYSTEM_CRITICAL          0        0        0        0        0        0
 26 CPU_Q_NFL_SAMPLED_DATA         0        0        0        0        0        0
 27 CPU_Q_LOW_LATENCY              40       40       0        0        0        0
 28 CPU_Q_EGR_EXCEPTION            266288   267006   718      0        0        0
 29 CPU_Q_FSS                      0        0        0        0        0        0
 30 CPU_Q_MCAST_DATA               0        0        0        0        0        0
 31 CPU_Q_GOLD_PKT                 0        0        0        0        0        0
I notice that many packets to SW forwarding queue have been dropped on the cpu queue itself but COPP policing doesn’t match this, while I see packets dropped in real-time with the command above, when looking at COPP policing I don’t see as many packets being dropped, so not sure how something dropped on the CPU queue is not necessarily dropped by the policer.
TIA, Paul
Policer stats
                         CPU Queue Statistics
                                              (default)  (set)     Queue
QId PlcIdx  Queue Name                Enabled   Rate     Rate      Drop(Bytes)
0    11     DOT1X Auth                  Yes     1000      1000     0
1    1      L2 Control                  Yes     2000      2000     0
2    14     Forus traffic               Yes     4000      4000     0
3    0      ICMP GEN                    Yes     600       600      0
4    2      Routing Control             Yes     5400      5400     0
5    14     Forus Address resolution    Yes     4000      4000     0
6    0      ICMP Redirect               Yes     600       600      2430232
7    16     Inter FED Traffic           Yes     2000      2000     0
8    4      L2 LVX Cont Pack            Yes     1000      1000     0
9    16     EWLC Control                Yes     2000      2000     0
10   16     EWLC Data                   Yes     2000      2000     0
11   13     L2 LVX Data Pack            Yes     1000      1000     0
12   0      BROADCAST                   Yes     600       600      954
13   10     Openflow                    Yes     100       100      0
14   13     Sw forwarding               Yes     1000      1000     49251043
15   8      Topology Control            Yes     13000     13000    0
16   12     Proto Snooping              Yes     2000      2000     0
17   6      DHCP Snooping               Yes     500       500      0
18   9      Transit Traffic             Yes     500       500      0
19   10     RPF Failed                  Yes     100       100      0
20   15     MCAST END STATION           Yes     2000      2000     0
21   13     LOGGING                     Yes     1000      1000     0
22   7      Punt Webauth                Yes     1000      1000     0
23   10     High Rate App               Yes     100       100      0
24   10     Exception                   Yes     100       100      0
25   3      System Critical             Yes     1000      1000     0
26   10     NFL SAMPLED DATA            Yes     100       100      0
27   2      Low Latency                 Yes     5400      5400     0
28   10     EGR Exception               Yes     100       100      0
29   5      Stackwise Virtual OOB       Yes     8000      8000     0
30   9      MCAST Data                  Yes     500       500      0
31   3      Gold Pkt                    Yes     1000      1000     0
* NOTE: CPU queue policer rates are configured to the closest hardware supported value
                      CPU Queue Policer Statistics
Policer    Policer Accept   Policer Drop
  Index         Bytes          Bytes
0          545864331        2431186
1          2665264654       0
2          61734583         0
3          0                0
4          0                0
5          0                0
6          0                0
7          0                0
8          0                0
9          0                0
10         20320974         0
11         0                0
12         0                0
13         5613065589       49251043
14         2931255243       0
15         2644260          0
16         0                0
17         0                0
                        CPP Classes to queue map
PlcIdx CPP Class                                :  Queues
0      system-cpp-police-data                   :  ICMP GEN/BROADCAST/ICMP Redirect/
10     system-cpp-police-sys-data               :  Openflow/High Rate App/Exception/EGR Exception/NFL
 SAMPLED DATA/RPF Failed/
13     system-cpp-police-sw-forward             :  Sw forwarding/LOGGING/L2 LVX Data Pack/
9      system-cpp-police-multicast              :  Transit Traffic/MCAST Data/
15     system-cpp-police-multicast-end-station  :  MCAST END STATION /
7      system-cpp-police-punt-webauth           :  Punt Webauth/
1      system-cpp-police-l2-control             :  L2 Control/
2      system-cpp-police-routing-control        :  Routing Control/Low Latency/
3      system-cpp-police-system-critical        :  System Critical/Gold Pkt/
4      system-cpp-police-l2lvx-control          :  L2 LVX Cont Pack/
8      system-cpp-police-topology-control       :  Topology Control/
11     system-cpp-police-dot1x-auth             :  DOT1X Auth/
12     system-cpp-police-protocol-snooping      :  Proto Snooping/
6      system-cpp-police-dhcp-snooping          :  DHCP Snooping/
14     system-cpp-police-forus                  :  Forus Address resolution/Forus traffic/
5      system-cpp-police-stackwise-virt-control :  Stackwise Virtual OOB/
16     system-cpp-default                       :  Inter FED Traffic/EWLC Control/EWLC Data/
ACCESS-FRV-3600-Stack-SW#
0 Replies 0
