Cisco 3850 activate ipservices license
Ajin Skariah
I have 2 3850 stacked switches running on ipbase license. I want to activate ipservices on both the switches. How can I achieve it? When I issued license-right-to-use detail, I can see that ipservices peirod left is lifetime and state is not activated. Does this means I can update it with the command license right-to-use activate ip-services all accepteula ? The show commands output given below.
COMMON-L3-SWITCH#show license right-to-use
 Slot#  License name   Type     Count   Period left
1      ipbase       permanent     N/A   Lifetime
License Level on Reboot: ipbase
2      ipbase       permanent     N/A   Lifetime
COMMON-L3-SWITCH#show license right-to-use summary
License Name    Type     Count   Period left
  apcount      base        0        Lifetime
  apcount      adder       0        Lifetime
License Level In Use: ipbase
Evaluation AP-Count: Disabled
Total AP Count Licenses: 0
AP Count Licenses In-use: 0
AP Count Licenses Remaining: 0
COMMON-L3-SWITCH#show license right-to-use usage
Slot#  License Name     Type     usage-duration(y:m:d)  In-Use  EULA
1      ipservices     permanent    0 :0 :0                no    no
 1      ipservices     evaluation   0 :0 :0                no    no
 1      ipbase         permanent    0 :0 :19               yes   yes
 1      ipbase         evaluation   0 :0 :0                no    no
 1      lanbase        permanent    0 :0 :0                no    no
 1      apcount        evaluation   0 :0 :0                no    no
 1      apcount        base         0 :0 :0                no    no
 1      apcount        adder        0 :0 :0                no    no
2      ipservices     permanent    0 :0 :0                no    no
 2      ipservices     evaluation   0 :0 :0                no    no
 2      ipbase         permanent    0 :0 :18               yes   yes
 2      ipbase         evaluation   0 :0 :0                no    no
 2      lanbase        permanent    0 :0 :0                no    no
 2      apcount        evaluation   0 :0 :0                no    no
 2      apcount        base         0 :0 :0                no    no
 2      apcount        adder        0 :0 :0                no    no
Ajin Skariah.
Hi Ajin,
This link could be useful
http://blog.router-switch.com/2016/10/how-to-activateupgrade-c3850-ip-base-license-to-ip-services/
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Ajin,
I have the same question. It's not quite clear from the blog post. In my case the output of show license right-to-use detail is:
SWITCH01#show license right-to-use detail
Index 1:  License Name: ipservices
           Period left: Lifetime
           License Type: permanent
           License State: Not Activated
           License Count: Non-Counted
           License Location: Slot 1
Index 2:  License Name: ipservices
           Period left: 90
           License Type: evaluation
Index 3:  License Name: ipbase
           License State: Active, In use
Index 4:  License Name: ipbase
           Period left: 90
Index 5:  License Name: lanbase
Index 6:  License Name: apcount
           Period left: 90
           License Count: 50
Index 7:  License Name: apcount
           License Type: base
           License Count: 0
Index 8:  License Name: apcount
           License Type: adder
           License Count: 0
What does this mean? Can I just activate the ipservices license for both of the swiches in the stack? Do I need to order a new ipservices license?
Hi Bavarian,
You can just activate the ipservices license using the command license right-to-use activate ipservices.
Ajin Skariah.
antonypeediacal
run the command "license right-to-use activate ipservices all acceptEULA"
